Jurnale de bord => Impreza => Impreza mea GD/GG (2001-2007) => Topic started by: adrian2310 on September 09, 2015, 17:27:08 PM
Title: Impreza WRX 2002 facelift 2006
Post by: adrian2310 on September 09, 2015, 17:27:08 PM
Va salut
De ieri sunt in posesia unei jucarii ptr oameni mari , IMPREZA WRX 2002 cu facelift fata de 2006 cu mici modificari:
turbina VF43
injectoare DeatschWerks 1000 cc
pompa benzina Walbroo
Blow off Grredy
Evacuare distanta egala,uppipe,down pipe 76"
pe langa acestea am mai primit odata cu masina
jante OZ RACING ULTRALEGERA 19"
Etrieri BREMBO si discuri de STI
un set de arcuri H&R
Masina are si unele mici probleme , caut un mecanic priceput din Constanta sau imprejurimi
revin cu poze cand o sa ma prind cum sa le pun in topic
http://imageshack.com/a/img673/9825/jUZ8DJ.png
http://imageshack.com/a/img673/8995/rtCYmB.png
http://imageshack.com/a/img538/4761/W61MDO.png
Title: Rãspuns: Impreza WRX 2002 facelift 2006
Post by: Musiu on September 09, 2015, 17:35:12 PM
Quote from: adrian2310 on September 09, 2015, 17:27:08 PM
http://www.subarufanclub.ro/forum/index.php?topic=111.0
Post by: andrei0241 on September 09, 2015, 18:01:40 PM
Daca e vorba de fineturi, nu cred ca gasesti mecanic bun in Cta pentru Subaru.
E cea de la Medgidia?
Post by: adrian2310 on September 09, 2015, 18:26:51 PM
nu , e cea de la Severin , Moldova Noua
pai si cei care au Impreza in Constanta unde merg cu ele ?
Post by: andrei0241 on September 09, 2015, 22:26:45 PM
Pentru revizii se gasesc destule, daca e nevoie si de o diagnoza precisa, cred ca doar la dealer gasesti.
La a ta, fiind vorba de modificari, macar pentru inceput pana o pui la punct, ti'as recomanda un drum la Bucuresti, te pot indruma colegii catre persoane pricepute acolo.
KET stiu ca'si facea reviziile la Tribeca la ACS service, in Medeea. Am fost si eu la ei de doua ori, totul ok, dar fara vreo problema deosebita, simpla mentenanta
Post by: celalalt on September 09, 2015, 23:16:42 PM
Pe dreapta e de un fel si pe sta ga de alt fel?Sau e de la face lift? ;D
Post by: andea79 on September 09, 2015, 23:24:16 PM
pai intr-o poza e cu faruri/roti de vara si in cealalta cu cele de iarna :)
Post by: adrian2310 on September 10, 2015, 07:05:44 AM
Pozele sunt din anunțul de vânzare , acum e cu jantele argintii , cele aurii trebuiesc îndreptate și încãlțate cu anvelope .
Nu înțeleg cu farurile sunt aceleași în ambele poze
Post by: adrian2310 on September 10, 2015, 07:07:01 AM
Și în București unde mã îndrumați ptr o constatare și reglaje ?
Post by: andea79 on September 10, 2015, 08:43:49 AM
Quote from: adrian2310 on September 10, 2015, 07:05:44 AM
sigur siguuuur ? ;D
poate este doar o iluzie optica din cauza capotei diferite :)
Post by: adrian2310 on September 10, 2015, 09:51:34 AM
Quote from: andea79 on September 10, 2015, 08:43:49 AM
sigur siguuuur ? ;D
Sa verific................... da sunt acelasi model ambele faruri  :P
saptamana viitoare o sa revopsesc toata partea fata si pragurile si o sa ii fac o sedinta foto
Title: Rãspuns:
Post by: moguai on September 10, 2015, 09:57:40 AM
Mergi la exelixis Adrian. Sunt prin pipera/voluntari dar am inteles ca s profesionisti. Pt wrx/sti acolo as recomanda oricui. Pt un aspirat clasic, merge oriunde ai incredere.
Post by: andea79 on September 10, 2015, 10:26:17 AM
da hood scoop-ul de ce este diferit de la o poza la alta ? :)
Post by: ucosmin on September 10, 2015, 10:35:11 AM
Unghiul din care e facut prima poza poate duce la confuzie. Mie nu mi se pare ca e diferit nici scoop-ul, nici farul.
Sa te bucuri de ea.
Post by: KET on September 10, 2015, 17:16:08 PM
Bine ai venit!
In Constanta nu ai unde sa mergi cu un WRX/STi. Eu merg la Bucuresti, in ultimul timp la Exelixis.
Succes cu masina, poate ne si intalnim...
Post by: adrian2310 on September 10, 2015, 22:20:42 PM
Quote from: KET on September 10, 2015, 17:16:08 PM
Bine ai venit!
Merci mult ptr INFO , dacã se organizeazã ceva în oraș vin și eu
Post by: KET on September 11, 2015, 14:07:55 PM
Greu sa organizam ceva in Constanta. Am avut cateva tentative, si o singura reusita, pana la urma. Ne-am strans 6 masini, din care doua erau ale mele si ate doua venite de la Bucuresti... Poate ne vedem intr-un weekend in statiuni, la o joaca, ca tot se termina sezonul acum...
