Jurnale de bord => Impreza => Impreza mea GC/GF/GM (1992-2000) => Topic started by: daniel.gugu on January 12, 2013, 00:43:15 AM
Hello again...
Inca un Subaru in fata casei lui Malakay :))
De cateva ore a mai intrat un Subi in familie. Vorbim de un Subaru Impreza GC, 2.0 turbo, 4wd.
Masina a fost postata la "vanzari auto".
Poze mai tarziu, dupa o curatare completa.
Impresii la "a nu stiu cata vedere" si dupa prima plimbare :
Estetic :
- lasa mult de dorit - tabla ruginita
Tehnic - mecanic :
- un monstru brutal si foarte galagios
Ca planuri : inca nu sunt finalizate...
Multumesc Malakay... Inca o data...
UP-DATE 11.02.2016
Engine - power :
- Apexi Power FC Commander
- Apexi Boost Controller Kit
- radiator aluminiu
- ventilatoare Mishimoto
- fmic
- pompa benzina Walbro 255l
- surub magnetic baie ulei
- tampoane motor & pitch mount STI Grupa N
- radiator ulei
- turbo TD05H
- injectoare yellow 440cc
- distantiere phenolice admisie
- serpi ...
Transmisie & Suspensie :
- suspensie BC Racing
- pivoti si capete de bara de directie SuperPro
- bascule fata aluminiu
- bielete stabilizatoare CDF Racing
- sway bars front (22mm) rear (24mm) Whiteline
- bucsi spate Powerflex
Frane :
- 4pot WRC calipers
- discuri .... de schimbat
- placute frana DS2500
Up-Date 18.04.2019
Up-Date 28.04.2019
Engine
EJ20 closed deck
Shortblock
RCM/Omega Pistons 92.25 2.1 Stroker kit
Crankshaft 79mm induction treated STI 2.5
Connecting rod Manley H-Tuff
Main bearing ACL Race
ARP Head Stud Kit Subaru EJ 2.0/2.5L DOHC CA625+, Kit #: 260-4704
ARP Case Bolt Kit Subaru EJ20/EJ25, Kit #: 260-5401
IAG Half Moon Valve Cover Cam Seals Black
13199AA010 Camshaft Sprocket Bolts x 2 Subaru EJ205 EJ255 EJ206 EJ208 EJ207 EJ257
Subaru Impreza, Legacy & Forester Quad Cam Front Timing Belt Cover Bolt Set
Subaru Impreza, Legacy & Forester Bell Housing Timing Hole Bung
Subaru Impreza Turbo 98 On Small Engine Block Gallery Plug & Washer
Oil system
Pan assy, oil Impreza GT/WRX/STI 1994-2005, Forester Turbo 1998-2005 - 11109AA053
RCM Magnetic Sump Bung - RCM2761
Oil strainer complete-engine Impreza GT/WRX/STI 2.0, Forester, Legacy/Outback, Baja - 15050AA050
Screw countersunk head to oil pump cover Impreza STI, 6x14x14
Impreza 2000 To 2007 Genuine Subaru Oil Pressure Sensor/Switch 25240KA040
Subaru Impreza Turbo 92-07 Dip Stick Tube
Subaru Impreza 92-14 ICP Oil Gallery 1/8BSPT Adapter For Defi Gauges
Cylinder heads
Manley Valve Spring and Retainer Kit for Impreza WRX/STI
Intake valves Impreza WRX/STI Manley Performance
Exhaust valves Impreza WRX/STI Manley Performance
Brian Crower 6mm Exhaust Valve Guides
Brian Crower 6mm Intake Valve Guides
??? Camshafts
Cooling system
Mishimoto Racing Thermostat Subaru STI 2001-2016 MMTS-WRX-01
Mishimoto radiator MMRAD-WRX-01
Mishimoto radiator vents MMFS-WRX-01P
Mishimoto kit furtunuri MMHOSE-WRX-01BK
Mishimoto MMHOSE-SUB-ANCRD
Subaru Impreza Turbo High Flow Cast Impeller Water Pump Kit
Subaru Impreza Turbo Oil Cooler to Water Pump cross over pipe
Subaru Impreza 96-17 Water Transfer O-Rings & Bolts
Fuel system
DW300 340lph Deatschwerks Compact In-Tank fuel pump Impreza 1997-2007 DW-9-301-0791
Subaru Impreza Turbo 92-00 Fuel Tank Straps
Subaru Impreza 93-00 Fuel Neck Filler Pipe Kit
Subaru Impreza Fuel Filler Neck Cap
Subaru Impreza 92-00 Fuel Filler Neck Lower Hose & Clips
Subaru Impreza 92-00 Fuel Filler Neck One Way Valve
Subaru Impreza 92-00 Fuel Filler Neck Body Gasket
Subaru Impreza 00-07 Fuel Pipe Retaining Clips 42037AE150
Subaru Impreza 92-07 Genuine Fuel Pump Tank Gasket
Accessories
STI Performance Group N engine mount, right Impreza ST4100055110
STI Performance Group N engine mount, left Impreza ST4100055120
Subaru Impreza, Legacy & Forester Genuine STi Group N Engine Pitch Stopper
Engine gasket and seal kit Subaru Impreza STI 2.0 2001-2005 10105AA360
Subaru Impreza, Legacy & Forester Alternator Live Wire Red Rubber Cap
Subaru Positive Battery Terminal Rubber Boot Cover
Subaru Turbo 5 x Exhaust studs & Flanged Nuts
Drivetrain & Transmission
STI Performance Group N gearbox mount, 6 speed ST410224S040
STI Performance Group N cushion lever support Impreza ST35036ST000
Subaru Impreza Turbo 2.0 STi 6 Speed Gearbox Gasket Seal Kit 00-02
Subaru Impreza Turbo LHD 00-07 GD/GG ICP Stainless Steel Black Braided Clutch Slave Cylinder Feed Line
Subaru Impreza Legacy Forester Block to Gearbox Stud
Subaru Impreza Turbo Front Gearbox Crossmember Bolt
Powerflex Rear differential mount Impreza GT/WRX/STI PFR69-122
Subaru Impreza 92-07 Turbo R160/R180 Rear Diff Upper Fill Plug
Subaru Impreza STi R180 Diff Gasket Set
Subaru Impreza 92-07 Turbo R160/R180 Rear Diff Lower Drain Plug
Subaru Impreza, Legacy & Forester Rear Diff End Cover Bolt 800210310
Bolt and washer assembly, pressure plate clutch 800508310
Brakes & Wheels
Front
Brembo STI 2002 Calipers
Godspeedbrakes front discs
Carbone Lorraine RC6 front brake pads for Impreza CL4066RC6
Carbone Lorraine RC5+ front brake pads for Impreza STI 4066T16RC5+
Rear
Godspeedbrakes rear discs
Carbone Lorraine RC6 rear brake pads for Impreza STI 4060RC6
Refurbishment
Subaru Impreza & Forester STi Brembo Front Brake Pad Fitting Kit
Subaru Impreza 2.0 & 2.5 STi Front & Rear Brembo Caliper Mounting Bolts
Subaru Impreza WRX STi 00-07 Brembo Rear Caliper Seal Kit
Subaru Impreza & Forester STi Brembo Rear Brake Pad Fitting Kit
Subaru Impreza STi Front Or Rear Brembo Caliper Bleed Nipple Cover
Subaru Impreza WRX STi 00-07 Brembo Front Caliper Seal Kit
Subaru Impreza, Legacy, Outback & Forester Stainless Steel Caliper Banjo Bolts & Washers
Handbrake
Subaru Impreza, Legacy & Forester Handbrake Shoe Fitting Spring Kit
Impreza 1992 to 2007 Rear Handbrake Shoe Adjuster
Subaru Impreza Handbrake Cable Retaining Clip
Impreza WRX STi Rear Handbrake Shoe Right Hand Lever Kit
Impreza WRX STi Rear Handbrake Shoe Left Hand Lever Kit
Lichid Frana Motul RBF660
Subaru Impreza Turbo 00-07 GD/GG ICP Stainless Steel Black Braided Brake Line Kit
Wheels & Tyres
Winter - not needed
Summer - Prodrive GC010 17" x 8J, 5x100, 6.5kg/pc
- Federal 595 RS-R, 235/45/17
Handling & Suspension
Steering rack 2.2 turns lock to lock GpA
Mishimoto Universal Transmission Cooler and Power Steering Cooler, MMTC-U
Bushing column assy Impreza - 34361FC000
Subaru Impreza Turbo 92-05 Steering Rack Mount Brackets & Superpro Bushes
Subaru Impreza Power Steering Pump High Pressure Pipe Banjo Bolt Washer
Subaru Impreza WRX & STi 00-02 Genuine Power Steering Pump Seal Kit
Front
Whiteline Front Control arm - lower inner rear bushing (anti-lift/caster correction) KCA359
Whiteline front roll centre/bump steer - correction kit KCA313
Rear
Whiteline rear sway bar links KLC26
Bracket, trailing arm left Impreza 20540FE110
Bracket, trailing arm, right Impreza 20540FE100
Subaru Impreza Rear Diff Outrigger Washer 41324FA000
Subaru Impreza Turbo Front Chassis Rail Reinforcement Plates
Subaru Impreza 92-07 Lateral Link & Trailing Arm Bolt Set
Subaru Impreza 92-00 Rear Diff Outrigger Mounting Bolts
Subaru Impreza Rear Diff Outrigger Bracket Bolts
Subaru Impreza 92-04 Front Shocker Upper Camber Adjusting & Lower Bolts
Subaru Impreza Turbo 00-07 Rear Subframe Mounting Bolt Set
Cusco power brace, front member Subaru Impreza GT (GC8), 660 492 FM
Interior & Exterior & Body
Body Sandblasting / welding / rust protection
Rollcage OMP FIA
Subaru Impreza 01 on STi Subaru Tecnica Interantional Door Sticker LH
Subaru Impreza 01 on STi Subaru Tecnica Interantional Door Sticker RH
Subaru Impreza Turbo 92-98 Front Bumper Support Beam (New Bolts (4))
Subaru Impreza 92-00 Brand New Rear Bumper Support Beam (New Bolts (4))
Subaru Impreza 92-00 Side Sill Fitting Kit
Subaru Impreza GC Saloon Fuel Filler Neck Plastic Cover
Subaru Impreza Weather Strip White Screw Grommet
Subaru Impreza, Forester & Legacy Metal Weather Strip Tapping Screw
Subaru Impreza 92-00 Bulkhead Grommet For A/C Cars
Subaru Impreza 92-00 Genuine Bulkhead Grommet For Non A/C Cars
Subaru Impreza 92 Onwards Bonnet Insulation Retaining Clip 90814FC001
Impreza 92-02 Front Window Stabilizer Guide 61256FE020
Subaru Impreza Full Roof Trim Clip Set Saloon & 2 Door Only
Subaru Impreza 92-00 Genuine Upper Front Panel
Subaru Impreza 92-00 Saloon Screen Upper & Lower Trim Set
Subaru Impreza 92-00 Genuine RH Headlight Front Panel
Subaru Impreza 92-00 Genuine LH Headlight Front Panel
Subaru Impreza 92-00 Genuine Front Panel Bonnet Catch Support
Subaru Impreza 92-00 Genuine Lower Front Panel Kit
Bracket spoiler, right Impreza GT/WRX, 96055FA150
Base, license plate Impreza 1992-2007, Forester 1997-2002 - 757745500
Clip - pin Impreza GT - 91167AA000
Bolt, grill front
Bolt, fender Impreza 801506040
Clip - pin Impreza GT 91167AA000
Grommet, hood support stay 57253AA010
Clip Impreza 92-00 - 91167FA010
Clip-bumper, side Impreza GT/WRX/STI - 57728AC090
Clip front bumper Impreza GT/WRX - 59122FA010
Screw, grille front hood Impreza GT - 904575013
Tapping screw, moulding roof Impreza 1993-2001, Legacy 1995-1998 - 91173FA000
Subaru Impreza 00-07 JDM Red Hazard Switch
Felicitari! Rupe-i gura! ;D
Lu` Malakay?? ::) :D
In cazul de fata : vecinul de langa casa niciodata nu te lasa... :D ;D
Malakay e mai ceva decat un virus pt windows...
Sa o stapanesti sanatos !! si sa aveti grija unul de celalalt !!!
Eu nu mai vorbesc cu Victor. Daca ma apuca si pe mine virusul sa mai adun si alte Subaru in fata casei?
Sa o stapanesti sanatos si sper ca vei reusi sa o aduci intr-o stare buna si d.p.d.v estetic.
Multumesc mult tuturor...
Nu ma pot da jos din ea... 1 plin = 380km ouch!!! din care si un drum Bucuresti Pitesti.
Acum lucram la lista "cu si despre" :'( :'( ... E atat de lunga ... Mai lunga decat strada Lunga din Brasov.
Astept sfaturi si sugestii!
:D :D Pai ai facut cam mult cu un plin. Dupa ce o vei cunoaste, si te vei da la ea "de-adevaratelea", vei ajunge sa faci mai putin cu un plin.
Felicitari pentru achizitie, sa te bucuri de ea si bafta la intocmirea listei, dar mai ales la "infaptuirea" ei!
(http://imageshack.us/a/img28/5210/34563279.jpg)
(http://imageshack.us/a/img14/6321/44482148.jpg)
(http://imageshack.us/a/img10/3848/74456362.jpg)
(http://imageshack.us/a/img542/1830/54647592.jpg)
Cateva poze de sambata ...
Ce seamana cu cateaua mea.... ;D
Putina tinichigerie si ai rezolvat o.Sunt sigur ca e doar de suprafata
Spor
Felicitari. O mare problema la babe este rugina, dar se rezolva. Bafta.
Asa este... si din pacate nu e de suprafata...
Dar cu pasiune si rabdare... se va gasi o solutie...
Ma poate ajuta careva cu o informatie?
Erau niste baieti care vopseau intr-un mod mai "special"... ceva cu o folie si un bazin de apa...
Ceva un link?
Te referi la hidrotransfer?
hidro-transfer pe gugle
http://www.crom-system.ro/hidrotransfer.html
Asta era... Thx again!!!
Pluto si troaca...
(http://imageshack.us/a/img210/8971/amandoua.jpg)
Unde-i Pluto? :D
GC-ul e Pluto !!
Unde-i troaca? ;D
Troaca moare... dar intra la restaurare...
In configuratia actuala priviti fisa dyno...
(http://imageshack.us/a/img268/958/imprezagh.jpg)
Si a murit motorul... :'( :'( :'(... de la primul test... :'( :'( :'(
Cum adica a murit motorul? Dupa atat de multi ani e normal sa nu mai ai toti caii acasa, daca la asta te referi.
nu cred ca se refera la cai.. cred ca l-au fortat cam tare.. si a cedat
2xGhe ai fost cumva pe acolo? :'( Ai dreptate...
Masina a ajuns la tinichigiu... Motorul va ajunge la mecanic pentru estimarea pagubelor.
Oricum ar fi trebuie sa vad partea frumoasa...
Cel putin stim de unde plecam... De la 193cp si o rugina :D ;D
Asa e pe la noi pe la Romanica.. te duci cu masina la testare si pleci cu ea facuta terci, cu airbaguri pocnite de la fire puse aiurea, cu motor spart de la forja sau in cel mai bun caz cu garnitura de chiulasa prajita...
:( Ghinion mare ai. Sper ca asta a fost tot. Bafta in continuare.
Caii îi găsești in lasagna in UK! ;D
Adaptam : Orice motor spart e un pas inainte...
salut , sper ca Pluto sa revina pe scena cat de repede posibil ;)
Bafta
dan
Multumesc mult, dar sunt din ce in ce mai pesimist... :'( :'( :'(
(http://imageshack.us/a/img266/9337/75788706.jpg)
(http://imageshack.us/a/img593/533/97522139.jpg)
(http://imageshack.us/a/img35/4026/19211211.jpg)
(http://imageshack.us/a/img202/7769/36369674.jpg)
(http://imageshack.us/a/img198/45/31886837.jpg)
(http://imageshack.us/a/img521/7676/69645119.jpg)
Holly :o :o :o :o cow!!
e coapta toata ... :( crezi ca mai merita sa bagi bani in ea?! adu-ti o caroserie de afara si faci recarosare ca sa scapi de taxa de mediu ...
OMG....crezi ca pe rugina mai prinde sudura?Alta caroserieeeeeee......
:D :D :D Am uitat de poza asta :
(http://imageshack.us/a/img835/1015/21970097.jpg)
Cea mai tare faza e ca la ultima "interventie" asupra masinii pentru prinderea asa ziselor praguri au fost folosite holsuruburi de rigips... ??? ??? :o :o
Mergi pe varianta lui Claudiu... i-a unua din UK!
In comparatie cu a mea asta e varza. Alta caroserie, nici nu se merita altceva.
Vezi ce mai recuperezi din ea (roti, faruri, stopuri, interior) si trece-o la pierderi.
Asta cred ca a stat citiva ani pe fundull vreunui lac sau in vreo piscina !
... sau parcata pe vreun dig la marea neagra... ;)
Mda... destul de ruginita. Nu trebuie sa mearga pana in UK dupa caroserie, stiu eu un baiat care a tot dezmembrat si are si caroserie fara rugina, mi-a dat mie o gramada de piese si se poate discuta decent cu el :D
nici nu tre sa iesim din casa sa discutam ! doar iesim pe geam/balcon !
NU VA MAI AGITATI ARE DEJA CAROSERIE :D
Gata... m-am relaxat! Thank you Malakay... ::)
Eu inca nu sunt relaxat, dar iau masuri...
(http://images1.wikia.nocookie.net/__cb20120312054957/southpark/images/b/b7/RandyMarsh1601.jpg)
seamana cu dan Bo$$ ;D
Pluto o sa renasca precum pasarea phoenix ;D ;D
Bafta... :P
Cu 2 litri de benzina se curata toata rugina.
Bafta... :P
Sau miracole...
Si mergand pe premiza ca orice virus are mandria lui... Malakay iar ma scoate din "zona maro"...
O sa fie nevoie de multa munca pana sa renasca Pluto... Cumpar masina de facut bani sau ziua sunt la munca si noaptea pe centura??? :'( :D
Vezi ca pe centura am lasat eu un carton ca sa ramana locul uscat in caz ca ploua...cedez spatiu.... ;D
Le
Iar s au dus raq banii de mobila.... ;D
Le
::) :D esti tare rau, numai pe interes esti SEXY !!! :D
Numai sa nu afle nevasta-mea... ;D
asa spunem toti ... :D :D :D
Masina e cheala... URAAAA!!! Cumpar rabdare!!!
(http://imageshack.us/a/img202/2948/74846000.jpg[/IMG[IMG]http://imageshack.us/a/img845/4963/61338123.jpg)
(http://imageshack.us/a/img541/4007/42354974.jpg)
(http://imageshack.us/a/img163/835/28283786.jpg)
Si direct de la PIMP MY RIDE, va prezentam noua transmisie de Subaru ... ;D :D ;D :D
(http://imageshack.us/a/img838/7297/97289044.jpg)
interesanta culoare visiniul asta... ;D ;D
Mi-ar fi placut sa o fac rosie dar imi este lene de alergatura pe la rar, politie, etc...
Inca ne mai gandim la ce tip de albastru sa o facem :
1. albastru - WR Blue mica
2. albastru - sidef
3. albastru - mat
4. deep blue metallic
1 sau 4...care nu stiu cum e ;D
Aceeasi dilema am avut o si eu,plecand tot de la acest visiniu.Si pana la urma a rezultat wrb...
;D ;D ;D poza cu caroseria calare pe o caruta mi-a facut ziua, multumesc pentru asta, te misti repede o sa fie good as new in no time ;D
Acum vreo 6-7 ani nu gaseai o bujie pentru masinile astea.Si acum gasesti di tati.....e bini di tat...
Gasesti "di tati" daca stii unde sa intrebi... ;)
Tare rau poza cu caruta o votez la poza lunii !
My friend , esti criminal cu transmisia Subaru !!!
Spor la treaba !
Si daca imi aduc bine aminte, transmisia era 4WD cu " 4 man power" - 2 trageau si 2 impingeau ;D :D
Malakay, votez si eu pentru poza lunii...
Jucarele noi :
Roll cage OMP cod AB/105P/165
Weight kg: 29
Attachment points: 10
Weight (Kg): 29
Homologation: FIA-ALL J
Note: Fe45 steel multipoint bolt-in roll cage with door bars (must be cut to fit and welded).Main hoop passes through the dashboard.
(http://imageshack.us/a/img854/135/81308080.jpg)
(http://imageshack.us/a/img593/8166/37888883.jpg)
(http://imageshack.us/a/img594/1431/55355387.jpg)
(http://imageshack.us/a/img15/9265/18484932.jpg)
Acum trebuie avut grija la decuparea bordului, tin si la estetica lucrarii...
Cumpar RABDAREEEEEEEEEEE si masina de facut bani :'( :'( :'(
mda pana la urma ai mers pe versiune race nu vers. de strada... grija mare la decuparea bordului !
o sa iasa ceva special ;D 8)
mult succes cu proiectul !!!
cum se comporta Foresterul de cand ai pus BOV?
