impreza gc8 turbo
impreza gc8 turbo
Răspuns: impreza gc8 turbo
« Reply #20 on: May 22, 2012, 09:24:29 AM »
BC coilvers sunt ok destul de populare aici dar bune pt track day sau racing in zi cu zi mers poate putin prea tari.
Pararea mea un anti-lift kit o sa faca diferenta masiva(stie cine are ) si whiteline antirol bars very good cu linkuri bune si vezi cum este.
« Reply #21 on: May 22, 2012, 21:28:50 PM »
ce diferenta face un anti lift kit?
« Reply #22 on: May 22, 2012, 22:46:38 PM »
Daca te uiti la postul meu ultimile foto se vede este bucsa spate de la bascula fata fiind acel plastic cauciucat numai are acel flex precum celor originale. Dupa ce am pus bara torsiune fata cu linkuri si anti-lift kitul sa schimbat total masina. ;D ;D ;D ;D ;D ;D ;D
uite aici ceva exemple
http://www.ebay.co.uk/itm/Subaru-Impreza-Classic-GC8-SuperPro-Anti-Lift-Front-Control-Arm-Rear-Bush-Kit-/230794996962?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35bc742ce2#ht_2224wt_952
si white line
http://www.ebay.co.uk/itm/Subaru-Impreza-WRX-GC-GF-93-00-Anti-lift-caster-kit-F-/120841300745?pt=AU_Car_Parts_Accessories&hash=item1c22b3eb09#ht_2438wt_1139
http://www.ebay.co.uk/itm/Subaru-Impreza-Anti-Lift-Kit-93-2000-CDF-Racing-/270953930646?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f161cdf96
Am sa intreb la yard poate au ceva pe acolo second hand , eu asa l am luat mega ieftin ;)
« Last Edit: May 22, 2012, 22:54:37 PM by impreza 01 »
« Reply #23 on: May 30, 2012, 15:14:53 PM »
mai mult te ajuta la inca cateva grade de caster un alk
« Reply #24 on: June 20, 2012, 20:03:31 PM »
Am nevoie urgent de un kit ambreiaj! cateva recomendari daca aveti.
« Reply #25 on: June 20, 2012, 20:35:35 PM »
daca ai standard power cel stock e ok . dupa vine exedy organic plate.
« Reply #26 on: June 21, 2012, 01:29:02 AM »
sau act, au si ei ambreaje foarte bune
« Reply #27 on: June 21, 2012, 09:42:40 AM »
mersi cred ca o sa raman cu exedy organic/stage1
Dupa cum stiu volanta nu trebuie schimbata. Nu?
Mihai.impreza
  • 733
  • Subaru impreza 1.6 TS
« Reply #28 on: June 21, 2012, 09:43:51 AM »
eu stiu ca un kit de ambreaj contine:rulment,disc,placa de presiune,nu cred ca este inclusa volanta!!!!si volanta se schimba banuiesc dupa uzura!!
« Reply #29 on: June 22, 2012, 00:32:02 AM »
nu , sau poti pune o volanta mai usoara .
« Reply #30 on: June 22, 2012, 09:26:39 AM »
Daca are volanta cu masa dubla e prima care trebuie schimbata....de obicei volanta asta cand pica strica si ambreiajul.
Recomandat ar fi sa fie schimbat ambreiajul complet cu volanta cu tot.
Ex. 03 WRX
99 STI Coupe Race Car
08 Impreza STI
« Reply #31 on: June 22, 2012, 10:41:40 AM »
are volanta simpla .. nu trebuie schimbata decat daca este uzata (dar astea se strica foarte foarte greu)
« Reply #32 on: June 22, 2012, 10:45:35 AM »
Asa e...daca volanta e cu masa simpla ii trebuie doar ambreiaj.
Ex. 03 WRX
08 Impreza STI
« Reply #33 on: June 22, 2012, 21:37:23 PM »
e si diferenta de pret intre exedy standard si cel organic.
« Reply #34 on: June 23, 2012, 11:29:55 AM »
Am comandat am si primit si instalat un kit ambreiaj f1 racing stage 3 si pot sa spun ca e SUPER :) Am primit la un pret bun!
Am si instalat un ALK de la Summit! A schimbat total cum comporta la accelerale si franare! Mersi ptr sfaturi!
Ambreiaje F1 racing merita incercat mai ales stage 3 ceramic.
draculasti
« Reply #35 on: June 24, 2012, 04:14:09 AM »
Szervus borát ! Fain subi ,bafta la modificari!
« Reply #36 on: August 21, 2012, 22:50:01 PM »
Am vazut masina la vanzare... ce sa intamplat? :-[
« Reply #37 on: August 24, 2012, 19:56:02 PM »
Nimic numai vreau sa cumpar una mai noua un sti din 2004 sus. atat :)
« Reply #38 on: August 24, 2012, 22:22:23 PM »
aha... e bine ca ramai tot la Subaru. Bafta ;D