Post by: adrian2310 on September 11, 2015, 14:55:39 PM
Quote from: KET on September 11, 2015, 14:07:55 PM
Eu stau în Mangalia , te aștept oricând vrei
Post by: adrian2310 on September 12, 2015, 17:04:26 PM
Azi am pus un tester pe ea și avea urmãtoarea eroare P0172 air/fuel adaption bank 1 , rich mixture . simptome masina tremura în relanti
Post by: andea79 on September 12, 2015, 17:40:41 PM
nu stiu ce tester ai folosit - probabil nu ceva specific subaru, P0172 la subaru ar trebui sa fie "System too rich..." si care poate aparea din mai multe motive, cateva ar fi:
- ai undeva un leak, maf-ul masoara X aer intrat dar in cilindri ajunge mai putin  -  se pierde undeva pe drum -  deci rezulta amestec mai bogat decat trebuie
- ai ceva probleme cu maf-ul care citeste prostii
- ai probleme cu prima sonda lambda care citeste prostii
- ai BOV cu evacuare atmosferica  ...
ar trebui sa folosesti ceva specific subaru sa iti verifici si fuel trims-urile si alte cele ... :)
LE: sau sa mai scriu cateva motive probabile, poate poate se nimereste careva :) :
- injector care ramane deschis mai mult decat trebuie
- regulator de presiune benzina care nu este ok
- admisie/filtru de aer modificat fata de stock pentru care nu a fost ajustat rom-ul (maf scaling-ul)
- IACV -ul   -> curata-l
Title: Răspuns: Impreza WRX 2002 facelift 2006
Post by: adrian2310 on September 12, 2015, 17:58:57 PM
Quote from: andea79 on September 12, 2015, 17:40:41 PM
Masina are BOV
Luni ajunge o nouă sondă Lambda
Masina are admisie sport cu tot cu filtru conic, cum trebuie reglat rom-ul ?
Ce înseamnă IACV?
Va țin la curent cu evoluția
Post by: andea79 on September 12, 2015, 19:12:35 PM
vezi cu lambda daca se sch ceva ...
daca nu verifica sa nu ai "leak-uri" pe undeva, verifica/curata maf-ul si iacv-ul (clapeta de acc.)
daca ai admisia de mai demult si doar acum au aparut problemele cel mai probabil rom-ul a fost "reglat deja " :)  - ma refer la calibrarea debitmetrului care este necesara in majoritatea cazurilor cand se sch flow-ul de aer
verifica bov-ul sa nu fi ramas blocat cumva si sa pierzi aer pe acolo...
Post by: MihaiFlorescu on September 12, 2015, 19:17:31 PM
Eu aș începe cu o verificare a traseului de aer sã nu fie ceva spart și apoi direct curãțare IACV.
Curãțarea chiar e bine venitã, chiar dacã nu de acolo e problema. Eu dupã asta chiar am simțit. Ca e mai liniștit motorul.
Vezi cã am pus și pe forum în secțiunea cu tutoriale câțiva pași.
Post by: adrian2310 on September 14, 2015, 10:50:57 AM
intrebare , unde este sensorul de temp exterioara , nu imi afiseaza in bord si vreau sa il verific
Post by: MihaiFlorescu on September 14, 2015, 14:08:55 PM
Verifica bordul si unitatea de comanda pentru aerul conditionat. Are un senzor pentru temperatura aerului in interior si e legat in serie cu cel de afara.
Am aflat si eu asta cand am mers cu masina fara acea unitate de A/C conectata. Nu imi afisa nimic pe ceasuri la temperatura exterioara.
Post by: adrian2310 on September 14, 2015, 15:44:05 PM
Acum am desfãcut consola centralã cea de sub casetofon și unitatea de aer și nu am vãzut nici un sensor , poți sa îmi spui mai exact unde sã mã uit ?
Post by: MihaiFlorescu on September 14, 2015, 15:48:49 PM
(http://s19.postimg.org/obwulfb3n/IMG_20141102_112620.jpg)
In dreapta jos e o priza de aer intre comutatorul de temperatura si cel de ventilatie. Pe acolo trage aer ca sa inregistreze temperatura. In spate e un senzor. Vezi daca mai exista si vezi efectiv unitatea de A/C daca e legata bine cu mufele.
Post by: adrian2310 on September 14, 2015, 22:04:44 PM
ma poate ajuta cineva unde gasesc asa ceva  STI TRUNK SPOILER Perrin Stiffys
http://imageshack.com/a/img540/2577/oCN9rA.jpg
Post by: adrian2310 on September 15, 2015, 20:15:05 PM
Am o problemã cu compresorul de AC , chiar dacã din interior nu este pornit AC ,compresorul  merge cam tot timpul și când pornește am scãderi mari de turații uneori moare motorul.
Acum am scoasã mufã de la compresor și masina sta lin la relanti
Post by: andea79 on September 15, 2015, 20:33:06 PM
da stiu ca ai probleme nu gluma :) una dupa alta :)
ai curatat IACV-ul cum era vorba mai devreme ?
verifica si incarcarea/voltajul pe baterie cu AC-ul oprit/pornit ... ia vezi :)
Post by: adrian2310 on September 16, 2015, 07:17:32 AM
Dacã îmi doream o mașinã fãrã probleme luam una nouã ;) , nu am curatat IACV-ul ptr ca vreau sã schimb și acea garniturã și încã nu a sosit . mâine verific voltajul și va zic ce parametri am
Post by: andea79 on September 16, 2015, 13:37:58 PM
iti ziceam de iacv pt ca s-ar putea sa aiba legatura si cu comportamentul cu ac on cand ar trebui sa se deschida un pic pt a creste turatia ...
Post by: celalalt on September 16, 2015, 13:58:21 PM
Vezi sa nu fie ceva model de USA masina.si cand ai ventilatia pe parbriz iti baga AC fara sa ti aprinda becul.Am patit o si eu la GC dupa swap...
Post by: adrian2310 on September 16, 2015, 19:27:11 PM
Verific acum treabã cu AC pe la parbriz , masina e adusã din SUA
Gata am verificat , asta era problemã AC pe parbriz , sapt asta sper sã o rezolv și cu IACV-ul
Saptamana viitoare vreau sa ii fac schimbul de ulei , ce ulei  imi recomandati ptr masina ?