Vic... Am preferat o versiune omologata FIA. Imi este un pic teama referitor la taiatul bordului. Din pacate, cred ca va fi nevoie si de retapitarea lui dupa decupare. Recomanzi ceva referitor la asta?
rzw75... Mersi mult, sa fie! Din fericire acest proiect se bazeaza foarte mult pe "Malakay's know-how" (aka Subaru Wikipedia) si foarte multa cercetare pe internet.
Referitor la BOV pe Forester : nu am avut nici un fel de problema cu el... :P Si incepe sa ii placa si "nevestimi" (merge cu el zilnic) :P
e bineeee... de abia astept si eu BOV ul... dar e drumul lung din state... :(
proiectul capata forma foarte repede, cand crezi ca masina va fii din nou pe strada? :o :o succes cu ea in continuare
Dupa estimarile mele :'( :'( :'( iulie-august... posibil mai devreme daca ma lovesc "cele 6 norocoase"...
Trag tare sa rezolv coaja, iau o pauza de strans, continuam cu "the power" si "the handling". Problema e ca din aprilie o sa stau mai tot timpul prin Brasov si nu o sa mai am timp sa ma ocup de masina...
poti sa imbraci bordul in piele intoarsa (suede)
(http://i1233.photobucket.com/albums/ff381/maryane86/DSC04126.jpg)
(http://innovativetuningdl.com/images/Voltron/03.12/VoltronDashFlocked.jpg)
(http://imageshack.us/a/img443/3422/photomar02153744.jpg)
(http://imageshack.us/a/img811/9264/photomar02153731.jpg)
Incet... Foarte incet... :'(
Relax! E aproape gata... ::)
Asa??!!
(http://imageshack.us/a/img708/984/photomar02185812.jpg)
Sau asa???!!!!
(http://imageshack.us/a/img248/3295/photomar02185743.jpg)
Asa...
(http://imageshack.us/a/img69/6301/photomar02185639.jpg)
Oare curatul stopurilor intra in categoria DYI???
Urmeaza infolierea - un fumuriu deschis.
OEM!
Ultima varianta!
In prima faza merg pe Oem fumurii...
Ca planuri pt DYI o sa incerc sa le desfac si cromul sa il fac negru. Sunt curios ce o sa iasa :D
Nu pune folie pe stopurile oem!
Sorry ca nu am venit azi pe la garaj dar nu m-am simtit bine si am stat numai in pat !
Ești pus pe treaba rău. Sigur va ieși bine de tot. Spor
Malakay nu-i bai... S-au bucurat fitili lu tata ca am ajuns mai devreme acasa ;D :D
Ket... Daca ajung la 80% din target as fi cel mai fericit pamantean.
HEEEELP !!! Cine ma poate ajuta cu urmatoarele piese? noi sau sh?
Poate cineva sa imi recomande vreun magazin?
(http://imageshack.us/a/img856/5092/suspensiespatemijloc.jpg)
(http://imageshack.us/a/img201/6543/suspensiespate1.jpg)
p.s. In cazul in care este interzisa aceasta postare, imi cer scuze, si rog administratorul sa stearga aceast mesaj.
nu le-ai vaz la mine in garaj :D ??
Vezi ca mai am si eu cate ceva...Daca nu le are Par...desi ma indoiesc..
(http://imageshack.us/a/img836/3139/photomar05225313.jpg)
(http://imageshack.us/a/img708/5172/photomar05225337.jpg)
(http://imageshack.us/a/img29/2610/photomar05225347.jpg)
Si dupa cateva ore de relaxare... Victor m-a invatat cum se de motorul jos... :-*
Cu ranga?
... Si manusi de coafeza ...
am dat jos motorul in aprox 1-1:30 ora max cu o trusa de tubulare de 120 ron din bricostore :D 4 capre si un cric, 2 pereche de manusi de coafeze ! Si 2 magari putere :D sa scoata motorul de pe caroserie ! A fost o seara buna ! 8)
meseriasi domne' ... nu altceva :D 8) ... norocul manusilor cu tubularele de bricostore
Ihhhaaa... B830DNA... Masina e desfacuta dar are numere noi
Iti mai iei una cu ANi si una cu SRI si esti bo$$ de bo$$... ;D
toate masinile lui au DNA la numar individiosule !
Felicitari dani !
Si ce daca.... ;D
IL83DNA
B830DNA
B831DNA
si cele care vor urma tot DNA vor avea ... cocalaru' ;D :D
E prescurtarea de la... doamna? Nu? ::) :D
(http://imageshack.us/a/img109/1521/photomar09170145.jpg)
(http://imageshack.us/a/img805/8686/photomar09170123.jpg)
(http://imageshack.us/a/img18/7010/photomar09170104.jpg)
Ura... In sfarsit caroseria este pregatita pentru curatare...
Si ceva bunatati pentru caroserie :
(http://imageshack.us/a/img41/6752/photomar08192647.jpg)
Spor la treaba. Spune-mi te rog cat a costat masticul? Am vazut ca se poate aplica si la pistol.
Am vazut ca pe piata se vinde intre 175 si 240 ron cutia de 2kg... Eu le-am primit cadou de la un prieten care a cumparat anul trecut 6 cutii sa faca o masina ??? :D :D
Cam asa am vazut si eu. Pana iese masina de la tinichighiu caut si eu cea mai buna protectie. Am gasit o vopsea de pisicina la 150 ron 5kg si as vrea sa stiu daca e mai buna asta.
iti faci piscina?Nu te mai ocupi de masina? ;D
vad ca incerci sa o izolezi cum poti ;D tre sa ii dat de cap si tu la cotet Garcia, nu te bate pe tine rugina.
Dan, abea astept sa ajung in tara sa vad proiectul pas cu pas, il urmaresc cu mare interes mai ales ca stiu ambele masini (donatoru de motor si pe cel de caroserie), astept sa le vad contopite ;D ;D
Garcia : Ai grija cu vopseaua de piscina ca e posibil sa nu iti reziste la socuri mecanice : pietricele... etc...
O sambata frumoasa cu multa munca si multa chinuiala la scos de suruburi... Las pozele sa vorbeasca...
(http://imageshack.us/a/img855/2623/58934637.jpg)
(http://imageshack.us/a/img402/1853/72555750.jpg)
(http://imageshack.us/a/img842/6007/65830647.jpg)
(http://imageshack.us/a/img713/1125/47936459.jpg)
(http://imageshack.us/a/img266/4767/33220208.jpg)
(http://imageshack.us/a/img708/9721/20992119.jpg)
Caroserie spalata...
(http://imageshack.us/a/img838/6986/49897653.jpg)
Intrebare : e normal sa difere hub-urile intre ele?
Dreapta
(http://imageshack.us/a/img254/4610/hubfatadreapta.jpg)
Stanga
(http://imageshack.us/a/img213/7358/hubfatastanga.jpg)
eu zic ca nu e normal, dar cu istoricul masinii, fiind masina de antrenament cine stie cati donatori a mai avut pt diverse...
nu e mare stres unu e cu abs si unul este fara ....
Incepem sa avem spor... La distrus bineinteles :D ;D
(http://imageshack.us/a/img18/9276/76151168.jpg)
(http://imageshack.us/a/img834/6817/11764882.jpg)
(http://imageshack.us/a/img824/9899/99733879.jpg)
(http://imageshack.us/a/img715/1693/44374430.jpg)
(http://imageshack.us/a/img199/4859/85047597.jpg)
(http://imageshack.us/a/img713/6701/95918488.jpg)
(http://imageshack.us/a/img835/9699/90762956.jpg)
Cum ar zice Tom, "ce ruina" :'( a ramas din kdr
URAAAAA .... a venit Roll Cage-ul...
(http://imageshack.us/a/img855/323/img1402hj.jpg)
Aseara de plictiseala m-am apucat sa curat de rugina elementele suspensiei si sa le vopsesc...
(http://imageshack.us/a/img5/161/img1401tv.jpg)
Frumos, e bine ca te-ai pus pe treaba. Vezi ca ti-am adus tricoul, e la Victor la magazin.
Mersi mult Claudiu...
Din pacate nu am timp suficient sa fac tot ce imi propun. Sper ca maine sa montez "cusca" si sa ii faca si o vopsea interioara...
Tinand cont de faptul ca e prefabricat ar trebui sa mearga repede montajul lui.
Si pe langa asta sa duc si motorul si transmisia la mecanic.
Albesc pe zi ce trece... :'( :'( :'(
Haha treaba de pensionari ! Rabdare si rabdare si iese racheta !
Si a mai trecut o saptamana...plina de activitate...
Reconditionate intr-o incapere cu o inaltime maxima de 1.5m :
(http://imageshack.us/a/img255/7237/photomar30151622.jpg)
(http://imageshack.us/a/img201/4371/photomar30151643.jpg)
Iar la garaj "s-a muncit" pe rupte :
(http://imageshack.us/a/img407/7375/photomar30151703.jpg)
(http://imageshack.us/a/img191/5537/photomar30151716.jpg)
Puntea spate veche :
(http://imageshack.us/a/img818/2949/photomar30155432.jpg)
Puntea spate actuala :
(http://imageshack.us/a/img90/9393/photomar30155447.jpg)
1. In cautare de : punte fata (cea veche este fisurata in doua locuri), brate fata, fuzete fata, fuzete spate
(http://imageshack.us/a/img507/4715/photomar30152506.jpg)
(http://imageshack.us/a/img248/6259/photomar30152511.jpg)
(http://imageshack.us/a/img507/421/photomar30152712.jpg)
Ce sunt astea si unde gasesc unele noi ?
(http://imageshack.us/a/img19/4362/photomar30152301.jpg)
La cofetarie :)) zici ca sunt tarte :D. Stai ca sar baietii acum si te lamuresc 8)
gasim in cutia cu maimute !
Punte fata gasita in cutia cu maimute... Vecinu de langa casa niciodata nu te lasa... Multumesc din nou domnului Malakay
Eu zic sa-ti dea si bani ca-i faci curat. Bafta!
Adica ?
Dezordinea ordonata ne caracterizeaza pe amandoi... ;D
Geniile traiesc in haos!
Super...deci si eu sunt un geniu? ::) :P
Tu esti cel mai mare GENIU !!!
99% transpiratie 1% inspiratie....
(http://imageshack.us/a/img853/5669/photoapr06122413.jpg)
(http://imageshack.us/a/img571/7851/photoapr06111211.jpg)
(http://imageshack.us/a/img138/2688/photoapr06111112.jpg)
(http://imageshack.us/a/img706/4083/photoapr06111015.jpg)
Pus la misto...
wiechers?
Omp.
bun frumos
In sfarsit "se lucreaza" la caroserie :
- antifonata
(http://imageshack.us/a/img818/6796/photoapr10192721.jpg)
Si cum nu imi placea sa o vad neagra pe dedesupt si daca tot am avut ocazia sa "produc" niste vopsea, in seara asta AM (eu) vopsit podeaua cu un albastru destul de dragutz :
(http://imageshack.us/a/img69/8805/photoapr10203632.jpg)
(http://imageshack.us/a/img844/3663/photoapr10203641.jpg)
(http://imageshack.us/a/img197/3708/photoapr10210356.jpg)
(http://imageshack.us/a/img132/5637/photoapr10210407.jpg)
Sper ca maine seara sa incep sa montez articulatia pe spate...
p.s. Am printat deja schita de montaj ;D
Incepe sa prinda contur... bafta!
Sper sa fie... Din pacate e nevoie de multa munca de convingere sa pui oamenii la treaba.
nu o sa aiba moarte babeta la cat antifon mananca ;D e un proiect pe cinste facut cu mult calm si cu mult cap. bafta in continuare ;D
Uite pentru inspiratie: http://forums.nasioc.com/forums/showthread.php?t=2422995
Heeeeelp!!! Caut suspensie de gc... Preferabil sh!
Un scurt up-date...
(http://imageshack.us/a/img822/6418/43137491.jpg)
(http://imageshack.us/a/img11/2061/79601430.jpg)
(http://imageshack.us/a/img713/6343/28336612.jpg)
(http://imageshack.us/a/img24/2139/25136606.jpg)
(http://imageshack.us/a/img507/4522/78332959.jpg)
(http://imageshack.us/a/img109/1016/82601321.jpg)
(http://imageshack.us/a/img845/1889/52616428.jpg)
Din pacate ne-am blocat din nou, datorita suspensiei spate. Incercam montarea unei suspensii de WRX break, prin modificarea pozitiei suruburilor flanselor.
Sper sa mearga...
Pana acum arata super! Spor sa ai...
Merge...amortizorul e acelasi.Daca vrei iti dau eu flanse.Sunt noi noute...Ar trebui sa mearga daca arcul nu e conic in partea de sus.
din ce am reusit sa vb cu dani aseara la 2 .... arcul de gd e mai mare decat flansa de gc ...
Arata bine. O sa iasa ţipla masina :)
Cel mai sexi rezervor :D ;D
(http://imageshack.us/a/img94/3929/59237226.jpg)
(http://imageshack.us/a/img507/171/33302080.jpg)
(http://imageshack.us/a/img9/209/49798095.jpg)
(http://imageshack.us/a/img209/1108/64936352.jpg)
(http://imageshack.us/a/img407/8981/67073254.jpg)
Si acum vestile proaste. Cam asa arata GC-ul cu suspensie de GD...
(http://imageshack.us/a/img594/6205/76633334.jpg)
(http://imageshack.us/a/img843/9969/70554651.jpg)
Datorita diametrului arcului si a talerului inferior, acestea stau lipite pe tabla... >:( :'( ... Cu suspensia asta cred ca ar face fata unui safari...
Gasesc pe la cineva vreo suspensie de GC, sh???
daniel....am eu amortizoare si arcuri de gc....dar cred ca sunt stock....chestia este ca pe 3-4 mai vin in Ro.Dacs te intereseaza iti trimit poze si dimensiuni.
iti pot da si eu daca doresti, cand imi pun suspensia reglabila.
termini inaintea mea ... in stilul asta ! bravo felicitari !
un proiect mare....pentru o drsgoste de "babeta" , spor la treaba si sa o vedem pe sosea langa Malakay
frumos proiect multa bafta in continuare
Un proiect mare si frumos... Cu foarte multa munca tip DIY, mai ales atunci cand ai parte de "low budget"...
Victor nu am nici cea mai mica sansa de a o termina inaintea ta... Inca mai caut multe piese (aparatori de cardan, de evacuare... bla bla bla) : trebuie sa ma bag pe sub masina ta sa vad ce piese imi mai lipsesc. O folosesc pe a ta drept exemplu. :D :D :D
Naiman : nu pot afirma ca ar fi "dragoste de babeta"... Victor "the virus" mi-a insuflat din "pasiunea" lui pentru Subaru... Sentimentele pentru aceasta masina au inceput sa apara in momentul in care am inceput sa lucrez EU (fizic) la ea... La finalul proiectului, dupa prima plimbare cu Pluto o sa postez "lista de cheltuieli" : bani/timp.
Multumesc tuturor pentru sustinere...
In sfarsit am mai prins ceva timp si pentru masina.
Si la sfatul lui Celalalt am dat o pata de culoare masinii:
(http://imageshack.us/a/img716/3310/photomai03225909.jpg)
(http://imageshack.us/a/img853/7492/photomai03222158.jpg)
(http://imageshack.us/a/img22/1017/photomai03214107.jpg)
Si daca Malakay a spus ca basculele de aluminiu sunt cele mai bune, a trebuit sa ne luam si noi:
(http://imageshack.us/a/img833/7567/photomai03193346.jpg)
Acum sunt in cautare de ansamblu stergatoare... Gasesc pe undeva?
Si din categoria DIY :
(http://imageshack.us/a/img854/7698/photomai03230423.jpg)
(http://imageshack.us/a/img689/2829/photomai07220911.jpg)
Maxim respect pentru tot cea ce faci la aceasta masina.
+1
Am vazut XT-ul ieri si e belea. Dacă iese si GC-ul asa, va fi belea. Si probabil va ieși chiar mai bine...
Sa speram ca avem rabdare sa o ducem pana la capat...
Si din categoria "bunataturi":
1. Direct de la "the virus"
(http://imageshack.us/a/img163/9089/photomai04113326.jpg)
2. Suspensie BC coilovers de GD. Sper sa am timp sa o vopsesc (arcurile si suportii - galbeni).
(http://imageshack.us/a/img441/7329/photomai08200048.jpg)
Respect "the virus"!!!
Astept pareri dupa ce montezi suspensia
Incet, incetisor, tango... Asa se misca lucrurile in tara asta...
Dupa 6 ore de stat la garaj am reusit sa montez rezervorul, puntea fata, bratele, fuzetele si amortizoarele pe fata :
(http://imageshack.us/a/img96/8343/photomai18184731.jpg)
Credeti ca pot gasi pe undeva toate suruburile de GC? Noi-noute???
Aveti idee cu ce as putea inlocui mocheta?
Cu un covor persan :)) Iti arat ce am pus eu la GC Dani, e un buretel ignifug foarte tare;)
Suruburi pe ebay sau Rocast
Suruburi mai poti gasi si la Fabory. Ce bine arata suspensia.
Categoria bunataturi continua cu :
(http://imageshack.us/a/img822/7010/87484931.jpg)
In sfarsit "fiarele" sunt montate :
(http://imageshack.us/a/img844/4263/10132352.jpg)
(http://imageshack.us/a/img836/5894/10335682.jpg)
Usile vopsite pe interior :
(http://imageshack.us/a/img62/4443/13082365.jpg)
Gaura antena astupata :
(http://imageshack.us/a/img24/6685/95652505.jpg)
Ce sunt astea? Anti-lift kit?
pivotii si capetele de bara de directie...
Un singur lucru ma nedumereste. Ce animal este prins pe perete, in poza 3 ? :)
woow cat de tare! felicitari , usor usor incepe sa prinda contur !
o vulpe ;D
Pluto si vulpea...
Azi am trecut pe la garaj si am ramas uimit!
Status :
(http://imageshack.us/a/img259/6531/photoiun07201619.jpg)
(http://imageshack.us/a/img694/7169/photoiun07191252.jpg)
(http://imageshack.us/a/img547/3931/photoiun07224420.jpg)
Citare de la a mea sotie : "parca arata a masina"
Cea mai buna varianta de a vopsi masina, este pe componente ( parerea mea). Sport la treaba.
O sa iasa ceva frumos :D
Incepe sa prinda forma, succes in continuare !!!
cum arata cu roll cage :D pfff
felicitari dani si spor la treaba !
Cred ca va fi cea mai vopsita si mai curata si mai protejata caroserie cand o sa fie gata. Spor!
Frumos de tot!
Cam pe cand crezi ca va iesi pe strada? ::)
Multumesc tuturor...
Varianta nacked cred ca va fi pe strada prin august...
Abea astept :D
Si eu vecine...
Vazand-o pe a ta in fata blocului parca am ceva mai mult optimism si chef de munca...
Cu rabdare... motorul a fost desfacut? in ce stadiu e? ??? ;D
In acelasi stadiu : agatat de o capra si sprijinit pe 2 anvelope
(http://imageshack.us/a/img834/33/photoapr09194512.jpg)
Dar deja ma gandesc la interne, la o turbina mai mare, serpisori si evacuare...
Ceva sfaturi de la maestrii???
Proaspete :
(http://imageshack.us/a/img845/1072/photoiun09171235.jpg)
(http://imageshack.us/a/img534/2648/photoiun09171333.jpg)
Si avem si pata de culoare ceruta de Celalalt :
(http://imageshack.us/a/img705/3713/photoiun09171819.jpg)
(http://imageshack.us/a/img32/9057/photoiun09171838.jpg)
(http://imageshack.us/a/img849/7863/photoiun09180037.jpg)
De altfel si sigurantele de capota sunt rosii :
(http://imageshack.us/a/img694/5087/photoiun09171447.jpg)
mama mama ce racheta o sa iasa pe strazi! :D
f frumos, multa bafta in continuare cu proiectul
interesanta capota ... mergi pe burta cu faceliftu :D
Low profile... Face parte din celebra caregorie : "don't tell to your wife"
Ai fost al doilea care a observat capota... :D
Si mai sunt cateva surprize... Dar toate la timpul lor ;D
Vivere Malakay!!!
(http://imageshack.us/a/img153/1626/photoiun12191824.jpg)
(http://imageshack.us/a/img27/6702/photoiun12192015.jpg)
Si se lucreaza...se lucreaza...
(http://imageshack.us/a/img526/3783/0h82.jpg)
(http://imageshack.us/a/img844/7402/cpkx.jpg)
Proaspat venite :
Bielete antiruliu CDF Racing (fff usoare dotate cu bucsi poliuretanice)
(http://imageshack.us/a/img90/4141/uvq.jpg)
Bucsi articulatii spate Powerflex :
PFR69-122BLK, PFR69-117,115,118BLK,122BLK,111BLK,110BLK
(http://imageshack.us/a/img547/211/x81.jpg)
Si acum vestile proaste : ieri am inceput desfacerea motorului.
