STI 2011 hatch
STI 2011 hatch
Răspuns: STI 2011 hatch
« Reply #40 on: November 16, 2015, 22:46:57 PM »
Grupa mare e Tribeca, STi este grupa speciala.
  • 1740
« Reply #41 on: November 17, 2015, 08:14:39 AM »
Si Forester ce e? :P
« Reply #42 on: November 17, 2015, 09:17:32 AM »
Umplutura...grupa mica... sleeperu perfect?  :D
  • 2813
Răspuns:
« Reply #43 on: November 17, 2015, 09:30:56 AM »
XTul stock la aspect, poate fi numit sleeper
  • 1740
« Reply #44 on: November 17, 2015, 09:56:25 AM »
Nu ma refeream la aspect  :P
  • 2813
Răspuns:
« Reply #45 on: November 22, 2015, 18:03:28 PM »
http://perrinperformance.com/i-14908570-air-oil-separator-for-wrx-sti.html
Tot citind despre motor, am inteles ca acest gen de device ar ajuta mult minimizarea detonatiilor. Are cineva montat?
  • 4081
« Reply #46 on: November 22, 2015, 18:23:49 PM »
mihai (ratzalarul) are aos , eu am un catch can cu iesire afara direct... sa nu bag in admisie nimic ...
ambele sisteme isi indeplinesc scopul - admisia si intercoolerul sunt perfect curate pe interior - fara ulei si alte mazgi :) (pluralul de la mazga ? :) )
« Last Edit: November 22, 2015, 18:28:26 PM by andea79 »
  • 2813
Răspuns:
« Reply #47 on: November 22, 2015, 18:37:58 PM »
Deci e recomandat. Rau in nici un caz nu face din ce am citit/vazut. Cel mai ieftin si simplu de montat e grimmspeed
  • 4081
« Reply #48 on: November 22, 2015, 19:24:21 PM »
rau cu siguranta nu face, practic nu mai bagi ulei in intercooler -ii reduce eficienta - si in cilindrii - uleiul creste probabilitatea de knock
despre eficienta grimmspeedului am citit opinii divergente :)
  • 5457
« Reply #49 on: November 22, 2015, 19:28:22 PM »
De ce are jdemii de stuturi? Nu e un catch tank (separator gaze carter) obisnuit?
Ratzalaru
  • 322
  • It's all about the road...
« Reply #50 on: November 22, 2015, 20:41:11 PM »
Are multe stuturi pentru ca are si circuit pentru lichidul de racire, ca sa incalzeasca AOS-ul si sa reduca condensarea vaporilor de apa - reduce mizeria care se poate aduna in el.
Fata de catch can un AOS are avantajul ca trebuie curatat mult mai rar (al meu de ex nici nu poate fi curatat, e capsat - Crawford AOS v2).
Dezavantajele ar fi ca nu au aceeasi eficienta ca un catch can, sunt in general mai scumpe si sunt in piata unele care nici nu functioneaza bine (la al meu doar versiunea 2 e considerata ok, versiunea 1 zice lumea ca erau bani aruncati pe fereastra).
Take you pick... de meritat merita!
STI 2008
  • 4081
« Reply #51 on: November 22, 2015, 20:56:42 PM »
doar sa completez ca probabil nu au aceeasi eficienta cu a unui catch can cu iesirea scoasa direct afara, pentru ca in mod normal si catch can-ul se instaleaza cu iesirea in admisie si in acest caz cred ca AOS-ul este mai eficient ..
  • 2813
Răspuns:
« Reply #52 on: November 22, 2015, 21:17:44 PM »
Multumesc pt pareri...trec pe lista
  • 4081
« Reply #53 on: November 22, 2015, 22:21:21 PM »
ai vazut ce scrie cu rosu la grimmspeed pe site:
"Please note this product is designed to combat factory amounts of blow by. If you have a built motor or are experiencing abnormal amounts of oil consumption, this product may not work for you"
adica tradus : "in teorie merge, in practica poate mai gasiti ulei in intercooler dar nu e din cauza noastra " :)
  • 3912
« Reply #54 on: November 22, 2015, 22:50:52 PM »
Hai ma... Voi ati invatat alta engleza pe-acolo...
  • 4081
« Reply #55 on: November 22, 2015, 23:18:40 PM »
 ;D recunosc am reformulat un pic, sa traduc cuvant cu cuvant  ;D
Please note  - Va ugam sa tineti cont
this product  - ca acest produs
is designed  - este facut
to combat factory  - sa functioneze
amounts of blow by. - in teorie
If you have a  - Daca aveti
built motor  - un motor bulit
or are experiencing abnormal  - sau faceti experimente anormale
amounts of oil consumption,  - si consumati ulei
this product may not work for you  - il veti gasi in intercooler :)
« Last Edit: November 22, 2015, 23:25:20 PM by andea79 »
« Reply #56 on: November 23, 2015, 07:38:20 AM »
  • 2813
Răspuns:
« Reply #57 on: November 23, 2015, 08:48:57 AM »
Mda, deci nu firma asta...
Totusi ei spun ca e posibil ca sa manance in continuare ulei dar din alte cauze, mai ales daca ai un motor non stock-built.
« Reply #58 on: November 23, 2015, 09:17:39 AM »
Nota 10 Pentru traducerea lui Andea79.
« Reply #59 on: November 23, 2015, 09:47:44 AM »
prova parca mai facea un aos bunicel, pe de alta parte daca vrei sa rezolvi mai multe pb inclusiv aceasta poti mereu sa mergi catre un dry sump setup daca cumva te deranjeaza un rinichi sau ficat :))