Post by: KET on September 19, 2015, 10:51:23 AM
Presupun ca ii rupi dintii, asa ca eu ti-as recomanda ce mi-au recomandat si mie altii si nu mi-a creat probleme. Adica un Motul 300V. Acum sa decizi tu daca 20W60 sau 15W50...
Azi merg inspre Vama. Lasa un numar de telefon sau ceva, poate ne intalnim sa-ti vad jucaria si sa stam 10 minute de vorba.
Post by: daniel.gugu on September 19, 2015, 20:16:29 PM
Frumoasa jucarie ... Vazuta live...
Multi km fara probleme!!!
Post by: adrian2310 on September 19, 2015, 22:30:17 PM
Quote from: KET on September 19, 2015, 10:51:23 AM
Scuze am vãzut târziu mesajul și eram deja plecat cu familia la Mamaia , când mai treci uite țel meu 0724379468
Post by: adrian2310 on September 19, 2015, 22:31:39 PM
Quote from: daniel.gugu on September 19, 2015, 20:16:29 PM
Multumesc ptr urãri , eu nu am avut norocul sã vãd galeata , data viitoare
Post by: KET on September 20, 2015, 22:56:16 PM
Quote from: adrian2310 on September 19, 2015, 22:30:17 PM
Nu-i problema. Data viitoare...
Post by: adrian2310 on September 21, 2015, 08:01:15 AM
Azi bag masina la vopsit și încerc sã montez și scoop -ul de STI, sper ca pe vineri sã fie gata sã îi fac prima ședințã foto
Post by: adrian2310 on September 25, 2015, 20:25:03 PM
proaspat vopsita si cu noile jante , urmeaza sapt viitoare montare discuri placute si etrieri de STI BREMBO
(http://s13.postimg.org/dpvt27adz/IMG_20150925_130826.jpg) (http://postimg.org/image/7c6pyy5hv/full/)
upload gif from url (http://postimage.org/)
(http://s23.postimg.org/rng9qcwaz/IMG_20150925_130837.jpg) (http://postimg.org/image/kk8eaqqvb/full/)
adult image host (http://postimage.org/)
(http://s9.postimg.org/bnoflhuxb/IMG_20150925_130813.jpg) (http://postimg.org/image/lxqukqksr/full/)
image hosting no registration (http://postimage.org/)
Post by: MihaiFlorescu on September 25, 2015, 21:24:46 PM
Frumos!
Post by: daniel.gugu on September 25, 2015, 23:23:54 PM
Nice...
Post by: andrei0241 on September 26, 2015, 00:06:33 AM
Cat te'a costat revopsirea? Din poze arata f bine si, sincer, nu credeam ca o sa fie gata asa repede precum spuneai luni.
Post by: KET on September 26, 2015, 08:08:10 AM
Da, chiar arata bine in poze. Sa ne spui si unde ai vopsit-o
Post by: adrian2310 on September 26, 2015, 13:05:54 PM
Am revopsit doar capota aripile fațã barã fațã pragurile și portbagajul, cost total 1500 lei timp lãsatã luni luatã vineri.
Sapt viitoare îi facem  polish total
Post by: adrian2310 on September 29, 2015, 09:21:34 AM
Modificarile continua .....
(http://s13.postimg.org/4uqlnz9xj/IMG_20150928_115051.jpg) (http://postimg.org/image/g7375rimb/full/)
images upload (http://postimage.org/)
(http://s10.postimg.org/wsrq6p709/IMG_20150928_144259.jpg) (http://postimg.org/image/e0fv34alx/full/)
upload image free (http://postimage.org/)
si urmeaza
(http://s28.postimg.org/3zui1zfzx/IMG_20150923_124023.jpg) (http://postimg.org/image/76p1lm0ft/full/)
image hosting over 5mb (http://postimage.org/)
Post by: adrian2310 on October 08, 2015, 10:32:44 AM
sapt asta am schimbat si arcurile
(http://s23.postimg.org/jht7oisu3/IMG_20151006_153949.jpg) (http://postimg.org/image/6qf1i0j1z/full/)
free upload (http://postimage.org/)
(http://s18.postimg.org/rpbatgxop/IMG_20151006_153917.jpg) (http://postimg.org/image/fnfwzbog5/full/)
image upload with preview (http://postimage.org/)
urmeaza bara spate ,scoop STI si stopuri facelift
Post by: MihaiFlorescu on October 08, 2015, 12:03:03 PM
Chiar arata bine! Tine-o tot asa cu modificari de bun simt.
Imi place combinatia de frane si capace rosii.
Ia stopuri de 2004. Sunt cele mai tari!
Post by: adrian2310 on October 08, 2015, 13:22:34 PM
Cine mã poate ajuta cu un set de stopuri ?
Title: Rãspuns: Rãspuns: Impreza WRX 2002 facelift 2006
Post by: Muttley on October 08, 2015, 14:35:47 PM
Quote from: MihaiFlorescu on October 08, 2015, 12:03:03 PM
Decuparile alea 2 din dreptul lampilor de ceata (presupun) le face pe bara lui, si totu' se potriveste?
(https://jspecauto.com/images/EnginePics/Full/2682_DSCN6063.jpg)
Post by: MihaiFlorescu on October 08, 2015, 15:24:14 PM
Se cumpara alta bara dupa cum zice si el.
Post by: adrian2310 on October 08, 2015, 19:20:54 PM
Bara e deja la vopsit , azi am primit un stop urmeazã al doilea în 2 zile și gata
Post by: celalalt on October 08, 2015, 23:15:22 PM
Crezi tu ca gata.O sa ti mai vina o gramada de idei...
Post by: adrian2310 on October 09, 2015, 11:04:39 AM
gata ptr saptamana asta
Post by: Muttley on October 10, 2015, 01:27:12 AM
Daca dai stopurile vechi, anunta-ma te rog.