Prima concluzie : turbina trebuie reconditionata sau inlocuita datorita unui joc al axului destul de mare.
Parerea mea : ma gandesc la inlocuirea ei cu un TD05 16G Big :
"•The turbo is rated up to 400 bhp.
•Water and Oil cooled
•Direct swap for TD04L turbo
•Adjustable boost control
•TD: 49.1mm/55.8mm
•CFM: 580@0.8 Bar
•CW: 48.3mm/68mm"
Ce parere aveti? Credeti ca internele stock rezista la 300CP sau va trebui sa iau interne forjate?
despre turbo cred c ai vazut pe ebay pe la 269-299 lire ... ai grija alea sunt made in china all day long .... la bani aia .... bagate la un new age turbo VF34-35-43.
Cat despre motor tot al desfaci deci baga ceva un stroker kit decent .... sau un block de STI new age
Bafta
Ai experientele baiatului de vis-a-vis, invata din ele :D Daca vrei doar 300 de cai, nu cred ca ai motive de ingrijorare cu internele stock! Cat despre turbo, e cu dus-intors.. ori iti iei turbina de newage si faci o adaptare la turbina ori fortezi un 16G care vine la fix.
Impreza01, din pacate nu am bani de stroker kit. O sa incerc sa ma multumesc cu interne stoc (am si posibilitate sa le iau la un pret bun).
Claudiu... Baiatul de vis a vis e cel mai bun exemplu pentru mine!!! Cred ca voi ramane la un TD05, serpisori si evacuare pe 3" fara catalizator, un soft... Si cam atat.
Roll bar finalizat si dat jos pentru a fi vopsit
(http://imageshack.us/a/img580/1461/8um9.jpg)
(http://imageshack.us/a/img690/6655/l6kc.jpg)
La "dulcegarii" s-au adaugat : radiator racing aluminiu 42mm core, pompa benzina walbro 255
Salut
Tu faci masina asta de competitii, nu ?
Pentru ca daca o vei folosi ca masina de strada, rollbarul iti va face mai mult rau (in caz de accident sau chiar miscari bruste, barele alea o sa te loveasca in loc de a te proteja si problema este capul unde pe strada nu ai casca......)
In orice caz bafta in continuare.
Seara buna
Masina va fi folosita foarte rar pe strada... Dupa configurarea stalpilor nu prea imi dau seama cum ar putea sa loveasca soferul sau pasagerul...
(http://imageshack.us/a/img163/1010/9cul.jpg)
(http://imageshack.us/a/img24/8769/fgcg.jpg)
(http://imageshack.us/a/img89/2934/3286.jpg)
felicitari ! prinde forme... ;D
Incet... Incet... Pe unii ii doare in...
(http://imageshack.us/a/img198/7636/ijd2.jpg)
(http://imageshack.us/a/img10/9949/fsnf.jpg)
(http://imageshack.us/a/img189/5409/9tmf.jpg)
(http://imageshack.us/a/img153/1008/6dty.jpg)
(http://imageshack.us/a/img841/9508/dx4j.jpg)
(http://imageshack.us/a/img33/976/2sf4.jpg)
Maine se va revopsi interiorul si vor intra la vopsit toate celelalte...
Very Nice ;)
O sa iasa ceva super! Spor la treaba Daniel! ;)
O sa iasa ceva frumos....anul asta? ;D
woooow felicitari ce taree a iesit !
Superb! Pai era si cazul sa pastram numarul de GC-uri frumos aranjate dupa ce a plecat a lui 2xGhe
Multumesc tuturor... Sper ca anul asta... Facem tot posibilul.
Culoarea este : blue egee de la Klar ;D
Partea grea o sa inceapa in curand... Montarea pieselor = un puzzle destul de greu
cu motorul ce ai facut ? te ai apucat de el
La momentul de fata motorul e subiect tabu! E desfacut, nu e de bine... Inca o gandim! Dar cum cele mai bune vin la o partida de pescuit...bineinteles in compania lui Malakay (asta cand nu prinde peste)...
Azi a sosit prima piesa de schimb la motor ;D ;D de mai mult nu am avut buget...
(http://imageshack.us/a/img35/3483/2ygh.jpg)
:D e un pas inainte asta conteaza ;)
:D buna asta !
Busonul de ulei?Tare...
Incepe sa prinda culoare...
(http://imageshack.us/a/img543/3170/1kq6.jpg)
(http://imageshack.us/a/img856/8372/iupz.jpg)
(http://imageshack.us/a/img829/3802/uywm.jpg)
(http://imageshack.us/a/img703/4299/hxh7.jpg)
(http://imageshack.us/a/img545/8501/la05.jpg)
(http://imageshack.us/a/img593/7562/9hyl.jpg)
(http://imageshack.us/a/img46/926/bv1k.jpg)
Abia astept sa o vad gata. Spor la treaba si nervi de otel!
Si eu Mihai... Dar mai e mult pana atunci :'(
Suruburi, piulite si ceva rosu pe sub capota motor... Proaspat venite...
(http://imageshack.us/a/img546/9641/58jz.jpg)
De maine seara (daca ne permite cheful si oboseala) incepem montajul (la ce ne pricepem)
Frumos, spor la treaba in continuare.
Dupa unele mici finisaje suportul de ceasuri a intrat perfect la locul lui ...
(http://imageshack.us/a/img20/9014/m4u7.jpg)
Bordul a plecat la retapitare... Din fata catre luneta : piele, alcantara, piele (negru si cusatura albastra)
Si a inceput montajul ;D ;D ;D
(http://imageshack.us/a/img843/7066/kvln.jpg)
Unde gasesc si eu nishte "bulbi" d-astia ???
(http://imageshack.us/a/img23/9052/wusd.jpg)
Parca am vazut la Hornbach...
Din cand in cand mai si muncim la masina...
(http://imageshack.us/a/img153/7202/z5hk.jpg)
(http://imageshack.us/a/img836/6831/6ljj.jpg)
Geam polisat si becuri schimbate...
(http://imageshack.us/a/img825/2548/mvx7.jpg)
(http://imageshack.us/a/img849/2018/l29c.jpg)
http://imageshack.us/photo/my-images/809/2flq.jpg
Foarte frumos a iesit ;D ;D ;D Felicitari Dani. Poate ma iei si pe mine la garaj sa o vad Live ca nu mai am rabdare pana vii cu ea acasa 8)
Ceva nu e ok la ultima poza. Am incercat sa repar, dar nu e bun link-ul se pare
Mergea doar copiat link'ul si pus intr'un browser, direct am incercat si eu sa postez poza si nu a vrut. Oricum, f tare acest proiect si sunt tare curios cum va iesi la final. De costuri nu intreb, ca probabil e mai bine ptr toti asa :D
Bo$$-admin mersi mult de ajutor...dar Androidul nu se impaca cu mine...
Mihaita eu merg la garaj aproape seara de seara. As vrea sa o inchid saptamana asta.
A fost un weekend plin!!!
(http://imageshack.us/a/img839/2089/q948.jpg)
(http://imageshack.us/a/img829/6664/ge5t.jpg)
(http://imageshack.us/a/img593/8382/bkkk.jpg)
(http://imageshack.us/a/img687/6695/cdzu.jpg)
(http://imageshack.us/a/img14/8164/urg4.jpg)
(http://imageshack.us/a/img46/5075/i098.jpg)
(http://imageshack.us/a/img203/605/2aqt.jpg)
(http://imageshack.us/a/img543/4879/l291.jpg)
(http://imageshack.us/a/img46/8643/957b.jpg)
Ce bine iese!
Cu motorul ce ai mai facut?
Oglinda aia care atarna zici ca e Zacks.Stiti filmuletul ala de la bulgari....din 44 sau 62...inainte de revolutie.Cu Benji Zacks izvesniens print....;D
Foarte tare! Abia astept sa o vad finalizata.
Ket... Ultima idee e : un bloc din familie, chiuloasele mele, turbo si evacuare twinscrooll... Ramane de cercetat...
Celalalt... Noi astia mai tineri stim doar de hentai... ;D
Mihai... Finalul e pe aproape...Speranta moare ultima :D ;D
Eleron montat...
(http://imageshack.com/a/img15/9836/x1us.jpg) (http://imageshack.com/i/0fx1usj)Uploaded with ImageShack.com (http://imageshack.com)
(http://imageshack.com/a/img163/355/icoa.jpg) (http://imageshack.com/i/4jicoaj)Uploaded with ImageShack.com (http://imageshack.com)
Inceput de izolatie...
(http://imageshack.com/a/img853/3734/r2bs.jpg) (http://imageshack.com/i/npr2bsj)Uploaded with ImageShack.com (http://imageshack.com)
Proaspat venite ... amortizoare capota si "chestii" prindere evacuare...
(http://imageshack.com/a/img42/4752/tkav.jpg) (http://imageshack.com/i/16tkavj)Uploaded with ImageShack.com (http://imageshack.com)
Te apropii de final.
Iese bine de tot.
Cand iese pe strada?
@Ket ... habar nu am cand o sa fie gata. tot ce stiu este ca sunt pornit sa o termin cat mai repede. nu mai am rabdare... :'(
Si intre timp ceva bunatati tinute ascunse (stim motivele cu totii ;D) :
(http://imageshack.com/a/img194/3998/u54g.jpg) (http://imageshack.com/i/5eu54gj)Uploaded with ImageShack.com (http://imageshack.com)
(http://imageshack.com/a/img706/2531/ipxy.jpg) (http://imageshack.com/i/jmipxyj)Uploaded with ImageShack.com (http://imageshack.com)
Sa moara jakie chean ::) o sa fie nebunie!
Clau, mersi mult... speram...speram... speranta moare ultima...
Daniel, ce speri tu?!
Este evident ca o sa fie belea masina!
Bravo, felicitari!
Am avut ocazia sa vad proiectul LIVE si am ramas fara cuvinte... atata atentie la detalii nu am vazut in viata mea, din punctul meu de vedere Dani trebuia sa se faca chirurg.... (sa iei fiecare surub in parte sa il cureti individual mi se pare devotament si pasiune la extrem)
Bafta in continuare ;D ;D ;D
Daca o termini pana la intalnirea de 4 ani si vii si tu e clar unde se duce premiul pentru cea mai buna restaurare :D
Tot la mine ca va sparg...;D ;D ;D
Mihai cand e intalnirea de 4 ani? Sa stiu daca ii las premiul lui Celalalt in schimbul unui discount ;D
Mihaita atentia la detalii e defect profesional....multi ma injura
Ianuarie. Ai timp :D
Multi te injura si mai multi te invidiaza 8)
Ieri am primit dezlegare sa fug cateva ore pana la garaj. Rezultatul :
- izolatie plafon finalizata
(http://imageshack.com/a/img28/7011/nlfl.jpg) (http://imageshack.com/i/0snlflj)Uploaded with ImageShack.com (http://imageshack.com)
- capota echipata
(http://imageshack.com/a/img850/5668/r88g.jpg) (http://imageshack.com/i/nmr88gj)Uploaded with ImageShack.com (http://imageshack.com)
- suruburi vopsite
(http://imageshack.com/a/img837/8116/z97p.jpg) (http://imageshack.com/i/n9z97pj)Uploaded with ImageShack.com (http://imageshack.com)
si multe alte piese curatate...
Si s-a mai lucrat un pic la masina :
Usi spate montate...
(http://imageshack.us/a/img541/8320/wbwe.jpg)
(http://imageshack.us/a/img41/4686/t1ci.jpg)
Plastic vopsit...
(http://imageshack.us/a/img196/5088/88op.jpg)
O alta zi cu putina munca la masina... noroc ca m-a expediat nevasta de acasa...
(http://imageshack.us/a/img560/1098/z3mv.jpg)
(http://imageshack.us/a/img703/6322/7yid.jpg)
(http://imageshack.us/a/img818/6383/hc4s.jpg)
(http://imageshack.us/a/img14/2642/6nnu.jpg)
(http://imageshack.us/a/img819/6881/e9sp.jpg)
In cautare de cleme ...
(http://imageshack.us/a/img835/1460/3vah.jpg)
(http://imageshack.us/a/img404/2990/5z2x.jpg)
"Balama" torpodeu (inainte si dupa):
(http://imageshack.us/a/img14/4683/isrw.jpg)
(http://imageshack.us/a/img812/9497/raal.jpg)
O mica problema... Gasesc pe undeva ???
(http://imageshack.us/a/img822/586/u8ey.jpg)
Alte piese gasite si plecate la imbracat :
(http://imageshack.us/a/img706/8817/u0zv.jpg)
tot vecinu de langa casa s-ar putea sa aiba consola centrala :o
Stiu... Am zis ca ne luam castile de mineri si ne bagam in cutia de maimute sa sapam...
PANDORA'S box ;D ;D ;D avem ditatii...
unde nu gasiti apelati si la mine ;)
Esti de admirat.
Faci totul foarte incet si bine.
Mai dam un search si pe la.mine. daca mai trebuie ceva...
Slabut weekend-ul asta... lipsa chef...
(http://imageshack.com/a/img194/3558/w1yf.jpg) (http://imageshack.com/i/5ew1yfj/)Uploaded with ImageShack.com (http://imageshack.com)
(http://imageshack.com/a/img546/3771/y2pf.jpg) (http://imageshack.com/i/f6y2pfj/)Uploaded with ImageShack.com (http://imageshack.com)
Si daca tot avem plafon negru...am zis sa ne mai jucam un pic si cu spray-ul cu vopsea..
(http://imageshack.com/a/img543/68/2wfj.jpg) (http://imageshack.com/i/f32wfjj/)Uploaded with ImageShack.com (http://imageshack.com)(http://imageshack.com/a/img35/884/rf2t.jpg) (http://imageshack.com/i/0zrf2tj/)Uploaded with ImageShack.com (http://imageshack.com)
(http://imageshack.com/a/img209/7789/5d28.jpg) (http://imageshack.com/i/5t5d28j/)Uploaded with ImageShack.com (http://imageshack.com)
Aseara am trecut pe la garaj... viteza de lucru specifica romaniei...
(http://imageshack.com/a/img822/4377/2wd4.jpg) (http://imageshack.com/i/mu2wd4j/)
(http://imageshack.com/a/img822/5918/zzhn.jpg) (http://imageshack.com/i/muzzhnj/)
(http://imageshack.com/a/img580/9950/v7vm.jpg) (http://imageshack.com/i/g4v7vmj/)
Iar acasa...
(http://imageshack.com/a/img11/9693/5vi2.jpg) (http://imageshack.com/i/0b5vi2j/)
Super treaba ce faci cu masina, bafta la build...
Esti de admirat.
mersi mult... lucrul cel mai bun la 9 luni iese, nu?
daca ar face incet si prost atunci chiar m-as duce cu capul...
:D DE MAINE SE DESCHIDE MUZEU IMPREZA GC DE PE STR VIITORULUI !!! SA O STAPANESTI SANATOS ! 4 GC PE O STRADA E CEVA :D
Mersi mult Victor... Sper sa merite. Ma bucur ca motorul merge frumos...
Era cea mai rapida metoda de a face rost de un motor.
Sper ca in max. 2-3 sapt. sa ies cu Pluto pe strada.
Mai multe detalii maine dupa o analiza mai completa...
Felicitari!
Ce motor are donatorul?
well done mai ales ca motorul merge si poate este chiar close deck ;)
Sper sa fi luat-o si la pret bun ;)
v1-2 gc sti
Cateva poze facute dimineata la prima ora :
(http://imageshack.com/a/img708/4767/t72y.jpg) (http://imageshack.com/i/jot72yj/)
(http://imageshack.com/a/img407/5764/9llx.jpg) (http://imageshack.com/i/bb9llxj/)
(http://imageshack.com/a/img18/3103/1qgj.jpg) (http://imageshack.com/i/0i1qgjj/)
(http://imageshack.com/a/img594/544/wh6y.jpg) (http://imageshack.com/i/giwh6yj/)
Motor, transmisie, stopuri si eleron se muta pe Pluto... Restul se marita...
Sper in aceasta seara sa fac cateva poze mai in detaliu...
Ma abonez la jante frane fata si esapament....
Aglomeratie de Subi pe metru patrat. Zona are SUBARUMAGNET ;)
Felicitari, o sa dau si eu o fuga azi sa o vad :o :o :o
si eu de abia astept sa termin munca pe ziua de azi.... :D
Victor este "contagios"! 8)
bv Dani, imi faceti pofta de un nou GC :))
Cu tine nu mai vb ma tadatorule ....
am vazut masina azi... arata bine se aude bine... Dani a dat termen 2-3 saptamani pana cand va iesii cu Pluto pe strada.
;D ;D ;D deci 21 de zile maxim ;D ;D ;D
and counting ;D no pressure....
Multumesc mult tuturor...fiecare persoana de aici are un anumit aport in reinvierea lui Pluto...
Masina donatoare a fost achizitionata pentru faptul ca am ramas pe ultima suta de metrii cu rabdarea si ca varianta de compromis pentru un motor bun intr-un timp scurt, urmand ca motorul spart sa il fac, asa cum imi doresc, in urmatoarele luni.
Dupa masina donatoare voi pastra/muta pe Pluto in urmatoarele zile :
- motor, admisie Apexi, evacuare Toyo, cutie, planetare, diff, suspensie Tein, stopuri si alte cateva plastice/chedere.
Azi am avut 5 min. sa trec pe la garaj sa urgentez un pic treburile :
Rezultat : parbriz si luneta montate
(http://imageshack.us/a/img266/7922/03vx.jpg)
(http://imageshack.us/a/img268/3905/ujom.jpg)
(http://imageshack.us/a/img845/3730/l69j.jpg)
Din categoria cadouri :
(http://imageshack.us/a/img836/953/syie.jpg)
Si din categoria surprize : toate suruburile de sub masina-spate noi-noute
(http://imageshack.us/a/img197/7375/t83l.jpg)
haha de unde ai furat suruburile alea :D super tare felicitari :D asteptam swap-ul ...
p.s pune video si cu evacuarea...
Dc nu ai pus luneta de Japonia cu stergator? ???
Cheia face toti banii
Mihaita : Parerea mea : stergator pe spate da bine doar la break/suv/jeep
Si cred ca am uitat sa fac public asta :
(http://imageshack.us/a/img29/9677/i6gp.jpg)
cand o sa vada garcea poza cu suruburile o sa ii iasa ochii din cap ca la melc :D ;D
;D ii tinem noi ochii sa nu ii fuga de pe orbite.
Filmuletul cu evacuarea :
http://youtu.be/XnmNTA0eJeo
Aur curat, in pungutele alea ;D, sa pastrezi codurile de la suruburi.
Garcia am sa le pastrez... si am uitat sa mentionez ca acolo sunt si bucsi bara stabilizatoare spate si bucsi punte spate - caroserie...
Tot respectul pentru migala si rabdare. Daca as avea si eu un garaj bine dotat sau bani sa tin masina in garajul altora as face exact ce faci si tu.
Da-mi un mp cu detalii despre unde ai vopsit masina si sa imi spui daca ai fost multumit etc.
@Mihai... "Service-ul" asta sta foarte prost la capitolul dotari. Am fost nevoit sa imi cumpar scule care le voi folosi cred ca de 3 ori in viata :'( : prese de bucsi, de pivoti, de arcuri... etc... Iar calitatea e discutabila : cat dai atata face. Daca am invatat sa folosesc pistolul de vopsit. :o ???
Singurul avantaj (creat datorita delasarii lor) a fost acela ca am avut unde sa tin masina si sa buchisesc la ea in liniste. Ba nu am avut timp, ba nu aveam bani.
Pentru cei interesati :
(http://imageshack.com/a/img43/1504/crrc.jpg) (http://imageshack.com/i/17crrcj/)
PART CODE PART NAME Q ' TY
20540AA080 BOLT B-TRANSVERSE LINK 2
012512400 BOLT AND WASHER ASSEMBLY 6
902350006 SELF LOCKING NUT 8
20520AA030 BRACKET-TRAILING ARM , RIGHT 1
20520AA040 BRACKET-TRAILING ARM , LEFT 1
20270AA080 TRALING ARM-REAR 2
901000109 FLANGE BOLT 2
20271AA010 BUSHING-TRAILING LINK-REAR 2
20250AC180 LATERAL LINK ASSEMBLY-FRONT 2
20550AA010 NUT-SELF LOCK 6
900335056 WASHER 4
20255AA330(331) LATERAL LINK ASSEMBLY-REAR , LEFT 1
"20255AA320
20250FE380" LATERAL LINK ASSEMBLY-REAR , RIGHT 1
023510000 SELF LOCKING NUT 4
016710553 BOLT 2
900335056 WASHER 4
20540AA000(001) BOLT-LATERAL LINK,OUTER 2
901250054 BOLT & WASHER ASSEMBLY 4
20175AA010 STOPPER-REAR CROSS MEMBER 4
901000110 FLANGE BOLT 2
20560AA000 WASHER CAM-REAR 2
20530AA020 CAP-LATERAL LINK 2
20560AA030 WASHER - LATERAL LINK 2
901000111 FLANGE BOLT 4
20540AA111 BOLT CAM-REAR 2
20560AA011 WASHER - TOE ADJUST 2
20151FA111 CROSS MEMBER COMPLETE-REAR SUSPENSION 1
012308250 BOLT AND WASHER ASSEMBLY 6
20520FA000 BRACKET - STABILIZER , RIGHT 1
20520FA010 BRACKET - STABILIZER , LEFT 1
"28052AA031
28469FE000" HUB - REAR AXLE 2
"28016AA020
28016AA020NT
28016AA030" BEARING - REAR AXLE 2
26750AA014 TONE WHEEL-REAR 2
Un mic cadou...