Post by: adrian2310 on October 10, 2015, 09:55:55 AM
Quote from: Muttley on October 10, 2015, 01:27:12 AM
Pe marți sper sã fac modificarea , te anunț
Post by: adrian2310 on October 10, 2015, 09:59:27 AM
Quote from: adrian2310 on October 08, 2015, 13:22:34 PM
Am rezolvat cu ambele stopuri
(http://i.imgur.com/tqFDYKP.jpg?1)
(http://i.imgur.com/v6GDqXD.jpg?1)
(http://i.imgur.com/1HTzfkr.jpg)
Post by: andea79 on October 10, 2015, 21:41:44 PM
auuu, ochiii  :o :o :o
Post by: malakay on October 10, 2015, 21:50:47 PM
dece ai mai colantat bara asta daca tot tre sa o schimbi ??
Post by: adrian2310 on October 10, 2015, 22:49:36 PM
Quote from: malakay on October 10, 2015, 21:50:47 PM
Pai și pânã miercuri sã merg așa necolata ?
Post by: KET on October 13, 2015, 14:52:37 PM
Mie imi placea mai mult fara galbenul ala. Dar e chestie de gusturi. Macar asa sigur nu te mai rateaza nimeni pe strada.  ;) Succes in continuare...
Post by: adrian2310 on October 14, 2015, 09:34:49 AM
scoop nou STI si bara spate cu stopuri
(http://s14.postimg.org/scz0l5brl/IMG_20151013_115441.jpg) (http://postimg.org/image/scz0l5brh/full/)
upload image (http://postimage.org/)
(http://s17.postimg.org/x6fbutbmn/IMG_20151013_115451.jpg) (http://postimg.org/image/vrdr63ajf/full/)
image hosting sites (http://postimage.org/)
Post by: daniel.gugu on October 14, 2015, 11:24:16 AM
Nice... multa bafta in continuare...
Post by: MihaiFlorescu on October 15, 2015, 10:01:42 AM
Si mie imi place. Mai trebuie lustruita evacuarea si exteriorul e gata.
Ce urmeaza?
Post by: adrian2310 on October 15, 2015, 18:17:57 PM
Urmeazã eleron lunetã și scaune sport care sunt la retapitat albastre cu negru
Post by: andrei0241 on October 15, 2015, 19:06:50 PM
Am vazut masina azi, langa Billa, sare imediat in ochi si cu colantele astea ...
Post by: adrian2310 on October 16, 2015, 09:59:39 AM
O noua sesiune foto , acum spalata
ieri am fost sa ii fac geometria la roti si parca eram pozarul cu faceti poze cu maimuta .
o faza tare a fost cand a venit un tiganus s-a uitat putin la ea si a plecat satisfacut spunand " are sigur peste 300 cai "
(http://s30.postimg.org/jr2e6c77l/IMG_20151016_095111.jpg) (http://postimage.org/)
photo uploading (http://postimage.org/)
(http://s7.postimg.org/3se1azr0r/IMG_20151014_170535.jpg) (http://postimg.org/image/hyts681vr/full/)
free image hosting (http://postimage.org/)
(http://s27.postimg.org/3uoeg2btv/IMG_20151014_170545.jpg) (http://postimg.org/image/df812y15r/full/)
upload pic (http://postimage.org/)
Post by: MihaiFlorescu on October 16, 2015, 10:30:50 AM
Daca merge a fel de bine precum arata... atunci esti un fericit :)
Post by: adrian2310 on October 16, 2015, 10:48:36 AM
Quote from: MihaiFlorescu on October 16, 2015, 10:30:50 AM
merge 95% cum arata
Post by: celalalt on October 16, 2015, 13:29:34 PM
O sa devi imun la tiganusi.Si la parcagii.Si la alti diversi care o sa te intrebe cat baga in bord.Dar oricum , e bine ca nu prea atragi atentia. ;D
Post by: adrian2310 on October 16, 2015, 19:10:36 PM
A ajuns eleronul , sapt viitoare bãgam la vopsit
Post by: adrian2310 on October 28, 2015, 20:23:15 PM
Help,
în seara asta am închis luminile am scos cheia din contact și au ramas luminile de poziție aprinse. Ca sã le sting a trebuit sã scot siguranta .
Cum rezolvãm problema ?
Post by: Muttley on October 28, 2015, 20:31:01 PM
Sa nu te superi daca intreb prostii, da' nu e din butonul ala de pe cochilia volanului, nu?
Post by: MihaiFlorescu on October 28, 2015, 20:32:06 PM
:) cea mai cunoscuta "problema" la Subaru. Vezi ca ai un buton in spatele volanului ;)
Probabil la spalatorie l-au apasat. Iti tine pozitiile aprinse chiar daca scoti cheia.
Post by: adrian2310 on October 28, 2015, 20:48:22 PM
Acum cobor sã verific, mai e o problemã când frânez brusc fațã frâneazã bine dar spatele foarte puțin , am aerisit frânele fațã/spate dar nimic , pe fațã am sistemul Brembo
Post by: Muttley on October 28, 2015, 21:00:40 PM
Cum ai constatat ca spatele-i slab? Clar poti afla doar p-un stand cu role cum au la ITP, sau de acolo stii?
La ABS n-ai ce regla, nu exista limitator de franare la puntea spate, iar daca n-ai aer in instalatie (pedala tare), ai putea incerca cu placute mai aderente, da' nu te astepta la minuni.
Post by: adrian2310 on October 28, 2015, 21:12:01 PM
Acum 2 zile am mers mai sportiv cu ea cu demaraje și frânãri bruște discurile fațã erau foarte încinse iar cele spate foarte putin
Am "rezolvat " problemã cu luminile cu ajutorul acelui buton magic de pe bord
Post by: Muttley on October 28, 2015, 21:20:35 PM
E normal sa se-ncinga franele fata, la franari brutale acolo se-ntampla cam tot.
Incearca acelasi tratament mergand in marsarier, vei vedea ca se-ncing si franele spate :P
Post by: adrian2310 on October 28, 2015, 21:28:10 PM
Mã gândeam ca atunci când am schimbat etrierii fațã cu cei Brembo de Sti sã trebuiascã sã schimb și pompa de Abs cu cea de STI sau este aceeași pompã cu WRX
Post by: Muttley on October 28, 2015, 21:37:04 PM
ABS-ul e un bloc electronic, cu niste electrovalve. La roti ai niste senzori, ce citesc viteza rotii, iar cand aceasta e zero, electrovalvele se inchid si nu mai franeaza roata. Cand viteza rotii creste, iar franeaza. Ciclul se repeta de multe ori pe secunda. Nu vad de ce ar exista un bloc ABS dedicat STI-ului, in teorie ar merge si unul de Matiz.
Daca zici de pompa de frana sau servofrana, acolo-i altceva, desi influenta ar fi minima.
Tu te plangi de un INCHIPUIT dezechilibru fata/spate, nu stiu detalii, dar daca etrierii spate de STI difera multi de cei de WRX, un dezechilibru ar fi plauzibil.
Du-o la o statie ITP, da-i aluia d-acolo de 1-2 cafele si roaga-l sa-ti masoare forta de franare.
Post by: MihaiFlorescu on October 28, 2015, 21:41:57 PM
Cam mult sa vorbim despre dezechilibru. Si eu am combinatia cu brembo doar pe fata si e ok.
Da, franele spate de STI sunt o idee mai mare. Diametrul discului fiind mai mare, ajuta intr-o oarecare masura masina sa franeze mai bine.
Post by: adrian2310 on October 28, 2015, 22:17:46 PM
Mâine merg la un stând de frâne sã vãd raportul de frânare
Post by: andrei0241 on October 28, 2015, 22:37:48 PM
Te va ajuta doar stiind valorile normale, altfel vei putea vedea doar dezechilibrul intre stanga/dreapta, dezechilibru pe care sigur l'ai fi simtit daca spui ca ai avut franari mai serioase
Post by: adrian2310 on October 29, 2015, 09:35:56 AM
aseara nu am avut ce face si am demontat ceasul de km sa incerc sa ii schimb lumina din verde in rosu stergand vopseaua verde de pe spate . Cand l-am demontat am atins si miscat acele de la turometru si km , dupa ce am sters tot am montat ceasurile dar nu mai merg nici turometru nici km , merge doar temp apei si combustibilul .
PLEASE HELP
Post by: malakay on October 29, 2015, 18:21:36 PM
vezi ca nu ai clipsat acul ... (apasa un pic mai tare ) si doar pe pozitia 0 !
Post by: adrian2310 on October 30, 2015, 11:19:47 AM
Quote from: malakay on October 29, 2015, 18:21:36 PM
am incercat , a merg doar la km
DECI CINE ARE DE VANZARE CEASURI CU TUROMETRU PE MIJLOC (WRX STI ) ?
Title: Rãspuns:
Post by: malakay on October 30, 2015, 17:18:20 PM
Eu am doar de bugeye de uk !
Sent from my HTC One_M8 using Tapatalk
Post by: adrian2310 on November 02, 2015, 20:40:44 PM
Deci am descoperit problema , motorașul de la turometru e distrus .
Am nevoie de ceasuri de bord doar ptr un motoras
Title: Rãspuns:
Post by: adrian2310 on November 02, 2015, 20:42:26 PM
Quote from: malakay on October 30, 2015, 17:18:20 PM
Deci malakay ajuți un coleg aflat în suferințã cu un preț bun ?
Post by: malakay on November 02, 2015, 20:58:48 PM
vezi pm !
Post by: adrian2310 on November 03, 2015, 10:10:48 AM
ai adresa pe pm.
caut un OBD READER CU BLUETOOTH  sa il leg la telefon , ce imi recomandati si cu ce program sa rulez ?
consola centrala HIDROTRANSFER CARBON
(http://s3.postimg.org/6t3t4keir/IMG_20151103_100131.jpg) (http://postimg.org/image/ngvb729a7/full/)
Post by: MihaiFlorescu on November 03, 2015, 10:11:40 AM
în ce scop vrei sã îl folosești?
Post by: ipman on November 03, 2015, 11:41:50 AM
Exista niste chinezarii de la iCar, se numesc Vgate. Relativ ieftinache si chiar nu sunt probleme. Sunt in versiunea BT si Wifi, merg foarte bine cu Torque. Le gasesti intre 80 si 120ron.
P.S. Versiunea Wifi e mult mai rapida.
Post by: adinegru on November 03, 2015, 12:14:25 PM
http://www.ebay.co.uk/itm/221825151872?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Pe iOS pierdea conexiunea la fiecare 5-10 minute.
Post by: andrei0241 on November 04, 2015, 01:57:41 AM
Eu am un d'asta (http://olx.ro/oferta/mini-vgate-elm327-bluetooth-obd2-ii-tester-auto-diagnoza-torque-ID4uv5i.html#2ffc2b0f06) de ceva vreme, ulterior am luat si Tactrix, iar Vgate'ul l'am bagat pe Fiesta. Il folosesc cu Torque'ul, mi se pare o combinatie f buna raportat la pret.
Post by: ipman on November 04, 2015, 09:04:08 AM
Eu am Vgate versiunea 2, cel trapezoidal. Nu pierde legatura, nu face probleme, e suficient de mic ca sa nu dai cu picioarele in el cand e montat, se poate deschide/inchide de la power, intra in stand-by ca sa nu consume bateria, ce sa mai, merge cum ar trebui, neasteptat de bine pentru o chinezarie.
Bonus pe Wifi e mult mai rapid decat BT.