(http://imageshack.us/scaled/landing/801/qtnb.jpg)
Trimite mi modificarile la mobila...stau cu.proiectul netermimat. ;D
Si iar se duse draqu banii de mobila... ;D
In ce stadiu e Pluto. O vedem pe strada in Octombrie sau nu? :o :o :o :o
Mihaita... eu asa sper... am fost un pic dat peste cap de niste neprevazute si nu am mai avut timp de masina
Oricum mai astept cateva piese foarte importante... ;D
Si totusi cateva poze facute ieri : ;D Multumesc mult Malakay ;D
(http://imageshack.com/a/img51/744/6o54.jpg) (http://imageshack.com/i/1f6o54j)
(http://imageshack.com/a/img820/1870/rx6z.jpg) (http://imageshack.com/i/msrx6zj)
Tapiterie Scaun...
(http://imageshack.com/a/img19/3694/gzlq.jpg) (http://imageshack.com/i/0jgzlqj)
Jante plecate la reconditionat : Multumesc impreza01
(http://imageshack.com/a/img843/7494/3lwf.jpg) (http://imageshack.com/i/nf3lwfj)
Hopa, arata a masinaaaaaa!!! 8)
F frumoasa cateaua!! Felicitari!!!
Esti pe drumul cel bun... ;) cu motorul ce-ai mai facut?
a facut schema mea preferata :D a cumparat o masina pt un motor :D
arata super masina ! abea astept sa o vad in fata casei !
Superb
La final va iesii ceva special.
Din nou tot respectul pentru Dani. ;D ;D ;D
Esti pe drumul cel bun, astept sa revina pe strada...
Ceva noutati?
Ce face Pluto?
Pluto a ramas un pic blocat datorita unor complicatii dar deja a reaparut luminita de la capatul tunelului... Sper sa revenim pe drumul cel bun si sa intram cat mai curand pe ultimii 100m...
E al dracului de frustant sa vezi cum iti vin piese/accesorii si sa nu ai pe ce sa le montezi :'( :'( :'(
(http://imageshack.us/a/img163/6505/5fzx.jpg)
(http://imageshack.us/a/img407/2172/49f4.jpg)
Incep sa urasc ziua de azi ... Calde - proaspat livrate...
(http://imageshack.us/a/img855/8271/6ejh.jpg)
(http://imageshack.us/a/img819/7201/qt44.jpg)
Pai lasa ca se va risipi frustrarea, daca zici ca a reaparut luminita.
Mult spor in continuare.
mda misto restaurare deabea astept sa vad masinuta terminata, multa bafta in completarea proiectului.
Tom mersi mult... daca am uitat ceva, daca ceva nu am facut bine, daca ai vreo idee de a imbunatati ce am facut pana acum... please feel free...
Apreciez orice tip de feedback...
niste bucsi poliuretanice pentru coloana de directie si shifter fac diferenta mare si sunt ieftine check it out ;) si daca ramai pe 5mt si nu ti-ai luat inca si bucsile de la dif poliuretanice fac dif mare si lungesc viata difului
(http://imageshack.us/a/img692/3623/mqbe.jpg)
ce este taiat deja am achizitionat. ma poti ajuta bucsile pentru coloana de directie si shifter?
in principiu da, lasa-ma sa pun o intrebare la ai mei
Mersi mult...
Coduri bucsi achizitionate :
- Rear beam mount PFR69-118BLK
- Rear Tie Bar To Hub Rear-Front Bush PFR69-115,117
- Rear Tie Bar Bush PFR69-110BLK
- Rear Tie Bar Bush PFR69-111BLK
- Rear Diff Mount PFR69-122BLK
Am incercat sa merg cat de mult am putut pe seria Black, dar si diferenta de pret in comparatie cu seria purple e sesizabila...
Un weekend cu ceva activitate :
(http://imageshack.us/a/img200/7537/59qt.jpg)
(http://imageshack.us/a/img802/5804/av13.jpg)
Inainte si dupa...
(http://imageshack.us/a/img28/3738/87qo.jpg)
(http://imageshack.us/a/img842/803/22w7.jpg)
(http://imageshack.us/a/img541/1719/b9e4.jpg)
(http://imageshack.us/a/img577/8623/4lba.jpg)
;D cunoastem fundalul din ultima poza :)) . Au iesit masini speciale de acolo ;)
Si eu am vrut sa intreb de fundal cand am vazut poza, dar am zis sa ma abtin :D
Mult noroc, ce sa zic...
Eu zic ca nu are nevoie de noroc. Se pare ca s-a gandit la toate...
Daniel, vazand cat esti de organizat, sunt convins ca ai trecut pe undeva absolut toate cheltuielile. Ar fi interesant de vazut la final cat costa sa faci asa o masina. Daca vei vrea sa le faci publice, ar fi super...
Felicitari si spor in continuare!
Aveti dreptate referitor la fundal... ;D
Ket mersi mult, dar lista cost/timp/etc... va fi facuta publica dupa intalnirea de 4 ani (vin insotit de nevasta... ;D) ...
Makes sense... :))))))
Nimeni nu e perfect...;)
Asa e... Nimeni nu e perfect...
Sigurante montate:
(http://imageshack.us/a/img12/2951/x5ov.jpg)
Speram ca asta va fi ultimul drum pe platform... Masina a intrat la mecanica.
(http://imageshack.us/a/img13/6043/sy79.jpg)
(http://imageshack.us/a/img46/5234/6lxa.jpg)
(http://imageshack.us/a/img96/723/xcog.jpg)
Singurele mele cuvinte sint : Whauuuuuuuuuuuuuuuuuu ce misto !
tiplete! ;)
Sper ca problemele au fost rezolvate si in sfarsit esi pe linie dreapta. ;D
Putem sa incepem lista cu cine va fii dat primu' o tura 8)?
Felicitari din nou si fii tare.... rodul muncii tale va fii nepretuiut.... pentru toate celelalte exista MASTERCARD ;D ;D ;D
Si a inceput distractia ...
Stranse in 8 luni...
(http://imageshack.us/a/img89/1976/b2tp.jpg)
(http://imageshack.us/a/img856/8311/k1li.jpg)
Mersi tuturor...
Din pacate se stie cine va fi prima persoana plimbata...si nu vreau sa risc sa ma trezesc cu bagajele in fata blocului si cu yala schimbata la usa de la intrare... :D
Mai ales ca se preconizeaza un al doilea "GC project"...
Si daca tot exista MASTERCARD am mai comandat :
1. Subaru Impreza STi Uprated Heavy Duty Group N Engine Gearbox Mount 5 Speed Kit
2. Subaru Oil Filter Genuine RCM Impreza Legacy Forester EJ20 EJ25 High Performance
3. Subaru Impreza Turbo GC8 Hel Performance stainless braided clutch line kit 92-00
Si cum sunt fumator, trebuia sa facem si o aroganta la capitolul "fitze" :
(http://imageshack.us/a/img62/4462/dihx.jpg)
Maxim de fita.Sa nu cumperi ulei,ca o sa ti dea sefii la forum premiu pentru cea mai buna restaurare...dupa mine ;D
+1
Stiam eu ça pot pune apa in loc de ulei... Doua luni nu cred ça o sa fie vreo problema ;D :D
Daca ar fi asa si in cazul benzinei...
Pai asa restauram ambele masini in fiecare an...Faceam o dunga...o linie...un iXs...scriam borla,racing etc...;D
Se anunta un weekend plin...
Intre timp au venit si garniturile de la capace supape, bricheta auto
(http://imageshack.us/a/img35/8953/cfgk.jpg)
Fierbinti...
(http://imageshack.us/a/img30/2215/08jt.jpg)
:D incep sa te urasc :D
:D ce compliment dragutz.... :D 8)
Pe drum :
- MOTUL 10W40 Chrono 300V si 5W40 300V Power (pe care sa il bag in Pluto???)
- Filtru benzina KNECHT KL134
Si mai sunt cateva in lista de venit...
Ce imi ulei recomandati pentru cutie si diff, servo?
Ce lichid de frana imi recomandati?
Ulei cutie 75w90 si diff la fel
Frana eu am luat 5.1 dar poti sa iei rbf660 si esti racheta !!!
Servo e dextron III parca am pus ....
In cutie si dif. baga 75w140 Motul...e mai bun decat 75w90...rezista mult mai bine in conditii ...grele ;D ;D
Mersi mult ... E 4-1 pentru 75W140.
Ceva cantitati se poate? Asta ca sa Nu comand la butoi de 200l.... :D
In cutie din cate stiu 3.5L si in diferential 0.8L
5L iti ajung pt cutie si diff
Thanks guys....
Am mai comandat :
- 5l Motul - Gear Competition 75W140
- 4l Motul - RBF660 Factory Line
- Motul - Top Grease 200 pentru tot ceea ce inseamna articulatii...
- set burdufe planetare...
Sambata vrem sa "reconditionam" planetarele si suspensia Tein... Capetele de planetare sunt inca in stare buna.
Pentru servo am optat pentru ceva de la Mobil sau Castrol, ce au mecanicii in stoc...
Am uitat ceva???
:'( :'( Mai am nevoie de (astept sfaturi) :
- discuri de frana fata-spate
- saboti frana de mana
Si alta surpriza... Multumesc mult Serban!!! Curul mic in scaun Recaro se tine... :D
(http://imageshack.us/a/img194/5404/n9to.jpg)
Cantitatile de ulei necesare le poti afla de aici.
http://ew5.earlweb.com/recommendations.php?sector=9&category=6&subset=271&modelyear=&vehicle=7713&site=41®ion=59&language=5&brand=45
Schimba si tu modelul masinii cu cel al masinii tale.
Mersi mult Ket
Dupa ce termini de restaurat masina o vinzi? ;D ;D ;D
;D :D ;D :D Buna gluma ...
Si eu as fi interesat sa intru la licitatie... ;)
Eu tot Motul 75 W 140 am bagat la cutie si diferential. Lichid de frana am folosit AP Racing si Motul RBF660.
Eu n-am glumit ;D
Cand termini ti-o dau si pe a mea sa faci acelasi lucru cu ea ;D
Sa imi spui si care e bugetul :D ;D
Gasit pe birou in dimineata asta... Sper sa fie ceea ce trebuie???
(http://imageshack.us/a/img713/8234/yahm.jpg)
zilele trecute electricianul a mai descoperit ceva...mecanicii au confirmat :
(http://imageshack.us/a/img845/1903/kvu4.jpg)
pai e si tunat cand o vedem pe asfalt? :o
:-X :'( prefer sa nu mai dau pronosticuri... acum se lucreaza la intins si prelungit fire, decupat bord si fete de usi, executie conducte frana dublu circuit si combustibil
:'( dar ce e mai important e ca mai asteptam unele piese de venit :
- distributie
- pompa apa
- pompa centrala frana, kitt de reparare etrieri Sumitomo (4pot)
- caseta de directie (de la reconditionat)
:'( inca nu am gasit solutie pentru :
- discuri frana
- ansamblu stergatoare
- aeroterma (posibil si sistem AC)
- adaptare/montare sistem ABS
Lista a inceput sa fie din nou lunga... Dar nu ne lasam!!!
incet incet vine ziua cea mare
(http://imageshack.us/a/img547/2351/d20t.jpg)
(http://imageshack.us/a/img12/8720/5gu1.jpg)
(http://imageshack.us/a/img594/7421/62t2.jpg)
:o
Superb!
daca vi la intalnire anu asta sigur o sa primesti numai tu premii :( ;D
7,5W40 ? :)
nu amesteca uleiul, are mai multe masini :D
7,5W40 :D inca nu m-am hotarat ce sa bag in Pluto si ce sa bag in Troaca. astept sfaturi!!!
:'( :'( :'( o vreau gata cat mai repede... iar sunt sevraj ca nu am timp de ea... :'( :'( :'(
prezent la intalnire sigur o sa fiu... mai ramane sa vad cu ce vin... tot ce imi doresc e sa nu fiu nevoit sa vin cu mazda
7,5W40 ? :)
:D
Nu am stiut in ce topic sa scriu, dar maine e o zi mare :
1. Suspensia de pe GC gri se muta pe GC albastru
2. Suspensia de pe GC albastru se muta pe Forester
3. Suspensia de pe Forester se muta pe GC gri (mai putin flansele)
Cu ocazia asta fac si revizia la Forester.
4. Se urca articulatia noua pe GC albastru
Maine seara revin cu poze...
Si de ce devenise fata verisoara cu mama si mama nepoata fiicei?Pt ca le a fŽ!Ž! negru de le a zapacit...Asta mergea la " bancu zilei".Si pun pqriu ca daca trebuie sa o mai spui inca o data,nu mai stii care pe care de la care ...;D
Nu e mah niciun GC negru. ;D E unu gri si unu albastru. ;D
Daniel, multa bafta la transplanturi!
Ieri sau facut transplanturi de suspensii. Poze facute aseara :
(http://imageshack.us/a/img440/6424/rv34.jpg)
(http://imageshack.us/a/img9/4990/f94e.jpg)
Suspensia Tein pe Pluto :
(http://imageshack.us/a/img713/8901/6euu.jpg)
(http://imageshack.us/a/img11/9128/udqh.jpg)
GC cu suspensie de Forester :
(http://imageshack.us/a/img11/6083/9try.jpg)
(http://imageshack.us/a/img13/2804/0zdv.jpg)
Forester cu suspensie de GD trantita pe burta :
(http://imageshack.us/a/img13/2023/ui74.jpg)
(http://imageshack.us/a/img845/4261/5bxg.jpg)
Raportul zilei de azi, mai tarziu sau maine seara.
wow ! ce mult ai coborat Foresterul !
gc-ul gri se dezmembreaza?
Porno...
Chiae cu riscu' de a-i plati drepturi de autor lu' alalant
SECSIII!
Nu e risc....nu e fun...;D
In principiu da... Depinde ce te intereseaza!
Foresterul nu va ramane asa coborat... Mai multe detalii pe topicul lui.
Ieri s-au montat : motor, cutie, modul abs... Lupta continua...
Ceva mai multe poze ...
(http://imageshack.us/a/img4/8367/qvi5.jpg)
(http://imageshack.us/a/img837/7273/3xuv.jpg)
(http://imageshack.us/a/img809/1921/1lw5.jpg)
(http://imageshack.us/a/img7/7555/disf.jpg)
(http://imageshack.us/a/img819/8906/4l4j.jpg)
(http://imageshack.us/a/img404/9306/oi7u.jpg)
(http://imageshack.us/a/img690/5261/24j2.jpg)
(http://imageshack.us/a/img812/7428/jvf4.jpg)
Motorul a fost refacut? Hai ca nu mai e mult. Sigur ajunge la Sovata...
Nu... Doar desfacut si curatat, cateva garnituri schimbate, vas de expansiune Forge (Multumesc mult Malakay), bujii noi, si injectoare curatate.
Si bineinteles tampoane de grupa N.
Sunt curios sa vad cum va merge sistemul de franare. Acum am conducte independente la rotile spate.
Las pozele sa vorbeasca :
(http://imageshack.us/a/img46/4794/hzm3.jpg)
(http://imageshack.us/a/img706/9648/tbjf.jpg)
(http://imageshack.us/a/img34/4060/2o7u.jpg)
(http://imageshack.us/a/img822/9315/16v1.jpg)
(http://imageshack.us/a/img841/1041/67q4.jpg)
O sa iesi vreodata afara cu ea sau o tii in casa?
;D cum sa nu?! sper sambata!!!
H8ERE esti ciudos nus ce sa zic :D ca nu mai iei premiu anu asta .... ;D
Ba par.Vezi ca deja ma hartuiesti si te pun pe tabelu cu maimute.Pai eu ii laud munca omului si tu ma persiflezi?h8r conecter esti tu ma păr...
+1 tura pentru fiecare sa va nu va mai hartuiti...
Mai e un pic si se fac 10 luni de cand m-am apucat de masina... Deja visez la prima cheie, la sunetul evacuarii si la prima talpa...
Pai o cheie ti dau eu si o talpa h8aru de malakie...Ca sigur are muuulte talpi acolo la el...in centru.Aproape de centru..
Talpa galbena si cheie de sti...
10 luni, avand in vedere ca ai facut o masina "noua", nu e o perioada lunga. Abia astept sa o vvedem pe drum. Ma dai si pe mine 10m? ::)
Masina de bagat ulei in usi :) si de tinut o viata...
Ket Numai 10m? Scap ieftin... ;D Nevasta-mea deja pregateste biletele... :D ;D
b-power sunt sigur ca nu o sa tina o viata :D :D :D
In seara asta am primit un scurt up-date telefonic :
- discuri frana montate
- frane montate complet
- si alte cateva bla bla bla
Concluzia : masina e pe roti !!!!!!!!!!!!!!!
Mi e si frica sa spun ca abia astept s o vad mergand.Ca hop sare Malakistu si ma face h8ar.
H8er??? Se poate traduce?
H eit ar...eight gen Adica pe romaneste ma face ofticos.
:D :D :D sunt mai greu la asa ceva
Lasa ca inveti pe forumul asta, Dani. Si eu am invatat de-astea aici. Sambata stam in paralel, ca o sa fiu in Bucuresti. ;)
Ket as vrea eu sa stam sambata in paralel dar nu cred ca va fi gata de iesit pe strada...
Daca totul merge ok pe partea electrica si motorul porneste ne apucam de interior...dupa care mergem la un test de frane si un dyno.
Mai avem de primit sosoni de iarna, sunetul si Inca cateva dulcegarii...
Sosonii de iarna sunt pregatiti :
(http://imageshack.us/a/img842/451/lvfu.jpg)
(http://imageshack.us/a/img856/7402/y7gi.jpg)
Capitolul TUNING AUDIO incepe cu un cadou de la sotie :
(http://imageshack.us/a/img196/1516/i5jb.jpg)
HU : Pioneer DEH-4600BT
Difuzoare : 4 x Hertz DCX 130.3
Insonorizare :
STP Noise Liquidator One Component care a fost folosit la arcele rotilor. In acest fel sper sa elimin macar o parte din zgomotul de rulare al masinii.
STP Crystal - in spatele difuzoarelor
Dupa decupare si tapitare, fetele de usi vor fi date cu pasta Brax.
Ne pregatim pentru Sovata ....
Nice nice!
Dar motorul? A pornit? Umbla? Hai ca mai e putin pana la Sovata. Sa spargem palinca de masa de calcat.
Ceva noutati?
pai ce faci? nu vii cu XT ul la Sovata? ne tradezi ? ;D
Noutati prea bune nu prea am... Se lucreaza, se lucreaza, se lucreaza ...
Momentan ieri s-a reusit decuparea/montarea bordului.
(http://imageshack.us/a/img842/6199/yagr.jpg)
Si da, target-ul e sa vin la Sovata cu GC-ul si nu cu XT-ul...
Deci cum ar veni,ai taiat bordul asta.Ce i drept,eu nu am avut timp sa ma uit dupa celalalt
m-a lasat rabdareaaaa....
Tulaaaai ma, da palinca se bea dupa cusut nu inainte, cam stangace cusaturile alea albastre, cel putin din poza asta.
Hop si io ca vaca...
Ai pus degetul pe rana... Cat dai atata face... :(((
Cum a zis si Malakay : Ca la romani incet si prost
Hqi ca ti fac eu un bord wenge...ce pana mea..
:D Cu usi cu amortizoare
Cu servodrive direct....
Indubitabil wenge... :))
Si a mai sosit ceva util...
(http://img.tapatalk.com/d/14/01/11/zusamesy.jpg)
Poate maine am timp sa mai trec si eu pe la garaj :((
Sent from my iPhone using Tapatalk (http://tapatalk.com/m?id=1)
Din poza nu mi-am dat seama....nu ai decupat bordul inainte sa-l imbraci in piele??
Din pacate nu... Proba a fost facuta foarte prost si am trait cu impresia ca tevile trec prin fata bordului. :(((
A iesit bine oricum.
O scoti tu la capat.
mergi cu asta asa si cand il gaseste celalalt pe al lui il refaci pe ala bine :D
Pai asa o sa si fac... Iti dai seama cum o sa arate bordul wenge :)
Cu manere haurii...
Si dupa foarte multe discutii aprinse au mai fost finalizate cateva piese ...(http://img.tapatalk.com/d/14/01/12/dugadyry.jpg)
(http://img.tapatalk.com/d/14/01/12/uremajyv.jpg)
(http://img.tapatalk.com/d/14/01/12/e7epa4u5.jpg)
Avem din ce in ce mai multe emotii!
(http://img.tapatalk.com/d/14/01/12/3a4e8a3a.jpg)
Daniel, felicitari. Eu abia astept s-o vad. Daca ma si dai o tura....
Impinsa, trasa sau cu caii ei, tot ajungem cu ea la Sovata...
Tic-tac!
Sa nu fie knock knock...
Tic-Tac.... Se lucreaza...
(http://img.tapatalk.com/d/14/01/17/puvy8avy.jpg)
(http://img.tapatalk.com/d/14/01/17/nypenu6a.jpg)
Houston we have power...
Ignition, they say ignition damnit!!! :D
Felicitari gugu-le! wruuuum wruuuuum, AMR 3sapt!
Noroc cu intalnirea, ca altfel nu te stresai asa tare sa o termini mai repede :D
Glumesc! E bine ca are curent. Vrem sa o vedem mergand si pe benzina, nu doar pe baterii :)
Si eu de abia astep sa ii fac primul plin...
Primele doua trei....
A fost instaurat bugetul de austeritate...
Unde ma? ;)
Un cuvant frumos : "mobila"
La cine?MA ati inebunit?
La cine ce?
Si cum pe la garaj nu am mai avut timp si chef ne-am apucat sa mai reconditionam niste "piese" care vor ramane de rezerva
(http://img.tapatalk.com/d/14/01/29/dehuve5y.jpg)
(http://img.tapatalk.com/d/14/01/29/y3a6u6yg.jpg)
(http://img.tapatalk.com/d/14/01/29/uhyda7ys.jpg)
Cine ma poate ajuta cu codul la :
(http://img.tapatalk.com/d/14/01/29/tygenyhy.jpg)
Lasa astea, cand o scoti in probe?
Ket habar nu am :((
Deci...? ::)
Chiar...deci?
Vezi ca am sufa...daca e nevoie.
O sa venim cu Foresterul... Sansele sa vin cu GC-ul tind catre zero :((
Bicoz?
Sper ca n are legatura cu plqca pt boxe ::)
Poveste lunga si lipsa de lucru manual :( ... Inchin o vodka in cinstea acestei masini!!!
Hai mai multe...
Mie imi pare rau de tot. Abia astdptam sa vad cea mai buna si completa restaurare... :( Va trebui sa organizam o intalnire la mare de 1Mai sa o prezinti ;)
Important e sa iasa bine, chiar daca mai intarzie un pic
Eh...lasa.Asa o sa iau eu iar uleiul ;D Glumesc.O luam pe ulei toti
In acest weekend, chiar daca nu a putut fi de fata, Pluto a primit premiul pentru "restaurarea anului".
Multumesc mult tuturor (adminilor, Pol Distribution, etc...) pentru acest premiu si pentru ajutorul/suportul oferit.
Doar ce am primit un telefon de La Service si :
Pluto is back!!! IT'S ALIIIIIIIIVE!!! IT'S ALIIIIIIIIVE!!! IT'S ALIIIIIIIIVE!!! IT'S ALIIIIIIIIVE!!!
Diseara poze si filmulete!!!
Bravo!!!!
Ne tii pe jar pana diseara...
Din pacate nu am cum sa ajung la garaj pana diseara :'( :'( :'(
Astept cu nerabdare sa vad ce-a iesit, sper ca la urmatoarea intalnire sa vii cu ea :)
Sent from my GT-I9505
Pana la intalnirea urmatoare nu se mai da jos din ea ;)
E deja de mult diseara...
(http://img.tapatalk.com/d/14/02/12/syqu3yne.jpg)
(http://img.tapatalk.com/d/14/02/12/9e9ezu4a.jpg)
Shiny, your precious!
(http://img.tapatalk.com/d/14/02/12/2u8ase5y.jpg)
(http://img.tapatalk.com/d/14/02/12/y8epy6uq.jpg)
(http://img.tapatalk.com/d/14/02/12/pybaqu9y.jpg)
(http://img.tapatalk.com/d/14/02/12/py9amynu.jpg)
(http://img.tapatalk.com/d/14/02/12/qe8e2a9e.jpg)
(http://img.tapatalk.com/d/14/02/12/5y2udeqe.jpg)
Filmuletul cu motorul pornit o sa il pun maine... Habar nu am cum sa fac asta de pe telefon!!!
O poza de ansamblu...ca nu te cred.
(http://img.tapatalk.com/d/14/02/12/equryvy7.jpg)
Mai avem... Si acasa :
(http://img.tapatalk.com/d/14/02/12/u3u3eheb.jpg)
Ce 3.14ZDA arata pe la ansamblele alea de la roti... ;D si asta ultima e belea.
Se vede?
Ai facut o sa leviteze?
Se si aude...
:)) e inca pe elevator. Maine se incearca montarea radiatorului de ulei, a senzorilor pentru ceasuri si altele...
Cum ma "se incearca"?
Eu propun sa facem road trip pana la ei sa le explicam cum sta treaba...
sco lol... bravo domnul sa fie intr-un ceas cu cuc si sa mearga acaretul
De unde ai luat bieletele alea babane? :)
Bieletele au fost luate de la CDF Racing
(http://img.tapatalk.com/d/14/02/13/3u9evesa.jpg)
(http://img.tapatalk.com/d/14/02/13/y2e4ygar.jpg)
(http://img.tapatalk.com/d/14/02/13/asy7uge7.jpg)
(http://img.tapatalk.com/d/14/02/13/a6a7yhy2.jpg)
Cat ulei o sa intre oare acum in motor tinand cont de faptul ca am montat radiator de ulei? Aveti idee?
Doamne cat costa RCA-ul... :o :o :o
(http://imagizer.imageshack.us/v2/xq90/607/jzg3.jpg) (https://imageshack.com/i/gvjzg3j)
la fel e si la mine. eu mi`am facut la Asirom...
Hai ca poate gasim ceva mai ieftin.Sau vezi la Alecsm cat iese...
Probabil iti va intra cu peste 1,3 litri in plus. Asa ca ar trebui sa-ti comanzi de fiecare data cate 6 litri. Dar se merita...
Arunca un ochi si la RCA pe roti (vezi firme partenere). De obicei au preturi mai bune, livrare la domiciliu, daca nu cumva esti in zona biroului si mai ai si acel 5% pentru membri... poate il facem si pe asta pentru sustinatori :D
Up-date de seara :
(http://img.tapatalk.com/d/14/02/14/u4a8e2um.jpg)
(http://img.tapatalk.com/d/14/02/14/emape8an.jpg)
(http://img.tapatalk.com/d/14/02/14/e3ysuny5.jpg)
(http://img.tapatalk.com/d/14/02/14/a9yhydyh.jpg)
Iti scriu si aici ce ti-am scris in alta parte: Felicitari! Nu multi pot face ce ai facut tu...
Ket mersi mult... Dar sunt sigur ca si altii pot... Cu ceva vointa si rabdare se poate aproape orice!
Mai ai putin ;D ...abia astept sa vad si eu bijuteria ;D
wow! e aproape gata! felicitari pentru determinare! ai adus o masina din stare de remat intr-o stare de invidiat!
Deci...eu n am cuvinte.Arata fix ca o bijuterie.Ma uit la ea si simt teama aia de iesi cu ea pe strazile "cilivizate" dân Bucuresti...Jos palaria.
Haha felicitari ,acu inteleg dece erai asa zambitor aseara.... !
Pfuuuuu teh seks! Felicitari, arata spotless, dea abia astept sa o vad montata, probabil nu la fel de mult ca si tine, dar sunt si eu acolo :)
Iar am ajuns sa nu mai am timp de masina :(( Multumesc Malakay de idee...
(http://img.tapatalk.com/d/14/02/18/7ujava6e.jpg)
(http://img.tapatalk.com/d/14/02/18/sebuta8e.jpg)
(http://img.tapatalk.com/d/14/02/18/ebuzy2y3.jpg)
Am incercat si eu dar era suspendat site-ul. Am incercat si sa-l sun pe Alex , dar fara reusita.
Nu-i bai... RCA facut 12luni 657,15ron la Astra
Au...si Astra cica e cu probleme mai nou...
A fost schimbata conducerea... In rest nu sunt probleme :)
ba se pare ca`i paste falimentul.
Si eu am auzit despre Astra la fel, si am auzit bine... ;) Dar pe cine intereseaza asigurarea aia? Se face alta. ;D Hai Daniel, filmulete vrem!
Noutati?
Dani, ne fierbi? Mai da-ne noutati :(
Dani, mai esti pe aici? :D
Din ce in ce mai rar. :((( criza isi spune cuvantul... Si sclavia pe plantatia altuia.
Din pacate nu am mai avut timp sa trec pe la garaj, dar nici nu cred ca au mai facut ceva...
I feel you bro, acelasi lucru si la mine, asteptam totusi ceva noutati :)
Din pacate au cateva saptamani in care nu am mai avut timp de masina...dar ieri a fost o zi speciala!!!!
A fost finalizata si testata toata mecanica... Primul drum pe roti a scos la iveala cateva mici probleme :
- fum alb la relanti si relanti un pic instabil la rece
- scurgeri de ulei pe la suportul filtrului de ulei
- ambreiaj de schimbat
Totodata ieri am inceput montarea interiorului : plafon, stalpi, ...
(http://img.tapatalk.com/d/14/04/13/ha8y7a3y.jpg)
(http://img.tapatalk.com/d/14/04/13/be5atu2a.jpg)
(http://img.tapatalk.com/d/14/04/13/gu7ery5e.jpg)
(http://img.tapatalk.com/d/14/04/13/yryru7ab.jpg)
(http://img.tapatalk.com/d/14/04/13/e7ujare4.jpg)
(http://img.tapatalk.com/d/14/04/13/y9yhe2aq.jpg)
(http://img.tapatalk.com/d/14/04/13/suqy4uty.jpg)
(http://img.tapatalk.com/d/14/04/13/7azateby.jpg)
Hai cu ea la nisip!
Venim... Venim...
(http://img.tapatalk.com/d/14/04/21/nezetaza.jpg)
Iar acasa incercam sa nu ne plictisim. Traiasca filmulete DYI de pe Youtube.
(http://img.tapatalk.com/d/14/04/21/3ymanugy.jpg)
(http://img.tapatalk.com/d/14/04/21/zy8y3u9u.jpg)
(http://img.tapatalk.com/d/14/04/21/natanu8u.jpg)
Niceeee!!!
Legat de suportul de numar, cam strica look-ul sportiv/agresiv. Cand vii la mare iti arat ce suport am eu pe fata, poate te incanta. ;)
(http://img.tapatalk.com/d/14/04/23/vysymepe.jpg)
(http://img.tapatalk.com/d/14/04/23/a8asybu4.jpg)
Un scurt up-date de aseara...
Sper ca in seara asta sa am mai multe poze!
(http://img.tapatalk.com/d/14/04/24/ypury6eq.jpg)
(http://img.tapatalk.com/d/14/04/24/dude4ezu.jpg)
(http://img.tapatalk.com/d/14/04/24/asuty6uj.jpg)
Au inceput ultimele finisaje...
Arata demential!
Mersi mult... Dar au trecut 14 luni de cand am inceput restaurarea...
Si cum ceva trebuia sa se intample... Caut cablu vitezometru!!! DE STANGA!!! ma poate ajuta careva???
Victor?Poate mai are el....Eu si daca mai am nu stiu pe unde e.Ultima oara am luat unul de legacy si a trebuit sa modific ceva la el la intrarea in cutie.
eu l-am dat lui ghe pt gc lui ... si ala de aspirat nu cred ca merge
(http://img.tapatalk.com/d/14/04/26/a3a6uhe6.jpg)
(http://img.tapatalk.com/d/14/04/26/u7y6a7et.jpg)
(http://img.tapatalk.com/d/14/04/26/he3umury.jpg)
(http://img.tapatalk.com/d/14/04/26/egenypav.jpg)
In fata casei...
Cum sunt sezuturile boss?
Haha, multe vizite la OMV. Transporti si tu in atmosfera? :D
Sa te bucuri de ea!
Bravo....a prins forma si viata ...super treaba ;D
@celalalt... Bestiale!!! Sunt primele scaune in care nu imi danseaza curu lambada :)) Poate bem azi o cafea 😉
@Ket... Sper sa ne vedem cat mai curand sa transportam impreuna.
@Ady. A prins viata in Safe Mode. Mai avem unele mici probleme de rezolvat. Dar incet incet le scoatem la capat!
Prima spalare dupa 14 luni si 8 zile ...
(http://img.tapatalk.com/d/14/04/26/gumygana.jpg)
(http://img.tapatalk.com/d/14/04/26/7a5egehy.jpg)
(http://img.tapatalk.com/d/14/04/26/sypana9y.jpg)
(http://img.tapatalk.com/d/14/04/26/udenumud.jpg)
Arata intr un fel...:o
Mersi mult Serban!!!
a iesit foarte bine! bravo! masina arata cum trebuie, si rotile sunt de acolo :) ce sunt? seamana cu team dynamics 1,2
Am trecut si eu pe strada cu cele mai multe GC-uri din Bucuresti astazi dimineata si mi-a sarit in ochi imediat. Nu am avut timp sa ma opresc, dar chiar si asa iti dai seama ca e o masina bine pusa la punct. Sper sa rezolvi si cu problemele de fineţe.
(http://img.tapatalk.com/d/14/04/27/7ununy7a.jpg)
Mai sunt multe de facut la aceasta masina, dar totul in timp. Inclusiv ceva remedieri pe la motor...
Dupa o scurta plimbare, ne protejam de ploaie....
(http://img.tapatalk.com/d/14/04/27/ysydeha6.jpg)
Seksy
Mersi Victor!
Si din categoria DYI (calitatea sigur lasa de dorit) :
(http://img.tapatalk.com/d/14/04/28/5apuhezy.jpg)
(http://img.tapatalk.com/d/14/04/28/e7atu3yq.jpg)
(http://img.tapatalk.com/d/14/04/28/6eju6ynu.jpg)
(http://img.tapatalk.com/d/14/04/28/evybu5e8.jpg)
Nu vreau sa mai aud sau sa simt miros de prenadez!!!!
Si cum am fost informat : masina asta Nu o sa fie gata niciodata...
Azi au sosit :
- filtru de aer
- bucsi coloana de directie
(http://img.tapatalk.com/d/14/05/05/nape5uge.jpg)
(http://img.tapatalk.com/d/14/05/05/ade6ugyt.jpg)
Sent from my HTC One using Tapatalk
Se vede treaba ca ai mirosit mult prenadez daca ai si inceput sa il auzi ;D
Am vazut si eu masina la garaj. Sper sa o scoti de acolo cat mai curand ca parca ar da mai bine pe strada decat acolo. Ai rezolvat cu senzorul de viteza si furtunasele de vacuum?
@Celalalt .... :D :D
Mihai masina este intr-o parcare subterana pentru ca nevasta-mea nu ma lasa sa o tin casa :))) si pentru fi protejata de ploaie. Din pacate trebuie sa relipesc parbrizul si luneta, am constatat ca sunt dezlipite.
Furtunasele de vacuum au fost rezolvate (Thx to Malakay and Raduph).
Cablul de vitezometru este venit dar inca nu am apucat sa il montez...sper sa se potriveasca. O sa fac o incercare in urmatoarele zile!
Completare la TO DO LIST - urgente pana sa stea definitiv pe strada:
- ca sa eliminam complet ploaia din masina mai avem de reglat usile si capota portbagaj, parbriz si luneta de relipit
- caseta de directie de schimbat
- bucsi coloana de directie de montat
- cablat si montat claxon in volan
- pompa servo de schimbat
Cam asta inseamna babeta :) Spor la treaba!
dute baa tradatorule ... buuuhuuu
Incet incet "o revergoram" noi...
Doamne, cum poate sa arate. Demential. O lasi clean sau trantesti ceva abtibilde pe ea?
Excelent. As veni si eu daca faceti intalnari in Bucuresti, poate mai fur niste meserie cu unele chestii. :D
Eu vinerea, de exemplu, ies in jur de 2 jumatate, pot veni cu babatia in loc de daily drive si sa ma arunc o fuga prin Bucuresti daca aveti chef/timp.
Zi-mi si mie te rog, ai idee ce e teava aia de iese din galerie (gasesti cateva poze in galeria cu furtunasele de vacuum) Imi sta pe creier pentru ca nu pot sa fixez furtunul cum trebuie pe ea.
Mersi mult Radu! In principiu masina va ramane clean, cu unele mici exceptii. Inca o gandim!
Ar fi frumos sa facem o intalnire, dar mai pe seara daca se poate (18.00-19.00)
Uraaa!!! Vitezometrul e functional (inca nu stiu ce indica, mile sau km) dar limba se misca...
.... Si s-a mai dus juma de rezervor :)))
Limba ar trebui sa ti arate ca pozitie la fel.Doar cadranul difera.Deci ar trebui sa vezi km/h
Priveliste de la birou :
(http://img.tapatalk.com/d/14/05/09/y9yzy6yz.jpg)
e simplu daca pe a 5a la 3000 ture iti arata 60 mile e in mile daca iti arata 100 mile inseamna ca sunt km :D
Reparam una...pica alta...
(http://img.tapatalk.com/d/14/05/10/zy3u4eje.jpg)
(http://img.tapatalk.com/d/14/05/10/evepe5ev.jpg)
Mama lor de garnituri...
Maine ne facem program de biserica!!!
Cum dracu....? Nasol moment... Pe unde picura, pe la buson?
Pare a picura pe la garnitura capac supape... Masina a ajuns deja in service, luni se va da motorul jos :(((
(http://img.tapatalk.com/d/14/05/11/je3aqysy.jpg)
Pffff.... Urat de tot. Speram sa fie ceva mai simplu gen un buson nestrans cum trebuie sau un filtru ceva...
Succes!
Edit: Picura si in partea cealalta?
Ma Dani, si mie imi picura pe acolo la GC de cand l-am luat din UK, am ajuns acasa, am schimbat garniturile la capace(120 lei) si aia a fost.
Aceeasi problema o am si eu... Dar ramane de vazut...momentan incercam sa gandim un plan pentru intregul motor.
Poate ar trebui sa faci si o rectificare, sa nu fie un pic flambat? Stiu ca se plangeau baietii pe rs25.com fix din aceeasi cauza. Garnituri noi si tot curgea din cauza ca era un pic deformat si nu etansa cum trebuie.
Pune pasta si strange. Am avut si eu aceeasi problema, pentru ca pe blocul motor nou am folosit capacele de pe vechiul motor. Pasta a rezolvat totul ;)
Ce mai face Pluto?
relativ bine... asteapta niste piese... :'(
E pe perfuzii?
Life support?
E la reanimare... Sper ca in cursul zilei de azi sa fie readusa la viata temporar!
In paralel am inceput deja sa lucram la o surpriza necesara... O inima noua!!!
A cedat aia veche? Nu mergea un bypass ceva?
Bypass-ul e in lucru... Si sper sa fie gata azi!
La inima noua se lucreaza in paralel si sper sa fie gata in maxim 2 luni ... MASTERCARD limitat!!!
e bine ca aflu de pe net :D ;D
Lasa Victor ca nici tu nu prea dai din casa. Se inmultesc GC-urile acolo pe strada si nu zici nimic...
busted :D
Din nou in fata blocului...
Subystreet...
(http://img.tapatalk.com/d/14/06/17/y8yzema7.jpg)
LOL! V-ati adunat la sueta?
Trec pe acolo destul de des si admir in trecere testoasa lu' Malakay.
ba ce carnat eu nu am pus o poza cu gc rosu pe forum si te-ai spart tu :D str coloniei ( de subaru )
Unde faci inima noua man?
Sent from my HTC One_M8 using Tapatalk
Toate culorile acolo.. un fel de "Taste the rainbow... try the GC!" :D :D :D
Mea culpa... 😂😂😂 dar totusi e o priveliste frumoasa...
Ma bucur ca nu se mai vinde :)
Da? Foarte bine! Pai, update-uri la ce s-a mai facut, atunci!
Din pacate nu am mai facut nimic, noul proiect imi ocupa tot timpul... Si cred ca sunt aproape 3 saptamani de cand nu am vazut-o... :'( Poate reusim weekendul asta !!! Caldura mare :'(
Ce dor imi era de ea...
(http://tapatalk.imageshack.com/v2/14/10/04/c8f0d5f529ec66b084f96e987b3ab40a.jpg)
Update-uri noi ? Am parbriz nou ;D
De maine seara o bagam iar la garaj ... :D ;D
- Bucsi poli punte/caroserie spate
- Evacuare de imbracat
- Turbo, diff spate, cardan, discuri frana - de schimbat (si inca cateva surprize)
- Insonorizare si tapiterie interioara
- buza bara fata de reparat
O prima surpriza...
(http://tapatalk.imageshack.com/v2/14/10/09/7f1ef63c73338929a9cf43246cea26f6.jpg)
episode 2
(http://i59.tinypic.com/jqnrdy.jpg)(http://i59.tinypic.com/jqnrdy.jpg)
Sunt familiarizat cu aceasta imagine :)) sa inteleg ca urmezi tu?
Pai de ce nu?!?!
Avem chiar si injectoare mai mari...