Post by: adrian2310 on November 09, 2015, 10:28:40 AM
intrebare ...
cum schimb becurie de la unitatea AC ?
avem si eleron luneta
(http://s28.postimg.org/de6tn4jd9/IMG_20151103_105222.jpg) (http://postimg.org/image/f5zsi12q1/full/)
upload an image (http://postimage.org/)
Post by: MihaiFlorescu on November 09, 2015, 10:49:08 AM
Iei becuri de instalatie de brad, scoti cele doua suruburi de la suportul de bauturi, scoti suportul de bauturi si apoi tragi toata masca usor. Unitatea audio ramane fixata, si iese totul in jur, impreuna cu panoul de comanda AC. De acolo te descurci. Ai nevoie de o surubelnita dreapta sau ceva ascutit ca sa scoti soclurile.
Rezultatul aici:
http://www.subarufanclub.ro/forum/index.php?topic=2002.msg59749#msg59749
Post by: adrian2310 on November 09, 2015, 10:56:17 AM
iese doar masca unitatea de AC pe langa cele 4 suruburi mai are 2 zbiruri care nu merg date jos
GATA AM REZOLVAT , TREBUIA SA FIU MAI CONVINGATOR CU EA
Post by: MihaiFlorescu on November 09, 2015, 12:19:52 PM
Daca vrei doar sa schimbi becurile merge cum am zis mai sus, chiar fara a scoate mufele din spate. Daca vrei sa dezmembrezi plasticele ca sa le vopsesti, atunci da, se declipseaza si desurubeaza mai multe.
Post by: adrian2310 on November 10, 2015, 17:43:29 PM
am rezolvat cu iluminatul , acum am alta problema , am cumparat pana acum 2 modele de OBD bluetooth dar nu reusesc sa le leg la ECU masinii (un VGATE SCAN SI ELM 327), cine ma poate ajuta ?
Post by: malakay on November 10, 2015, 20:11:30 PM
daca nu reusesti sa te conectezi la ecu cu nici un device si stii sigur ca nu e de la interfata ... este problema de la masina .. atunci verifica pe stalpu de la pasager la picioare tre sa fie o mufa verde vezi poate a umblat cineva pe acolo si a demufat aia ...
Post by: andrei0241 on November 10, 2015, 20:49:50 PM
Pe alte masini merge? Imperecherea pe BT s'a realizat ok?
Post by: Muttley on November 10, 2015, 21:40:48 PM
Elm 327 a mers din prima la mine. Pairingul cu telefonul, facut pe masina cealalta, a ramas valabil.
Post by: adrian2310 on November 10, 2015, 21:53:23 PM
Ambele OBD au mers bine și s-au conectat repede pe un Peugeot Partner și pe o Dacia Duster .
OBD se leagã la smartphone dar nu se leagã la ECU
Post by: Muttley on November 10, 2015, 21:55:40 PM
Ai la mine pe topic, prin primele pagini, configuratia mufelor de sub volan. Ar trebui sa fie la fel, sunt din acelasi an.
Scuze, vad ca malakay zice de stalpul pasagerului. Alta mufa verde probabil.
Post by: adrian2310 on November 18, 2015, 17:17:48 PM
ce am descoperit ieri ... diferentialul spate are capac PERRIN(care cand a fost schimbat nu au schimbat si garnitura si curge pe sus asa de mult ca a acoperit reclama PERRIN ) care din ce am citit exista numai ptr diferential de STI nu si de WRX .
Inainte sa iau masina baiatul acela spunea ca a avut montat pe ea cutia de STI , e posibil sa fie si diferentialul de STI ?
Post by: Muttley on November 18, 2015, 19:19:13 PM
A mea n-are garnituri la niciunul din busoane, si nici n-ar avea pe ce sa sprijine, deci nu cred sa lipseasca. Etansarea si limita de infiletare cred ca se face la interior, pe un prag din capac. Cred doar, nu m-am uitat.
Edit: scuze, iar citesc in fuga. Spui ca ai capacul cu totul schimbat, deci ce am scris eu nu se aplica.
Post by: adrian2310 on November 19, 2015, 18:32:17 PM
sapt viitoare vine garnitura de la capac si vad atunci ce este in interior .
ce diferente sunt intre galeriile de admisiE de la WRX si STI ?
am gasit pe net o galerie de admisie si clapeta de acceleratie de STI 2001 -2005 si va intreb daca merita deranjul ?
Post by: STI on November 19, 2015, 19:46:10 PM
flow mai bun pt galeria de admisie de sti, clapeta este identica
Post by: KET on November 20, 2015, 08:11:00 AM
Schimbarea galeriei implica si gadilarea softului.  ;)
Post by: adrian2310 on November 22, 2015, 10:55:50 AM
INTREBARE
aceste coduri de OE sunt corecte ?
D1040FE000 Group N Pitch Stop Mount
D1010FE120 SUPORT MOTOR
D1010FE110 SUPORT MOTOR
D1010FE020 SUPORT CUTIE
vreau sa le comand si nu vreau sa fac o prostie
Post by: adrian2310 on November 24, 2015, 09:11:07 AM
Nu mã ajuta nimeni cu un rãspuns la întrebarea mea ?
Post by: MihaiFlorescu on November 24, 2015, 09:29:45 AM
De obicei nu prea sunt pe cod produsele de "tuning". Se comada piesa si e specificat in descriere pentru ce an/model este.
Post by: Muttley on November 24, 2015, 10:15:52 AM
Conform google, chestie pe care sigur ai facut-o si tu, ar fi ce trebuie. In cel mai rau caz sunt suporti obisnuiti de STI, fara denumirea de "grupa" asociata. Caz in care rallysportdirect de exemplu ar fi mincinosi, ceea ce m-ar mira.
Le gasesti la noi, in magazine obisnuite?
Post by: adrian2310 on November 24, 2015, 17:58:54 PM
le-am comandat acum de pe jdm-planet.com 945 lei setul de 4 piese
Post by: Muttley on November 24, 2015, 19:32:58 PM
Extrem de ieftin  :-\
Sa ne tii la curent te rog.