(http://tapatalk.imageshack.com/v2/14/10/19/87fee3342759049dbc6df71960baa934.jpg)
Multa bafta! Sa o aduci la intalnirea de 5 ani
Aha.E mai ceva ca Elodia.E chiar noua Elodia.
vezi ca elodia.... elodia nu mai merge de vreo 7 ani .. deci nu iti doresti asta :D
@celalalt... Nu vad legatura cu Elodia...
@Ket... De data asta sigur vin cu Pluto. Nu cred ca o sa finalizez motorul nou pana atunci dar ne straduim.
Exact.Nici pe elodia nu o vede nimeni ;D
"Putina" benzina in atmosfera nu strica...
(http://tapatalk.imageshack.com/v2/14/10/21/6992095a283afe3efa4f2a44e6972479.jpg)
Asa, cara!
Sa avem ce face la iarna...
(http://tapatalk.imageshack.com/v2/14/10/26/0ecfd6deebb08d8f24bb9f8048551c28.jpg)
(http://tapatalk.imageshack.com/v2/14/10/26/4490739cd0b84fad6f2796764e2365b4.jpg)
(http://tapatalk.imageshack.com/v2/14/10/26/5bd03f1a6579e880e895b1b02ff379aa.jpg)
(http://tapatalk.imageshack.com/v2/14/10/26/f0aff87cd91c5f02ee5ac2c41ef8de52.jpg)
(http://tapatalk.imageshack.com/v2/14/10/26/06986dd0c227a465599ece97a0d02801.jpg)
(http://tapatalk.imageshack.com/v2/14/11/08/33f7ade988702cdd17be46408b02d95e.jpg)
"Cred ca am rezervorul spart"... Imi dispare benzina din rezervor 😄
....asa vin toate din fabrica,cu rezervorul spart😜
"Dont worry be happy"
Pai se vede clar in poza ... alimentarea are diametru mult mai mic decat evacuarea, daca n'ai opri motorul nici n'ai putea face plinul :D
Sosonii de iarna sunt deja montati, iar masina a intrat un pic la hibernare. Cu ocazia asta mai facem ceva finisaje la ea...
(http://tapatalk.imageshack.com/v2/14/11/10/8be50776538caeb49d12064ed6c416ed.jpg)
(http://tapatalk.imageshack.com/v2/14/11/10/50579a479d9b65a8cc3f97316e73d6ea.jpg)
(http://tapatalk.imageshack.com/v2/14/11/10/d375bc184babec0e591506d83a2810c8.jpg)
(http://tapatalk.imageshack.com/v2/14/11/13/d473d3245525eef9b0b9a80a38485b84.jpg)
(http://tapatalk.imageshack.com/v2/14/11/13/eba196df677726c02b2b788b62b19876.jpg)
Si asa am inceput sa mai lucram la finisaje...
ce grosime are materialul ??? spor !
Conform specificatiilor 4.2mm... Sa fie!
Si din cand in cand mai lucram si la masina...mici finisaje...
(http://tapatalk.imageshack.com/v2/14/12/07/4b7037bc1ce40e7a8bf7a1716ff1a4e5.jpg)
(http://tapatalk.imageshack.com/v2/14/12/07/24b50580cf093954140a2289d74cfb5a.jpg)
(http://tapatalk.imageshack.com/v2/14/12/07/0783cae58ace505139853b9077fb3118.jpg)
(http://tapatalk.imageshack.com/v2/14/12/07/32e7c8f8a6d9f262a357d2ba7f0db46e.jpg)
Pfffff, nu se va mai putea sta in masina ta. Zgomot de la motor si zgomot de la boxe...
daniel face un pic din toate din masina asta :D o masina cu care mergi la curse ascultand muzica de calitate :D ! crazy house e pe viitorului ... :D (e virusat de vecini )
Fiecare cu gusturile lui manca ț aş.Merge si un neon d ala colorat sa lumineaza pe la "genti".Ca sa sara "tiuningu" in ochi.Sa agață gagicele...Dar are un mare defect...parerea mea.Nu e bemweu...
Nu e nimic rau in faptul ca omul vrea sa aiba un sound de calitate in masina si nu-si permite sa te plateasca pe tine in Captain Morgan sa bati la tobe tot drumul... :D
Costa mai mult de atat.Numai pana instalez scena...
hai ca ati sarit de pe sina !!! :D
Dupa cateva zile de munca, azi am reusit sa iesim la plimbare .... Mersi mult Malakay!!!
(http://tapatalk.imageshack.com/v2/14/12/14/ba17085713fd345b352da230c0a1463f.jpg)
(http://tapatalk.imageshack.com/v2/14/12/14/8a4d118d3fdc73026f9142b6525b31a4.jpg)
(http://tapatalk.imageshack.com/v2/14/12/14/deb74971d75c6b4bdb3656f41a82d9a5.jpg)
(http://tapatalk.imageshack.com/v2/14/12/14/0490dcfd64f9a17e9c2ff43a5f584827.jpg)
(http://tapatalk.imageshack.com/v2/14/12/14/7cd1f16795e60d2e425792d763d8ded5.jpg)
(http://tapatalk.imageshack.com/v2/14/12/14/c7f30ac2f548ae2a82fd3d4dccc2ef08.jpg)
Frumos frumos!
arata super si se aude super bine ..
Cum trage?
Nu trage... Boost 0,5 - 0,6. Cautam schite de montaj pentru furtunasele de vacuum, boost controller.
Mos Nicolae intarziat....
(http://tapatalk.imageshack.com/v2/14/12/19/b8a95f7bc1b41971c7e766e8835e52d6.jpg)
(http://tapatalk.imageshack.com/v2/14/12/19/958611b033ecc2efc2fdc975a5c50da7.jpg)
Sau Mos Craciun in avans...
Frumos! Mai ai multe de cumparat? ;D
😄 Mos Craciun la mine vine prin Ianuarie - Februarie... Stii foarte bine ca lista e foarte lunga si nu o sa se incheie niciodata 😄 atata timp cat e microbul in sange...
Pluto la mall 😄😄😃
(http://tapatalk.imageshack.com/v2/14/12/20/15ae4f62fc7996f602ca2f601f57a25e.jpg)
(http://tapatalk.imageshack.com/v2/14/12/24/ac8e7c4f47949e353cfffa0ba9baf604.jpg)
Mos Craciun a venit mai repede decat ma asteptam...faruri noi !!!
Trebuia! Nu putea sa vina la Constanta cu farurile alea vechi... :D :D
Ii schimba destul de mult aspectul, in bine.
Cele vechi nu puteau fi reconditionate/ vopsite la interior sau nu ai preferat sa te complici?
E atat de multa munca... 😭
Prin Buc am vazut pe alte forumuri vreo 3 persoane care fac reconditionari/ modificari faruri, iar pretul era ~300 ron, daca retin bine, de aceea intrebam de starea celor vechi.
Macar astea's noi si atata timp cat se poate, mai bine asa :D
Dani, imi merge sa scriu la tine de pe taptalk. Da-ti un reinstall
Rezolvat!!! Mersi mult admini!!!
Se poate inchide :)))))) ?
Buna idee...
(http://www.scoobypedia.co.uk/uploads/Knowledge/3_port_solenoid_system.jpg) ;D
Mersi mult Victor... Cand mergem??? 😄
nu stiu vb la tel !
Avem booooost... Fiara trage acum! Mersi mult Victor, CoastaDeEst...
Si s-a mai dus un plin :(((((
Abia astept sa ma dai cu Pluto!
Zilele fericite vin cu gauri in portofel. Lasa, nu te mai agita atat, scad astia imediat pretul la benzina ca doar a scazut pretul petrolului...
Before and after ...
(http://i60.tinypic.com/2enripf.jpg)
(http://i58.tinypic.com/2v989dx.jpg)
foarte misto pozele
;D ;D ;D ;D
Mersi mult Mihai... La aproape doi ani, in aceeasi locatie
Povestea continua :
Strut bar montat
(http://i62.tinypic.com/33cohzt.jpg)
Si o mica fitza ...
(http://i58.tinypic.com/25s2zw7.jpg)
(http://i59.tinypic.com/snyo7m.jpg)
Frumooos!
Ceasuri si stopuri schimbate ...
(http://i58.tinypic.com/33dcgew.jpg)
(http://i61.tinypic.com/xf5m34.jpg)
Subaru.....looks good even upsidedown!
Sent from my Nexus 5 using Tapatalk
:D sorry pentru upsidedown
Si incet incet incepem un nou capitol ...
(http://i60.tinypic.com/2rnzx37.jpg)
Te'apuci de fotbal? ;D
Nu ar strica putina miscare... mai iese si tutunul din noi.
Am masurat barele stabilizatoare...pe fata am 26 iar pe spate 31...dupa cum ti-am zis sunt probabil cele mai groase posibil ;D
mersi mult adi ... eu am reusit sa comand Whiteline 22mm fata si 24mm spate...
Curatenia de iarna :
(http://i60.tinypic.com/2n8zb4m.jpg)
Da si tu mailul ala.Ca pe urma te apuca si zici ca nu te bag in seama...
Si un mic up-grade (mersi Tom pentru sfaturi) :
Sway bar fata stoc 19mm - whiteline 22mm
Sway bar spate stoc 18mm - whiteline 24mm
Si o mica fitza ... grila schimbata cu I roz
(http://i58.tinypic.com/t0lpoy.jpg)
(http://i61.tinypic.com/2aqiba.jpg)
(http://i58.tinypic.com/20t582q.jpg)
asteptam weekend-ul
(http://i60.tinypic.com/119mo2h.jpg)
Ce bine vine stickerul subarufanclub :)
E cam stramb. Nu i l-a pus malakay bine. Acum trebuie sa-i vopseasca masina. ::)
ar merge un pic de roz "Hello Kitty" :D :D
Ce zambet stirb are pe dreapta(sau stanga cum te uiti) ;D
E de la sticker... Toate la timpul lor... :D
Ai rezolvat cu acceleratia?
Da ... de luni seara ... am comandat si alt cablu sa fie de rezerva ;D never say never
Cateva poze din weekend ... ne-am luat revansa dupa cablul de vitezometru rupt
(http://i57.tinypic.com/atntbr.jpg)
(http://i60.tinypic.com/b869hc.jpg)
(http://i58.tinypic.com/2cgeu5f.jpg)
(http://i58.tinypic.com/mj1sg1.jpg)
(http://i61.tinypic.com/1zppngl.jpg)
(http://i59.tinypic.com/1zvcvuv.jpg)
(http://i60.tinypic.com/9u7z7m.jpg)
(http://i60.tinypic.com/doozef.jpg)
(http://i60.tinypic.com/20hq6vs.jpg)
(http://i60.tinypic.com/673780.jpg)
Intra si asta la consumabile ? ;D ;D
Multumim pentru noua poza de profil pe facebook :D
Inca putin si imi reactivez contul de facebook :D :D :D Cu placere!!!
sa speram ca nu ... mersi mult de ajutor ::) ;)
Lasa ca da Cristina Like in locul tau :D :D :D
:D :D :D
Intr-un final si dupa foarte multe certuri cu TNT si cu "Za Romanian Customs" s-a ajuns la 35 ron taxe vamale :))
(http://tapatalk.imageshack.com/v2/15/03/02/f92cea56dd5d385c7d63db1ae165c38b.jpg)
(http://tapatalk.imageshack.com/v2/15/03/02/f9ee14777fa3c8703dbe3d0dfdd0e13c.jpg)
no acuma incepe distractia :)
Inca nu...
Mai avem cateva pe lista de To Buy / To Do inainte de a urca Ecu pe masina
Program de weekend ...
(http://i59.tinypic.com/20i76u8.jpg)
Crazy ... No comment !
Asa e cand n ai ocupatie...
Sunt curios ce mai urmeaza😁
Neoanele ;D :D....
Suspensia / articulatia e aproape gata. Mai lipsesc cateva rigidizari...
Wishes list e inca lunga!
Nu pune neoane.Sunt prea main stream.Baga banda led.Consuma si mai putin. ;D
Mai bine instalatia de pom, ca oricum va fi nefolosita pentru urmatoarele 9 luni :D
Felicitari Dani! Tine-o tot asa si la intalnirea de 6 ani ai sa iei premiul pentru burlacul cu cel mai smecher GC
Haha.Buna asta...
Dani, merci de tura! Foarte misto Pluto. Cum ai zis si tu, zici ca esti cu kartul... Sa ai grija de el si sa-i rupi dintii maxim
Ket merci mult. Poate data viitoare avem mai mult timp si spatiu...
Hai ca abia astept tura promisa, poate cand mergem la geometrie. Ziceai ca o vrei si mai rigida ?!
Nu cred ca se poate mai rigida ... ;) prefer sa o mai ridic un pic si sa ajung la setarea pe duritate undeva la 20 din 30...
(http://s12.postimg.org/mp3lh205p/IMG_4880.jpg) (http://postimg.org/image/bpie5g9qh/full/)
image upload with preview (http://postimage.org/)
(http://s11.postimg.org/6p4ejoqsj/IMG_4885.jpg) (http://postimg.org/image/a8qc9hti7/full/)
image uploading (http://postimage.org/)
Misto!!!
eu zic ca e prea jos si o sa iti atinga ...
Si mie mi s-a parut cam dura. Daca o vei tine numai pentru track day, probabil ca va fi ok. Dar daca o mai plimbi si pe doamna cu ea, ar trebui sa o faci mai moale
Asa a fost si la mine.Dar eu am mai saltat-o cate 1cm pana cand a fost ok.Dar eu am si distantieri de 2cm la roti.Si tot atinge.
Brr... cosmar! :)
Imi aduc aminte de momentul in care s-a lasat un amortizor SLS si aveam salupa cu zgomote pe spate.
Caseta de directie cum se prezinta ?
Multi incep sa o auda dupa ce merg o perioada cu suspensii sport.
Asa e.Asta am uitat sa spun.Se cam f... caseta pentru ca e cam fortata.Plus ca nu mai bracheaza rotile la fel de mult.Merge de zici ca esti cu kartul.Intoarcerea in 3 miscari e defapt in vreo 7...
Am plecat de la cat de jos am putut si la prima proba atingea si pe fata si pe spate.
Am bagat-o in garaj si am mai ridicat-o 5mm fata - spate si am setat-o pe duritate maxima.
Acum atinge doar fata...
Am bagat-o iar in garaj... Si am lasat-o acolo... :D
Pana sambata o sa ii mai dau cativa cm...
Celalalt ce distanta e la tine intre centrul rotii si aripa???
Sa aduci o ruleta cand vii akas si masori la mine ! Eu am dat suspensia cusco de la gc meu ridicata la max :)) si abea bagi 2 degete intre roata si aripa !
Masor maine.Dar eu am pe spate aripile roluite si pe fata strambe de la cat a atins.Iti dau eu un reper ceva.
34cm la Victor... Sa vedem la Celalalt...
Cand am jante nu am anvelope... Cand am anvelope nu am jante...
Jantele de vara au plecat la vopsit dar au venit anvelopele
(http://s27.postimg.org/mupeotj1v/image.jpg) (http://postimage.org/)
upload photos (http://postimage.org/)
(http://s22.postimg.org/ze4341u1d/image.jpg) (http://postimage.org/)
imagehosting (http://postimage.org/)
Parca d astea am si eu.Sau p acolo.
Multumit de ele???
Da.Sta bine pe ele in parcare.
Dani, eu zic sa le dai inapoi. Nu poti sa mergi la consum cu ele... :D
Jantele pe 18" sunt in asteptarea anvelopelor...
(http://s29.postimg.org/evsbajpfr/image.jpg) (http://postimage.org/)
(http://s29.postimg.org/holiukps7/image.jpg) (http://postimage.org/)
free pic (http://postimage.org/)
frumoase jante :) sa le vedem pe masina !!!!
Mie nu mi plac.Si 18 e cam mult pe GC.Eu zic ca te intreci cu gluma si te propun pt un BAN.Esti prea arogant.Pai in stilul asta urmeaza 22'...sau mai rau jante de autobuz.Ia baga ti mintile n cap.
Stiam eu ca ar fi trebuit sa le fac cu un pic de mov... :D
Malakay ar trebui sa ne spuna cum se comporta GC-ul lui cu jante pe 18".
@Ket - stii bine ca noi circulam regulamentar de drumurile publice... Numai la consum ;)
@Rzw75 - mersi mult... Daca nu imi place cum se misca Impreza cu ele o sa fac o proba si pe Forester
Set-up strada : 17" Team Dynamics Motorsport + Yokohama Advan Sport 215/45/17
Set-up track : 18" Inovit + Bridgestone Potenza Adrenaline RE002 225/40/18
Intra jante pe 18 la GC?
Din experienta lu' Malakay... Da
Oricat am incercat si masurat la coupe fara sa modific aripile (nu am voie la grupa A la coasta) nu intra jante pe 18
nu trebuie sa modifici nimic intra 225/40/18 fara stres
La anvelope de curse nu exista dimensiunea asta :)
Pe 18 diametrul anvelopei este de 650....si nu mai intra fara modificari...
Acum eu merg cu 200/625/17 (echivalent la 225/45/17)....si sunt la limita...
Cadou de la sotie ...
(http://i57.tinypic.com/10pa9vd.jpg)
De 9 Martie?
Dar ea stie ca ti-a facut cadoul asta? :D
De 9 Martie?
:D :D stie, stie ... la sfatul ei am plusat cu 5 lire la o licitatie...
Aha.Si ea a sustinut cele 5 lire?
:D :D inca negociem
(http://s22.postimg.org/pcqpeujgx/image.jpg) (http://postimage.org/)
(http://s22.postimg.org/90gnp455d/image.jpg) (http://postimage.org/)
(http://s22.postimg.org/8mfbpil1t/image.jpg) (http://postimage.org/)
(http://s22.postimg.org/fblv5j6dt/image.jpg) (http://postimage.org/)
Mai trebuie ridicata :'(
Ai reusit sa termini pana la miezul noptii sau a mai durat? Chiar astept sa imi spui cum se comporta bridgestone-urile. Desi pe 18" pe un GC, chiar nu are ce sa nu fie bine. Acum ai grija la caseta de directie.
Nu am mai stat sa o ridic.
Sambata avem programare la reconditionat caseta de directie si pompa de servo. O sa continui atunci cu reglajul de suspensie...
.. reconditionat caseta de directie si pompa de servo...
Se face asa ceva pe la noi? Cine/unde?
Eu am sa incerc la http://www.servicepst.ro/
Par destul de seriosi si dispusi sa lucreze si dupa program... Sper si calitatea sa fie pe masura asteptarilor!
Sa mai ai o caseta de schimb totusi.Stiu ca nu prea ies reconditionarile pe casete de subaru.Eu am facut una prin '44 si mai rau am stricat o.Si erau unii specializati pe asta.De prin harghița parca.
Ce problema ai la pompa de servo?
Una noua e aproape 13.000 lei la SMT... deci? Caut caseta de directie pentru Pluto.
Pompa de servo a inceput sa scoata un zgomot la bracare maxima...
Zgomotul de bracare maxima nu cred ca e din cauza ca ar avea ceva pompa de servo ???, la mine zgomotul asta il face la rece de cand am luat masina. eu am un bizait din pompa mai tot timpul de ceva vreme
Salut. si pompa de servo de la foresterul meu a inceput sa faca la fel si am comandat un o-ring. am gasit o filmare cu problema ,poate ajuta la ceva...
si a mea scoate un tziut la bracare maxima. dar nu`mi bat capul deocamdata ;D
Hot hot hot
(http://s10.postimg.org/urokz8cop/image.jpg) (http://postimage.org/)
free upload pictures (http://postimage.org/)
Deci ai treaba in weekend :)
Nu, nu... E pentru mai tarziu... Pregatim ceva frumos...
Si au venit si jantele pe 17 de la vopsit..
(http://s22.postimg.org/3yrks325d/image.jpg) (http://postimage.org/)
(http://s22.postimg.org/98wjjdme9/image.jpg) (http://postimage.org/)
(http://s22.postimg.org/7fp1hbbtt/image.jpg) (http://postimage.org/)
screen cap (http://postimage.org/app.php)
Am un avocat bun daca ai nevoie ;)
Cred ca un popa ar fi mai bun... :D
Chiar si asa.Tot iti trebuie avocat.
Ii trebuie un barou intreg :D
Si cateva poze de dimineata...
(http://s13.postimg.org/6jbpf6xev/image.jpg) (http://postimage.org/)
(http://s13.postimg.org/6i1rlrvl3/image.jpg) (http://postimage.org/)
(http://s13.postimg.org/kag6hemcn/image.jpg) (http://postimage.org/)
free photo hosting (http://postimage.org/)
Sa mi bag.... :o
Cu numarul ala cel putin nu te opreste nimeni pe strada ;D
Dupa ce termina si cu motorul nu o sa-l opreasca ca nu o sa-l prinda ;) Desi nici acum nu prea-l prind multi...
Jantele de strada au fost montate...
(http://s2.postimg.org/bamnhx83d/image.jpg) (http://postimage.org/)
(http://s2.postimg.org/5xxt3sk6x/image.jpg) (http://postimage.org/)
20mb image hosting (http://postimage.org/)
Sa nu exageram... Mersi mult...