Post by: MihaiFlorescu on November 24, 2015, 21:07:47 PM
Quote from: adrian2310 on November 24, 2015, 17:58:54 PM
Ai grija sa nu fie replici. Eu am dat 750 doar pe suportul de cutie. E drept ca este Grp N modificat de RCM sa fie si mai dur...
Post by: adrian2310 on November 24, 2015, 21:17:55 PM
Astea sunt
http://jdm-planet.com/product/genuine-subaru-impreza-wrx-sti-heavy-duty-group-n-engine-gearbox-mount-kit-5speed-oem/
Post by: MihaiFlorescu on November 24, 2015, 21:36:06 PM
Aaaah.. ok. O sa mai fie 30% taxe de import. Ca sa stii la ce sa te astepti.
Post by: KET on November 25, 2015, 16:36:29 PM
Din proprie experienta iti zic sa le pastrezi pe cele pe care le dai jos ca nu se stie ce se intampla. Mie mi s-a rupt un tampon de grupa N de la motor. Asa ca nu le vinde pe cele de pe masina, tine-le pentru orice eventualitate...
Post by: adrian2310 on November 25, 2015, 20:58:07 PM
Quote from: KET on November 25, 2015, 16:36:29 PM
Merci mult ptr idee
Post by: adrian2310 on November 26, 2015, 17:33:22 PM
Gata interioul
(http://s7.postimg.org/ogfe4fzbv/IMG_20151121_110223.jpg) (http://postimg.org/image/6qdpjelqv/full/)
photo upload (http://postimage.org/)
(http://s12.postimg.org/61b3cdjel/IMG_20151125_092229.jpg) (http://postimg.org/image/61b3cdjeh/full/)
how to screenshot on windows (http://postimage.org/app.php)
(http://s1.postimg.org/atbhyswxb/IMG_20151126_124701.jpg) (http://postimg.org/image/cxvuzvyjv/full/)
intrebare , unde este situat sensorul de temp exterioara ?
Post by: Muttley on November 26, 2015, 19:20:27 PM
In partea inferioara a radiatorului la masina originala, se vede prin bara.
Post by: malakay on November 26, 2015, 20:37:12 PM
ti-am scris si pe facebook in fata radiatorului de apa , sper ca ai rezolvat !
Post by: adrian2310 on November 27, 2015, 17:27:40 PM
am cautat azi o ora la masina dar nu il gasesc , ma puteti ajuta cu o poza ?
Post by: MihaiFlorescu on November 27, 2015, 17:51:35 PM
http://opposedforces.com/parts/impreza/en_g11/type_55/climate/air_conditioner_system/illustration_2/
Reperul 12.
Post by: malakay on November 27, 2015, 18:04:39 PM
(http://www.subaruoutback.org/forums/attachments/problems-maintenance/17099d1282690920-outdoor-temperature-reading-switches-001-medium-.jpg)
daca te uiti prin plasa ( gen pe sub numaru de inmatric ) tre sa il vezi !
Post by: adrian2310 on November 27, 2015, 18:14:09 PM
e groasa treaba , uitati solutia
http://forums.nasioc.com/forums/showthread.php?t=2382859
Post by: malakay on November 27, 2015, 18:59:30 PM
nu stiu ce sa zic man ... eu am avut sensor pe bugeye de l-am desfacut ! vezi sa nu fi taiat mufa cand a fost facut swap-ul  de bot !
Post by: MihaiFlorescu on November 27, 2015, 20:47:24 PM
Si mie imi statea pe limba sa zic ca cel care a facut swap-ul nu a tinut cont de mufa sau nu stia ce face...
Post by: adrian2310 on November 27, 2015, 21:27:53 PM
Mã mai uit mâine
Post by: adrian2310 on December 20, 2015, 10:53:55 AM
gata cu proiectele pe anul acesta , ptr primavara un prim proiect  eleron WRC.\
Daniel.gugu  daca te gandesti la o schimbare ma intereseaza
(http://s23.postimg.org/bjkbon95n/subaru_wrc.jpg) (http://postimage.org/)
screengrab (http://postimage.org/app.php)
Post by: Forester on December 20, 2015, 13:23:10 PM
Cu eleron d-ala nu mai iei curba, mergi tot inainte...  :D :D
Post by: adrian2310 on December 20, 2015, 15:45:34 PM
Quote from: Forester on December 20, 2015, 13:23:10 PM
Bunã asta
Post by: daniel.gugu on December 24, 2015, 12:41:16 PM
Quote from: adrian2310 on December 20, 2015, 10:53:55 AM
Sorry... Not yet.
Post by: adrian2310 on January 20, 2016, 16:25:37 PM
Am nevoie urgențã de aceastã vâlvã  42084FE010
am nevoie de o informatie , care este rolul acestei valve
(http://s8.postimg.org/tkg1i4m4l/pcv0yp.gif) (http://postimage.org/)
windows print screen (http://postimage.org/app.php)
poate fi inlocuita cu un T ?
Post by: Muttley on January 21, 2016, 18:57:23 PM
Aparent, o idee ar fi sa renunti la ea, ai instructiuni complete aici: http://www.socalsubies.com/forums/showthread.php?t=27597
Iau si eu in calcul varianta asta.
Post by: adrian2310 on January 21, 2016, 23:48:44 PM
Merci ptr ajutor , mâine mã apuc de treaba
Post by: Muttley on April 05, 2016, 09:53:01 AM
adrian, cum ai facut, ai anulat valva?