Nu am mai scris de foarte mult timp pe aici ...
(http://i58.tinypic.com/2ajdglu.jpg)
(http://i57.tinypic.com/e0mjvp.jpg)
(http://i59.tinypic.com/2ed36o5.jpg)
Si daca tot am reusit sa spargem cutia am facut si revizia si altele pe langa :
- filtru ulei
- Motul 300V 15W50
- serpisorii montati
- ulei cutie si grup Motul Gear Comp 75W140
(http://i62.tinypic.com/2ik4f4n.jpg)
(http://i60.tinypic.com/21brp1u.jpg)
(http://i62.tinypic.com/zuj9ds.jpg)
(http://i58.tinypic.com/2zsww7p.jpg)
Rezultat :
(http://i57.tinypic.com/e84qxv.jpg)
Si am aflat la ce mai e bun eleronul :
(http://i59.tinypic.com/2m2aqtt.jpg)
Ma poate ajuta cineva cu bucsi poliuretanice pentru timonerie?
Bun bun. Ce cutie ai pus? Tot de WRX 5MT?
Nu ai dat si tu semn ca te duci la circuit... :(
Si rezultatul rezultatului? ;D
Si merci mult de tot pentru 75W140! Si cu livrare la domiciliu...
@mihai : am pus cutia care a fost pe KDR ... Iar pe circuit am fost pentru a ma obisnui cu masina... De abia astept urmatorul track day. ;) poate ne apucam si de motor
@ket : nu ai pentru ce. Oricand! ;)
arata bine cotetul, man inca o data merci si eu de ajutorul cu 75w140 ai fost salvator de vieti ;)
oricand man, bafta azi !!!!
Daca tot a fost soare, am iesit la plimbare
(http://s3.postimg.org/jcyr621kj/image.jpg) (http://postimg.org/image/3rhfm3pm7/full/)
image hosting 10mb limit (http://postimage.org/)
Si daca tot vine Craciunul ...
(http://s29.postimg.org/51j4xmzjr/image.jpg) (http://postimg.org/image/mrktiod4j/full/)
(http://s29.postimg.org/bqpodnkvr/image.jpg) (http://postimage.org/)
Tot mai bagi in ea? Nu iti ocupa suficient galeata?
Fiecare cu drogul lui...
Asta e un alt inceput! Avem planuri mari pentru saptamana viitoare!
Urcam pe masina admisie, injectoare, ecu cu boost controller...
Sper sa avem timp sa schimbam si puntea fata cu caseta de directie.
Oricum daca nu se vinde in iarna asta la primavara o chelim si o transformam de circuit.
Junky!
Heeeelp!!! Ma poate ajuta careva cu un rezervor de servo??? :'(
Si cum nu putem sta cuminti ...
Before and after :
(http://s22.postimg.org/v5cz2vejl/28_12_2015_before.jpg) (http://postimg.org/image/idyswd4rh/full/)
(http://s22.postimg.org/3w1loddgh/28_12_2015_after.jpg) (http://postimg.org/image/5nukj9wt9/full/)
Poti sa ascunzi venele.Tot o sa bagi ca nebunul.Junky!
De acord cu Serban. Esti mai virusat decat virusul de pe forum. Succes!
;D asa o fi ... dar merita si Pluto un mic cadou
p.s. Mersi mult Malakay!!!!
before & after
(http://s9.postimg.org/ja4dxzdjj/DSC_0009.jpg) (http://postimg.org/image/qdc9dliyz/full/)
(http://s9.postimg.org/5ihjcsv2n/31_12_2015.jpg) (http://postimg.org/image/bjf89vhor/full/)
si o mica aroganta ...
(http://s13.postimg.org/t9spq3l13/DSC_0098.jpg) (http://postimg.org/image/hxg48bcc3/full/)
image search (http://postimage.org/)
LA MULTI ANI TUTUROR!!!!!
Misto Vitara :D
cu placere ... sper sa mai lucram la ea la vara :)) cand o sa fie 30 grade minim !
Cine face si desface, toata ziua are ce face ... ;D ;D ;D Din pacate a vent frigul si zapada si a trebui sa ne oprim ...
Si mai avem ceva surprize bine ascunse ...
(http://s2.postimg.org/jgsxuh1ix/20160113_210527.jpg) (http://postimage.org/)
(http://s2.postimg.org/c287fu515/20160114_214519.jpg) (http://postimage.org/)
(http://s2.postimg.org/62kgc6k8p/20160114_214622.jpg) (http://postimage.org/)
(http://s2.postimg.org/k51sdf08p/20160115_193855.jpg) (http://postimage.org/)
Andea, ceva sugestii? ;)
inafara de citit manualul de la apexi ? parca ti-am trimis link ... sau nu tie ?
sau daca vrei un plan mai "structurat" in ideea in care vrei sa te distrezi cu setarea :
1. vezi/testeaza care este metoda de monitorizare a knock-ului cu apexi-ul sau fara (cablu vag+ecu explorer de exemplu https://code.google.com/archive/p/ecuexplorer/downloads)
2. lasi preventiv timingul mai jos cu 3-4 grade
3. cu boost-ul jos (wastegate pressure) si verificand cu un wideband setezi AFR-ul, te asiguri ca pe boost esti in zona 11-11.2 afr fara sa ai knock bineinteles - daca ai knock lasi timingul mai jos pe zonele respective
4. cresti boost-ul in pasi spre valoarea maxima dorita (presupun ca folosesti ceva MBC) verificand tot timpul ca nu ai knock si afr-ul ramane in zona de la punctul 3 - pe zona unde creste boost-ul s-ar putea sa ai nevoie de ajustari ale afr-ului pentru a ramane in 11-11.2
5. cu boost-ul si afr-ul setate la punctele anterioare incepi sa cresti in pasi timingul pana incepi sa ai knock, cand apare knock-ul dai timingul inapoi cu 2-3 grade si ... gata :)
este clar o lista foarte succinta si pe repede inainte dar in linii foarte mari cam asta se intampla ...
LE: acum citesc si eu manualul :)
LE2: http://www.paulr33.com/powerfc-faq/powerfc-faq.htm#index
Si cum ne mananca rau ... incercam sa ne scarpinam cu folos ...
Sa raman pe side feed sau sa folosim conversia la top feed ... Ce parere aveti? Avantaje / dezavantaje?
(http://s27.postimg.org/8ivkxmd9v/image.jpg) (http://postimage.org/)
(http://s27.postimg.org/96zu2tmlv/image.jpg) (http://postimage.org/)
(http://s2.postimg.org/5np7ppfih/image.jpg) (http://postimage.org/)
(http://s2.postimg.org/7ppp3ydhl/image.jpg) (http://postimage.org/)
(http://s2.postimg.org/5mf9wadop/image.jpg) (http://postimage.org/)
simplu ... momentan nu ai nev de injectoare mai mari !
ce simplu mi-ai taiat craca ... ;D
Cum spuneam - UN NOU INCEPUT!!! Planuri pentru viitorul apropiat ...
1. Rampe injectoare CDF Racing side feed - comandate
2. Regulator presiune benzina, furtune si fitinguri -6 - comandate
3. Distantiere phenolice 8mm - comandate
4. Garnituri admisie - comandate / venite
5. FMIC - comandat
6. Blow Off Forge - comandat
7. Distributie - de comandat
8. Kit relocare acumulator - de comandat
:o
crazy little fucker... ce pot spune ...
Poti sa-i sui "SUCCES LA DIVORT!" :D
Bafta cu proiectul!
Mama avocatilor sa fie si nu mainprimesti nimic la partaj.
:D :D mai e pana acolo ... nu mult dar mai e ...
Ce poti spune ??? Ca de abia astepti sa lucram la masina ... ;D
Au inceput sa apara ...
(http://s28.postimg.org/qgwaekzzh/image.jpg) (http://postimage.org/)
(http://s28.postimg.org/m6hmizuwd/image.jpg) (http://postimage.org/)
Am inceput sa stricam... si ne pricem de minune... asta asa de Valentin!!!
(http://s8.postimg.org/k0t0wxro5/IMG_20160214_WA0002.jpg) (http://postimage.org/)
host images (http://postimage.org/)
(http://s10.postimg.org/cagonq7ll/20160214_122920.jpg) (http://postimg.org/image/69izqnkz9/full/)
image free hosting (http://postimage.org/)
(http://s27.postimg.org/pb5uh191v/20160214_123006.jpg) (http://postimg.org/image/vc3je3vnz/full/)
(http://s11.postimg.org/f43sunfqb/20160214_124513.jpg) (http://postimg.org/image/f43sunfq7/full/)
upload pictures online (http://postimage.org/)
Bravo, bravissimo! Sa fii atent cum desfaci si pui la loc iar daca ai nevoie de cineva care sa te-ncurce te rog sa-mi spui si vin imediat.
Vedem noi cat de tare o stricam... te astept in weekend la o bere...
Deja tremur de nerabdare, emotii si convulsii... Te rog sa-mi dai pe PM coordonatele si vin negresit. De care bere consumati, ca sa stiu daca trec pe la manufactura de bere artizanala sau fac o halta la Metro?
Spor! Vezi sa nu ramana piese... :D
Ce ramane iese la mezat.
Mai face un Subaru, ca are putine
Inca nu s-a intamplat .. Dar pentru toate exista un inceput :D :D :D
Spor la treaba!
Salut Daniel! M-am adresat corect sau trebuia sa ma formalizez cu Excelenta Voastra, Inalpreasintite Daniel? Sa nu cumva sa fac vreo greseala...
Cum a decurs astazi procedura de upgrade? Ce ne poti spune despre integrarea CDF Racing, FMIC. Blow of Forge, TD05H si PFR69-122BLK pe Pluto (habar nu am ce inseamna da' vreau sa dau impresia ca sunt conectat la stiinta si tehnologie)?
Am constatat ca nu m-ai contactat pentru a te ajuta, de unde deduc ca nu ai avut nevoie de vasta-mi expertiza tehnica iar berea artizanala iti displace ori vremea de afara impunea alte lichide.
Sa ai spor in tot ceea ce mesteresti si sa ne auzim cu bine!
;D :D nu te-am contactat pentru ca nu am apucat sa lucrez la masina...
Musafiri, fini, ziua soacrei... Etc. Iar azi : Spalare de pacate, nevasta... :D
Incep sa apara...
(http://s18.postimg.org/4a1lvecex/20160229_161347.jpg) (http://postimg.org/image/h1fs1wm6t/full/)
upload (http://postimage.org/)
Daca scria si nike pe ele era ce trebuie ;D 8)
Si cum nu putem sta cuminti cand avem cateva ore libere...
(http://s31.postimg.org/spjfk9usb/20160424_084651.jpg) (http://postimg.org/image/t2atqgd1z/full/)
image upload no compression (http://postimage.org/)
(http://s31.postimg.org/iw7qnyfx7/20160423_095355.jpg) (http://postimg.org/image/wd4p6tq8n/full/)
screen capture (http://postimage.org/app.php)
Dilema cea mare o sa fie mereu Galeata sau Pluto? Ambele sunt de fun. Super fun!
Pluto fun, Galeata strada
Si ultimele piese din puzzle... cu exceptia unui siliconic de 63
(http://s32.postimg.org/jhkxj5p39/20160513_181932.jpg) (http://postimg.org/image/48v05dvep/full/)
(http://s32.postimg.org/u3acz6v5x/20160513_193800.jpg) (http://postimg.org/image/rypzy3tj5/full/)
img host (http://postimage.org/)
(http://s32.postimg.org/b4zyjv8lh/20160513_193856.jpg) (http://postimg.org/image/5429mslz5/full/)
image hosting 12mb (http://postimage.org/)
Acum trebuie sa ne facem timp sa le montam...
Ne apropiem de final ...
(http://s33.postimg.org/95jmuevi7/Pluto_BOV.jpg) (http://postimage.org/)
free photo upload (http://postimage.org/)
Mai e un pic ... Ne chinuim la decupat/potrivit bara fata ...
(https://s31.postimg.org/eog1jyyrv/20160615_214737.jpg) (http://postimage.org/)
(https://s31.postimg.org/tyfwr5ua3/20160615_214749.jpg) (http://postimage.org/)
Tragem tare... nu mai avem rabdare...
(https://s32.postimg.org/wiivk2m9x/20160627_220809.jpg) (https://postimage.org/)images upload (https://postimage.org/)
Azi am inceput sa studiem in detaliu manualul de la Apexi...
Tare complicat mai e... IGN INJ O2 ... Dar cu ceva vointa si ajutor de la Cluj o sa ii dam de cap...
ce se poate cu placere :)
GC-ul mi se pare cel mai bad ass model in continuare. Pana si aspiratele mici au o privire de golan incruntat.
E gata pana in weekend? O vedem in actiune?
Azi am dat o tura de cartier... Mai avem ceva finisaje de facut : geometrie, semislick-uri, ceva soricei/coliere de pus, furtunasele de vacuum de pus pe definitiv...
Asteptam sa vina si un FC Datalogit sa putem sa ne jucam cu laptop-ul pe ecu ca pe paletuta ne ia durerea de cap...
(https://s32.postimg.org/tn88nviqt/20160702_113914.jpg) (https://postimage.org/)photo sharing (https://postimage.org/)
Azi am reusit sa montam cauciucurile de vara, sa ii facem geometria... si sa dam si o scurta tura... prea cald fara AC...
Ascunsa la umbra...
(https://s32.postimg.org/6vbf0q5kl/20160703_111934.jpg) (https://postimg.org/image/fdkv52c35/)image hosting 15mb (https://postimage.org/)
Ascunsa la umbra...
...de ochii cui?
In ce hal arata anvelopele alea ::)
Si cat de bine se lipesc de asfalt ;D :P ... Din pacate a trebui sa setez suspensia pe duritate maxima sa nu imi atinga pe spate ... In rest sa vedem in cati km se tocesc ...
Lorian ... ascunsa doar de soare ...
Ce cur mișto are! ;)
Din nou zambete tampe pe fata mea dupa o plimbare de juma de rezervor.
(https://s32.postimg.org/hlvneieed/20160714_210526.jpg) (https://postimages.org/image/69j1wq5pd/)image upload without registration (https://postimage.org/)
(https://s32.postimg.org/re97iglh1/20160714_211449.jpg) (https://postimages.org/image/895y8p6sx/)capture (https://postimage.org/app.php)
(https://s31.postimg.org/yvlod1nu3/20160714_210242.jpg) (https://postimg.org/image/vbzqn8l47/)temp image upload (https://postimage.org/)
In continuare una din cele mai misto masini de pe forum. Ma bucur ca nu te-ai despartit de ea. La cat mai multe zambete! Atat de multe, sa ai sa imparti si cu altii :D
Apexi ala regleaza largimea zambetului? :D
Da da da ... incet incet ...
In weekendul asta am facut greseala sa ma duc Pluto la cumparaturi ... Un pepene spart si doua cutii de bere bubuite ...
(https://s32.postimg.org/52o9xocg5/20160717_125401.jpg) (https://postimg.org/image/7k014xwch/)
(https://s32.postimg.org/5gplx9wjp/20160717_130937.jpg) (https://postimg.org/image/leybneqrl/)
(https://s32.postimg.org/cl7f6b3t1/20160717_193203.jpg) (https://postimg.org/image/y7mfnc2dd/)
(https://s32.postimg.org/4tqp7qznp/20160718_071148.jpg) (https://postimg.org/image/mwjryyvi9/)
Desi nu ti-am spus-o, ti-o repet: berea se cumpara la sticla...sau se consuma la prieteni caci unii dintre ei au butoi si dozator in curte... ;D
Duminica viitoare te asteptam cu grataru' incins si hectolitrul de bere rece.
Sau poate mergem pe o balta ... O sa fiu Home Alone !!! :D
Cam asa arata harta stock din Apexi ... Tin sa mentionez ca a trebuit sa fac aprox. 244 poze cu telefonul sa le pot pune intr-un amarat de excel ... :'(
Inca studiem definitii si multe altele (mai bine studiam japoneza) ... Pana ii dam de cap ... mergem la relanti :'(
Acceleration injection time
(https://s31.postimg.org/4ni8i26i3/Acc_Inj_Time.jpg) (https://postimg.org/image/o5cvy03fr/)
Air flow
(https://s31.postimg.org/x1no1xu23/Air_flow.jpg) (https://postimg.org/image/wc4vpktif/)
Boost pressure set-up 4
(https://s31.postimg.org/vnw16musr/Boost_pressure.jpg) (https://postimg.org/image/wq67p6dlz/)
Cranking
(https://s31.postimg.org/fe5v3qk4r/Cranking.jpg) (https://postimg.org/image/njnx1w8dj/)
Ignition / Injection Correction
(https://s31.postimg.org/6keymmx63/Ign_Inj_correction.jpg) (https://postimg.org/image/ppi7webtz/)
Ignition map
(https://s31.postimg.org/8dhvayicr/Ign.jpg) (https://postimg.org/image/h8iplh753/)
Injection original fuel correction
(https://s31.postimg.org/pfapd1x7v/Inj_fuel_correction.jpg) (https://postimg.org/image/g7igwcq5j/)
Injection map
(https://s31.postimg.org/k55qlrcyz/Inj.jpg) (https://postimg.org/image/mmhht0wvb/)
Injector set-up
(https://s31.postimg.org/4xpr1el4b/Injector.jpg) (https://postimg.org/image/ut9hklmxz/)
Water temp correction
(https://s31.postimg.org/uhwmlkvvv/Water_temp_correction.jpg) (https://postimg.org/image/qyaovrt5z/)
Azi am reusit sa imi fac curatenie in laptop-ul de scarbici ... Si surpriza ... Tinand cont de faptul ca mi-am pierdut toata informatia din calculatorul de acasa din cauza unui virus fain ...
History :
1. Achizitia :
(https://s3.postimg.org/oelhqvaar/image.jpg) (https://postimg.org/image/x9mc1dz33/)
(https://s3.postimg.org/c18njykmb/image.jpg) (https://postimg.org/image/hpeyauoyn/)
(https://s3.postimg.org/xp2785aeb/image.jpg) (https://postimg.org/image/nrr6f32sf/)
(https://s3.postimg.org/3lnog774z/image.jpg) (https://postimg.org/image/th7eze8yn/)
(https://s3.postimg.org/vn1ptwcf7/image.jpg) (https://postimg.org/image/6h0rn2b4v/)
(https://s3.postimg.org/arffing83/image.jpg) (https://postimg.org/image/40yy97t27/)
(https://s3.postimg.org/6jkn9wesj/image.jpg) (https://postimg.org/image/66t93pwin/)
(https://s3.postimg.org/43itw1wpv/image.jpg) (https://postimg.org/image/wt5psp0pr/)
(https://s3.postimg.org/av98ywlpf/image.jpg) (https://postimg.org/image/u0ci8o0db/)
(https://s3.postimg.org/9u909s4pv/image.jpg) (https://postimg.org/image/eswiob8in/)
(https://s3.postimg.org/w7gqwl5nn/image.jpg) (https://postimg.org/image/4k41ihkgv/)
(https://s3.postimg.org/t1w56dn1f/image.jpg) (https://postimg.org/image/ju3wpofz3/)
(https://s3.postimg.org/v7v1emfvn/image.jpg) (https://postimg.org/image/wmwm3cgyn/)
(https://s3.postimg.org/oiohylujn/image.jpg) (https://postimg.org/image/ujm6voh5r/)
(https://s3.postimg.org/3n27ncycj/image.jpg) (https://postimg.org/image/7w6xpj1lr/)
2. Prima plimbare :
(https://s4.postimg.org/q5ua2kw19/image.jpg) (https://postimg.org/image/js56zbr55/)
(https://s4.postimg.org/5mzdxii3x/image.jpg) (https://postimg.org/image/8h2jayka1/)
(https://s4.postimg.org/mowtdcmct/image.jpg) (https://postimg.org/image/isjhhd1d5/)
(https://s4.postimg.org/i4amyf2nh/image.jpg) (https://postimg.org/image/mdfd0l5wp/)
restul ... in episodul 2 ...
Daca la ralanti ofera tot 103 dB ca si "Galeata Albastra" te invit sa mai facem o tura prin cartier, dupa miezul noptii...
Tu chiar vrei sa fiu batut si dat afara din Paradis... :D
Felicitari pentru pasiune, rabdare si perseverenta. Ai reusit sa-ti "construiesti" doua masini de vis. Relaxare maxima dupa o zi grea la birou sa dai o tura sau sa surubaresti ceva la ele :)
Ca si o opinie personala, eu nu as fi renuntat la eleronul vechi. Parca este incompleta fara el.
Mai mult imi place eleronul asta decat "masa de calcat" ... Gusturile astea ... :D
E incredibil .......