Post by: adrian2310 on April 18, 2016, 10:25:58 AM
scuze nu am mai intrat de mult pe forum ,  am cumparat alta second si am motat-o
Post by: adrian2310 on May 18, 2016, 09:44:01 AM
dintr-o mica neatentie masina a suferit un facelift nedorit
caut bara fata aripa dreapta capota si far dreapta ptr hawk sau bara fara , aripi, capota si trager ptr blob
(http://s32.postimg.org/i8fv84hz9/13240159_1036215979759214_6666467377009309882_n.jpg) (http://postimage.org/)
image hosting free no registration (http://postimage.org/)
Post by: KET on May 18, 2016, 10:29:23 AM
Post by: adrian2310 on August 28, 2016, 11:29:00 AM
new face in town , sapt viitoare e gata vopsit si eleronul
(https://s12.postimg.org/vh4wobe6l/IMG_20160826_194542.jpg) (https://postimg.org/image/p3ftl29ah/)20mb image hosting (https://postimage.org/)
(https://s4.postimg.org/e1afq46vx/IMG_20160819_182718.jpg) (https://postimg.org/image/vrc4b5kgp/)screen capture (https://postimage.org/app.php)
Post by: Muttley on August 28, 2016, 11:48:34 AM
Deci masina asta a avut de-a lungul vietii sale toate mutrele new age posibile.
Post by: adrian2310 on August 28, 2016, 16:02:52 PM
E o fire mai nehotãrâtã , dar cât va sta la mine așa rãmâne
Post by: malakay on August 28, 2016, 19:21:39 PM
ACUM E BLOB :D  felicitari ma bucur ca nu ai renuntat la masina...
Post by: adrian2310 on August 28, 2016, 20:40:13 PM
Nu scãpãm ușor unu de altul , va rãmâne foarte mult în familie
Post by: adrian2310 on September 20, 2016, 18:39:34 PM
GATA SI CU ELERONUL WRC
(http://s21.postimg.org/skaas0jev/14292327_1121618857885592_2666396108376665121_n.jpg) (http://postimg.org/image/mjcluxwsj/)free upload image (http://postimage.org/)
(http://s12.postimg.org/3t107phot/14375284_1120645724649572_1402386657_o.jpg) (http://postimg.org/image/vt53rzl55/)image hosting 30 mb (http://postimage.org/)
Post by: malakay on September 20, 2016, 20:20:47 PM
felicitari arata foarte bine !
Post by: Musiu on December 04, 2016, 22:23:55 PM
Am vazut ca masina a iesit la vanzare, sper ca pentru un upgrade! Bafta orice-ar fi!
Post by: andea79 on December 04, 2016, 22:51:28 PM
s-a stricat ceva cand mestereai la canistra de carbon ?
am vazut ca intrebai de ea in 1 dec seara si ai pus-o la vanzare in 3 dec ... :)
te chinui sa o pimpuiesti de atata timp si vrei sa o vinzi asa brusc ?
Post by: adrian2310 on December 05, 2016, 10:02:22 AM
ai ghicit , un mic upgrade
sper sa o rezolv cat mai repede , tipul o poate tine 2 luni
referitor la canistra o sa ramana acolo ,
(https://s15.postimg.org/ecokhmsnf/image.jpg) (https://postimg.org/image/9e1233ouf/)upload gif from url (https://postimage.org/)
Post by: Musiu on December 05, 2016, 10:08:10 AM
 ;D Frumoasa, sper sa se lege vanzarea si cumpararea la timp. Spor!
Post by: malakay on December 05, 2016, 11:53:00 AM
cred ca o sa iti para rau ... eu in momentul de fata nu as daca un ej20 pe un FA20 ! Urmarim cu mare interes
Post by: andea79 on December 05, 2016, 11:58:07 AM
fain si spor si distractie atunci  :)
ala-i WRX/FA20 sau STI/EJ25 in poza ca eu nu sunt in stare sa imi dau seama ? (rusine stiu  :-[ )
Post by: malakay on December 05, 2016, 11:59:24 AM
ej nu se mai produce dupa hatchback ...:D
Post by: Forester on December 05, 2016, 12:30:33 PM
Pai parca toate sti-urile de dupa hatch pana in zilele noastre au motor 2.5. Asta nu inseamna automat ej? Exista FA25?  :D
Post by: Muttley on December 05, 2016, 12:34:25 PM
Quote from: andea79 on December 05, 2016, 11:58:07 AM
Posibil sa fie vereicsul, ca nu are masa de calcat.
malakay, STI-ul a ramas cu vechiul 2.5.
Post by: moguai on December 05, 2016, 14:29:04 PM
Ala i wrx cu fa20 si probabil cvt. Dar e us only (posibil si pe la arabi sa fie)
Post by: adrian2310 on December 05, 2016, 14:43:47 PM
E wrx 2.0
Post by: Musiu on December 08, 2016, 12:16:39 PM
Pana la urma iei WRX rosu din poze sau cauti sa scapi de blob si accepti VARIANTE AUTO CU MASINI COUPE , CABRIO sau SUV dupa 2004?
este nevoie de o corectura in anuntul de pe FB - Rallye e cu Y nu cu I - https://www.facebook.com/groups/motorsportparts/permalink/1895411110682451/?sale_post_id=1895411110682451
Post by: b-power on December 08, 2016, 16:30:18 PM
Quote from: Musiu on December 08, 2016, 12:16:39 PM
Bravo! I-ai aratat tu lui!
Post by: Musiu on December 08, 2016, 18:18:41 PM
Quote from: b-power on December 08, 2016, 16:30:18 PM
Hai sa nu fim ironici inutil, am incercat doar sa-l ajut pe Adrian sa-si corecteze anuntul. de pe FB. Tot nu mi-e clar cu ce-si inlocuieste blobu.
Post by: adrian2310 on December 12, 2016, 11:43:23 AM
sa lamurim problema
am acceptat variante auto ptr ca masina mea nu este foarte vandabila si incerc variante cu auto plus diferenta ,si acel auto poate il vand mai repede .
Da rezultatul final va fi wrx 2015 (sper acela rosu )
multumesc ptr atentia la detalii( chiatr nu am realizat ) , o sa corectez acum pe Fb si OLX .