17.08.2016 20:04 Sosit in Romania - BSI Bucuresti
20.08.2016 10:48 Primit de la expeditor - BSI Bucuresti
20.08.2016 12:04 In prelucrare - BSI Bucuresti
20.08.2016 20:34 In prelucrare - BSI Bucuresti
22.08.2016 15:43 In prelucrare - BSI Bucuresti
22.08.2016 15:48 In prelucrare - BSI Bucuresti
23.08.2016 13:07 In prelucrare - Oficiul Postal Bucuresti 6
29.08.2016 12:15 Avizat - Oficiul Postal Bucuresti 6
Cred ca ai gresit rubrica, mai bine zis trebuia postat la "Bancul zilei".
Aha, nu e banc, e realitate?
Cand ne vedem in particular iti voi arata si eu ceva asemanator dar mult mai tragic-comic.
Intr-un final ... ne-am apucat de treaba ...
(https://s16.postimg.org/akgwkwxgl/image.jpg) (https://postimg.org/image/5lte6dtnl/) free photo hosting (https://postimage.org/)
Nu am mai scris de ceva timp ...
Vineri seara dupa ce am reusit sa rezolvam cu micile pierderi de ulei pe la fitingurile din modina catre racitorul de ulei ... la o mica tura am reusit sa mai bubuim o garnitura ...
(https://s22.postimage.org/l3ppz6oqp/20161021_173914.jpg) (https://postimage.org/image/oak9it96l/)
(https://s22.postimage.org/aux8td0ox/20161022_005301.jpg) (https://postimage.org/image/yyo0hnj5p/)
(https://s22.postimage.org/j1p8kxqrl/20161022_144806.jpg) (https://postimage.org/image/co05holvh/)
Cu aceasta ocazie am reusit sa facem up-grade la ceasul de AFR (am trecut la Innovate), conectat direct si in permanenta cu FC Hako, ECU si laptop ...
Si acum sa inceapa distractia ...
nu s a vandut pluto? ;D
Inca nu ;D
(https://s12.postimg.org/vxc27y7kt/20161029_200116.jpg) (https://postimg.org/image/kxquwch5l/)image url upload (https://postimage.org/)
Pluto is alive?
Is alive ... de foarte mult timp.... ne jucam la soft. Cand avem timp :)
Azi am reusit sa ne pregatim si noi de iarna... gume de iarna si suspensia inaltata cam 1.5cm si o mica geometrie...
(https://s13.postimg.org/jhgbaqy6v/20161119_090932.jpg) (https://postimg.org/image/fxudkxvgz/)image upload no compression (https://postimage.org/)
Parcata asa cum trebuie ... langa un frate mai mare ... :D
(https://s11.postimg.org/4fvna36df/20161119_194410.jpg) (https://postimg.org/image/ke4d080lb/)capture screen (https://postimage.org/app.php)
Asteptam zapada....
Nice!
Da' eu am o grija: FMIC-ul ala, nu risca sa sufere sever de la diferite chestii de pe drum??
Bullbar cromat!i dare u! ;D ;D ;D
De curiozitate, la regimul de functionare in gol al motorului inregistreaza aceeasi acustica de 103dB pe care i-au "savurat" vecinii mei la orele doua in miez de noapte sau poate mai mult?
Sa speram ca nu intalnim nimic in cale mai inalt de 15cm... :D
Heli acustica este una decenta... din punctul meu de vedere si al vecinilor mei :D
Pana nu vii in cartier sa dam o tura la miez de noapte nu te cred :P
venim ... venim ... poate apucam si vreo 2 ore de pescuit ;D
Pe langa faptul ca inca mai avem grija de EL, Pluto a mai primit si unele mici cadouri ...
Jante OZ Alleggerita 17*7.5
(https://s2.postimage.org/m13fcwap5/image.jpg) (https://postimage.org/image/9z81ir1gl/)
(https://s2.postimage.org/m2dd6bcix/image.jpg) (https://postimage.org/image/knbshlbfp/)
Transmisie in 6 trepte care deja a intrat in procesul de restaurare ... THX MALAKAY ...
(https://s2.postimage.org/3ugxdwc15/Fuzete_1.jpg) (https://postimage.org/image/hbdvwrmcl/)
(https://s2.postimage.org/dkr1rlhdl/Etrieri_1.jpg) (https://postimage.org/image/4cytawab9/)
(https://s2.postimage.org/661pz7vi1/Etrieri_2.jpg) (https://postimage.org/image/c6zewai45/)
Curatare chimica ... si vopsea 3 in 1 ...
(https://s2.postimage.org/r6rrk4z09/Fuzete_1b.jpg) (https://postimage.org/image/sltc8v039/)
(https://s2.postimage.org/7q71xm3w9/Fuzete_2.jpg) (https://postimage.org/image/vh6ffq439/)
(https://s2.postimage.org/xvyb05kc9/Planetare_1.jpg) (https://postimage.org/image/fgdu2r67p/)
(https://s2.postimage.org/xuod6qiih/Planetare_2.jpg) (https://postimage.org/image/y7frcx0s5/)
Frumos rau cotetu! Ma bucur ca nu l-ai uitat intr-un colt, avand in vedere ca ai si galeata
Multumesc mult ... nu aveam cum sa il uit ;)
Spalata, lustruita ...
(https://s26.postimage.org/q7076q2w9/image.jpg) (http://postimage.org/image/f7ezv4ch1/)
(https://s26.postimage.org/k7cg32i3t/image.jpg) (http://postimage.org/image/dtncztd7p/)
In curte la RAR ... in asteptarea ITP-ului ...
(https://s26.postimage.org/bcgnpnzmx/image.jpg) (http://postimage.org/image/isfxbgnc5/)
Si acum ne apucam de treaba ...
(https://s26.postimage.org/9968hzzu1/image.jpg) (http://postimage.org/image/3kzxr3vhh/)
Tot imi place cateaua :-[ :-[ :-[ :-[
Si cum nu putem sta cuminti ... a inceput distractia ...
(https://s26.postimage.org/mz817nt0p/20170925_211002.jpg) (http://postimage.org/image/zdut7zkit/)
(https://s26.postimage.org/8u285ujzd/20170925_211013.jpg) (http://postimage.org/image/c0wrph4f9/)
(https://s26.postimage.org/nenwef4bt/20170925_212027.jpg) (http://postimage.org/image/e6vnxpx9h/)
Ce diametru are bara antiruliu? Vad c-ai setat-o pe "hard"...
22mm fata si 24 mm spate
Cu mentiunea ca fugea de fund imediat chiar fara acceleratie, pe cand eu cu WRX-ul nu reuseam de nici un fel sa o fac sa plece. Asta daca ai acelasi setup ca la intalnirea de la Timisul de sus/jos.
Just for fun ... ;D
A trebuit tu sa pui poze cu Whiteline de 22 reglabil si sa vad ca bieletele se aseaza bine...
Iar astept salariul ca pe aer >:(
@Muttley ... cunoastem ... partea proasta e cu justificatul pieselor :-X...
@Mihai ... si vom pastra aceeasi setare de bari ... e distractiva foc ;D
Un alt weekend relaxant ...
Whiteline vs SuperPro
(https://s1.postimage.org/7t4o6xp19r/20170930_093108.jpg) (https://postimage.org/image/1wg3zx8iaz/)
Fuzete fata pregatite de a fi urcate pe masina
(https://s1.postimage.org/1wsve355n3/20170930_103048.jpg) (https://postimage.org/image/9e76kkiw23/)
(https://s1.postimage.org/36vskexfbj/20170930_135454.jpg) (https://postimage.org/image/17zlu2rwzv/)
Punte spate data jos, masina spalata bine pe dedesupt, ceara bagata prin toate gaurile ...
(https://s1.postimage.org/5d7ykcn0pb/20171001_175607.jpg) (https://postimage.org/image/8taacfwnrf/)
Puntea spate pregatita pentru a fi urcata pe masina
(https://s1.postimage.org/4sb2c7vn7z/20171001_192826.jpg) (https://postimage.org/image/155ioozuq3/)
Sper sa intre diferentialul de 6MT pe puntea de GC, mai ales ca m-am chinuit 2h sa pun bucsile poliuretanice.
Suportii aia stii ca nu prea fac fata la nesfarsit unei bare de 24... :/
Daca mergi 100% in regim de circuit sunt sigur ca nu ... o sa vina si vremea lor sa fie schimbati ... ;D
lookin good !
Cine ma poate ajuta cu praguri de GC imprumut ??? ... max 1 saptamana sa le copiez in fibra ...
Se mai pune problema? Doar sa ajungi sa le dam impreuna jos
Multumesc mult ... Cand as putea veni?
dece vrei sa le faci din fibra ? nu e mai usor sa iti cauti un set oe ?
Am barile modificate in partea de jos cu fibra ... si as vrea sa fac si pragurile custom sa vina la aceeasi inaltime ...
Sunt de la 9-16:00 , cand vrei disponibil sa dam o fuga sa le luam
In sfarsit au ajuns si ultimele piese din puzzle ...
1. Distributie RCM
2. Rampe injectie cu conversie la top feed
3. si alte mici nimicuri ...
(https://s1.postimage.org/1j37gzpf27/20171026_073335.jpg) (http://postimage.org/image/754xuuqpvf/)
(https://s1.postimage.org/37cke6e77z/20171026_074619.jpg) (http://postimage.org/image/6qyi3zgwzv/)
ultimele ? exista asa ceva ? :)
Ultimele din etapa asta ... ;)
Inca putin ...
(https://i.postimg.cc/15zgRQS2/20180314_180957.jpg) (https://postimg.cc/kDkMwLBv)
(https://i.postimg.cc/G218bT3x/20180217_111311.jpg) (https://postimg.cc/PL2r4xwC)share image (https://postimages.org/)
(https://i.postimg.cc/C1HZ5MzT/20180303_091504.jpg) (https://postimg.cc/bDrYFhx3)
(https://i.postimg.cc/3NtdjLXt/20180303_091512.jpg) (https://postimg.cc/SYzSkft9)
Jantele au 7.5" latime?
De unde ai luat rampili?
8j si cadou ...
Si nu ti se par usor cam mari 235-urile pe 8 inchi?
Edit: de fapt vad ca-s semislicuri, iar astea au flancurile mai rigide.
Nvm :)
nu sunt mari 235 eu vreau sa cumpar pt jantele de pe forester care sunt tot 8 j 245/45/18 8) O0
235 sunt limita maxima ptr 7J
@malakay: ce Et au jantele alea? Nu risti sa atinga cu 245?
pls delete
la forester sper ca e loc :) o sa fac niste probe :o
Eu aveam pe 9J si 8.5 J 245/40/R18
La Skoda si parca Ford din fabrica latimea de 235 vine pe 7J, deci inca e ok, 8 cred ca e la fix ... end of OT
Almost ready ... Aveti cumva vreun tampon / bucsa de radiator?
(https://i.postimg.cc/SR1YQNRw/20180403_171150.jpg) (https://postimg.cc/YLgCb713)
(https://i.postimg.cc/0QfJ3Cs5/20180403_170910.jpg) (https://postimg.cc/zbyBHKv4)
mmmhh, vine vine priiimavaraaa :)
arata bine ... sa inteleg ca ti-ai facut de cap de ziua ta la service :)
Doar un pic ...
A trecut aproape 1 an de la ultima postare … In sfarsit a venit vremea sa il aducem pe Pluto acolo unde vrem …
Deci ... un alt proiect a inceput de curand sa se contureze ...
Plecam de la :
(https://i.ibb.co/7vfsk1h/20181216-132708.jpg) (https://ibb.co/qBSTJr6)
Sa vedem unde vom ajunge ...
Intre timp :
1. caroseria a ramas cheala
2. am inlaturat tot ce inseamna antifon
3. am inceput inlocuirea pragurilor … un pic ruginite
(https://i.ibb.co/frBfKQ7/20190203-144644.jpg) (https://ibb.co/qmXK4xw)
(https://i.ibb.co/RQX9CFp/20190203-144649.jpg) (https://ibb.co/r5BmZjG)
(https://i.ibb.co/drhnsbV/20190203-144724.jpg) (https://ibb.co/pxmC6WM)
(https://i.ibb.co/wCwX1k5/20190203-162729.jpg) (https://ibb.co/vmQG8F0)
(https://i.ibb.co/1RJ47TK/20190209-151507.jpg) (https://ibb.co/XFkGjtp)
(https://i.ibb.co/dKfPF3V/20190210-114521.jpg) (https://ibb.co/Lp0xmqc)
(https://i.ibb.co/xsQbfSV/20190210-140405.jpg) (https://ibb.co/wL1qwND)
(https://i.ibb.co/LDwzDQd/20190224-150840.jpg) (https://ibb.co/ymTnmhF)
Urmeaza :
1. sablare caroserie
2. inlocuire :
(https://i.ibb.co/0tXD5Ch/20190209-100412.jpg) (https://ibb.co/9tv8Pbs)
3. montare body kit 22b 4doors version
(https://i.ibb.co/XpsmTk1/20190217-165342.jpg) (https://ibb.co/d62nyJF)
(https://i.ibb.co/HPYB33L/20190217-165415.jpg) (https://ibb.co/X5pjMMf)
(https://i.ibb.co/njnKkg7/20190217-165556.jpg) (https://ibb.co/vkQMzw3)
Ce bine sta pe căruciorul ala :D spor la treaba! Abia astept sa o vad cu kit-ul pus.
Si toate astea pentru o bara fata crapata... :(
In sfarsit visele mele erotice incep sa capete forma ... GC wide si swap la New Age.
E vina lui Malakay ...
Si la anu' ce mai faci?
Ii monteaza un motor electric + o baterie de tractiune transformand-o in primul GC PHEV... >:D
Interesanta idee ...
E vreo 7000$ kitul
http://www.electricsubaru.com :)
Why do such a project? For fun, of course.
Sunt curios care ar fi reactia RAR-ului la un astfel de proiect.
Le spui ?
I-ar face test dinamic sa-i determine incadrarea la noxe. :police:
@Serban (nickname prea lung) … din pacate trebuie … eu fac itp la RAR
@Pfaizzzer … mai mult ca sigur … mi-e imi faceau test de noxe la o masina de competitie …
Incet si sigur proiectul prinde contur (https://www.subarufanclub.ro/forum/index.php/topic,1517.0.html)
Caroseria a fost sablata iar tinichigiul s-a apucat de treaba (suduri pentru rigidizare si indreptat tabla in cateva locuri).
(https://i.ibb.co/Jt11TMr/20190420-135149.jpg) (https://ibb.co/9gDD0Cy)
(https://i.ibb.co/g4yX6Lm/20190420-135747.jpg) (https://ibb.co/Z2dwNpG)
Sigilant antirugina :
(https://i.ibb.co/SRb4gQd/20190426-215739.jpg) (https://ibb.co/zGpTg87)
(https://i.ibb.co/3h1Nsdz/20190426-215746.jpg) (https://ibb.co/kcK8yB1)
Cateva jucarele ... in speranta unei "tinute de drum"
(https://i.ibb.co/MNXY52z/20190413-180504.jpg) (https://ibb.co/Bs1XKzh)
(https://i.ibb.co/pKXcGhT/20190502-212857.jpg) (https://ibb.co/bvdTqbV)
Caseta de directie "2.2 turns lock to lock GpA"
(https://i.ibb.co/wJyb49W/20190430-150001.jpg) (https://ibb.co/vs1rk7P)
(https://i.ibb.co/c6Cv4c2/20190501-222557.jpg) (https://ibb.co/qNWnTMm)
Si bineinteles ...
(https://i.ibb.co/fdK80Qc/20190419-135704.jpg) (https://ibb.co/s9D53tB)
Aproape gata …
https://youtu.be/s9U8i2lmMmc
(https://i.imgur.com/S7yRN9B.jpg)
(https://i.imgur.com/e7z0nZi.jpg)
(https://i.imgur.com/EccHtph.jpg)
(https://i.imgur.com/nSO2wYu.jpg)
(https://i.imgur.com/cWL7Ooy.jpg)
(https://i.imgur.com/fsxGwyD.jpg)
Video unavailable. Nu stiu daca ai vrut sa pui si ceva pe youtube sau a fost o scapare.
Arata bine de tot masina.
Fixed?
Fixed?
Da.
frumos
Mai astept mult capota aia? :))
Incredibila munca dar pare sa fie exact ce trebuie.
De asemenea, lucreaza bine tinichigiul :) Abia astept sa vad finalul
Lucrarea este rodul muncii unui bijutier căci Gugu nu apelează decât la artiști emeriți :D
Si acum incepe partea cea mai grea … asamblarea …
(https://i.postimg.cc/prtyQKNC/01-asamblare-preliminara.jpg) (https://postimg.cc/9RJWCRQw)
(https://i.postimg.cc/Kjrj04x2/02-vopsire-1.jpg) (https://postimg.cc/ctCdHxv9)
(https://i.postimg.cc/dtwLLRjt/03-vopsire-2.jpg) (https://postimg.cc/G9gcfyfZ)
(https://i.postimg.cc/CKBKWcSJ/04-vopsire-3.jpg) (https://postimg.cc/yJKBRXJS)
(https://i.postimg.cc/15B46gv0/05-vopsire-4.jpg) (https://postimg.cc/pp92Mdby)
(https://i.postimg.cc/sg2xJVLk/06-vopsire-5.jpg) (https://postimg.cc/6yDBWNtc)
(https://i.postimg.cc/fbGbZYbs/07-vopsire-6.jpg) (https://postimg.cc/5HmJSYvK)
(https://i.postimg.cc/RZbFsk5N/08-vopsire-7.jpg) (https://postimg.cc/ZWp40DqS)
Aia e vopsea sau colant ?
Vopsea
Franele sunt si ele gata ...
(https://i.postimg.cc/qMW5BsFb/09-Frane-1.jpg) (https://postimg.cc/crMmXn0w)
Avem si distributia ... motorul e si el pe drum ...
(https://i.postimg.cc/ZRYfsV9R/10-Distributie-si-capace.jpg) (https://postimg.cc/bGMHs09c)
(https://i.postimg.cc/g0HSKf2Q/11-Grip-1.jpg) (https://postimg.cc/2q37k9v7)
(https://i.postimg.cc/ydfLMc9T/12-Grip-2.jpg) (https://postimg.cc/k6bN8VTV)
Role, intainzatoare si frane am si eu la magnetofon... ;D
Mai mult decat pasiune vad o munca de om responsabil care acorda atentie pana si celui mai mic detaliu pentru ca masina sa reprezinte un proiect de referinta. Ai sa si mergi cu ea sau este doar o piesa de muzeu?
… e doar nebunie … nimic altceva … putea fi orice altceva dar am avut doar "ghinionul" de a il cunoaste pe Malakay acum 10 ani …
Imi plac nebuniile tale. Ma rog, cui nu-i plac.
Eu nu mai stiu ce mai ai prin batatura, le-am pierdut sirul. Aveai galeata, parca o cioara, la un moment dat un 22B(?) gri, acest Pluto... FXT... ;D ;D
Eu nici nu mai vad poze in threadu tau ... vad multi bani si atat 😂
Din ce in ce mai aproape …
(https://i.postimg.cc/YSNJLHpc/1.jpg) (https://postimg.cc/zLBd44bp)
(https://i.postimg.cc/7hhcRJSD/2.jpg) (https://postimg.cc/0KgcMQtH)
(https://i.postimg.cc/nrW5fV1m/3.jpg) (https://postimg.cc/2L4T4DMj)
(https://i.postimg.cc/256pCWwF/1-Turbo.jpg) (https://postimg.cc/ZW1scCXC)
(https://i.postimg.cc/DfG9fnqD/2.jpg) (https://postimg.cc/mhbX8xpN)
(https://i.postimg.cc/3JHPdV1w/3.jpg) (https://postimg.cc/RqXPYPjr)
(https://i.postimg.cc/Wb6xr8Yw/4.jpg) (https://postimg.cc/56yPWBVX)
(https://i.postimg.cc/jSxmhfG0/5.jpg) (https://postimg.cc/YhPdrvrb)
Din ce in ce mai bine.
E dă hargint sau dîn platina? ;D
Cositor tătă zâua...
Plastic vocsit. Are la europa toate dimensiunile...
Așa e cu cei “ce” n-are. Pizmuiește.
Oricum, eu cred ca autorul e undeva in SUA și lucrează din garajul de langa casa.
De pe strada lui, cei cu Șurubaru și nu numai, “măcar” jumate vin sa isi repare mașina la el.
Radem glumim dar arata asa bine melcu ca nu l as pune pe masina. In vitrina cu ea...el...uarevăr
Printre picaturi mai lucram si la Pluto …
(https://i.postimg.cc/JnV3C07v/1.jpg) (https://postimg.cc/QBmKpXTJ)
(https://i.postimg.cc/G2FFLRH2/2.jpg) (https://postimg.cc/ftbtC67n)
(https://i.postimg.cc/3N3gWqvZ/3.jpg) (https://postimg.cc/VrHSVD4S)
(https://i.postimg.cc/hvMVm08R/4.jpg) (https://postimg.cc/sGQBd70T)
Frumy!
Bai … au disparut niste mesaje de pe aici? sau am visat ca erau …
au disparut :o
au disparut :o
:'( :-X mda … a aparut cenzura
Sunt la loc de dat cu capul.
Am vazut masina live azi, o sa fie haos! 8)
