Jurnale de bord => Impreza => Impreza mea GC/GF/GM (1992-2000) => Topic started by: daniel.gugu on January 13, 2018, 01:08:33 AM
Title: Un alt cotet numit "Goofy" - GC8 Type R
Post by: daniel.gugu on January 13, 2018, 01:08:33 AM
Un alt vis implinit ...
Subaru Impreza WRX STI TypeR
Prima inmatriculare : 01.09.1999
Greutate : 1260kg
Putere : 206kW
Km : ~ 173000
"Cochetam" cu aceasta masina de foarte mult timp ... Si cum eram eu in concediu si ma plictiseaam ... am zis sa risc o plimbare ...
03.01.2018 : Il sun pe Malakay si il invit la o plimbare pana in Lituania. Nu a stat prea mult pe ganduri si a zis DA.
05.01.2018 : Ne trezim noi cu noaptea in cap si plecam spre aeroport... ceata, frig, "prima iubire"... aveam niste fete atat de lungi ... Timpul trecea repede ... Bucuresti - Istanbul - Vilnius ...
Seara, in jurul orelor 19.30, dupa o plimbare de aproximativ 1h cu un X5 alb si "pomulet de craciun" in loc de ceasuri de bord ajungem la destinatia finala ...
Sare Malakay al meu direct pe masina ... mai ceva ca Toshi ... ba prin stanga, ba prin dreapta, ba prin fata, ba prin spate ...
O ia la o tura, o ridica pe elevator ... si ne hotaram sa o luam ...
Engine & Power
OEM Subaru Impreza STi Genuine Crankshaft Damper Pulley
OEM Subaru Impreza STi 96-00 Intercooler Spray Water Bottle & Pump
Cooling system
Radiator Nissens    NIS 67740
Radiator cap STI Performance Group N 1.3 bar Impreza, Forester, Legacy, ST4511355010   ST4511355010
Hose, radiator lower Legacy, Impreza GT 99/2000 - 45167AA030   45167AA030
Hose, radiator upper Legacy, Impreza GT 99-2000 - 45167AA020   45167AA020
Subaru Impreza Upper/Lower Radiator Hose Clamp   ICP11004
RCM Magnetic Sump Bung   RCM2761
Gasket, drain plug Impreza GT/WRX/STI, Forester, Legacy, Legacy/Outback - 11126AA000   11126AA000
Oil filter Impreza STI, ST15208ST010    ST15208ST010
Pan assy, oil Impreza GT/WRX/STI 1994-2005, Forester Turbo 1998-2005 - 11109AA053   11109AA053
Subaru EJ20 Group N Sump Gasket + Bolts & Three Bond Sealant   ICP6961
Subaru Impreza 96-00 Power Steering Oil Cooler Rubber Hoses
Subaru Impreza Power Steering Pump High Pressure Pipe Banjo Bolt Washer
Fuel system
OEM Subaru Impreza 92-07 Genuine Fuel Pump Tank Gasket   42060AA040
OEM Subaru Impreza 92-00 Fuel Filler Neck Lower Hose & Clips
OEM Subaru Impreza 93-00 Fuel Neck Filler Pipe Kit   42066FA030
OEM Subaru Impreza Fuel Filler Neck Cap
OEM Subaru Impreza 92-00 Fuel Filler Neck Body Gasket
OEM Subaru Impreza Turbo 92-00 Fuel Filler Neck Lower Breather/Vent Hose
OEM Subaru Fuel Filter STi JDM   42072AA011
WALBRO 255 Fuel Pump Kit (din pacate nu am gasit una noua OEM)
Accessories
Engine mount left STI Impreza GT/WRX/STI   ST4100055120
Engine mount right STI Impreza GT/WRX/STI   ST4100055110
Cover, timing belt front, center Impreza GT/WRX/STI, Forester, Legacy/Outback (13570AA044) -13570AA045   13570AA045
Cover, timing belt, no.1, outer left Impreza GT/WRX/STI, Forester, Legacy/Outback - 13574AA094   13574AA094
Cover, timing belt, no.1, right outer Impreza GT/WRX, Forester XT - 13572AA101   13572AA101
Subaru Impreza Turbo Cambelt Cover Front Lower Seal 13594AA001
Subaru Impreza Turbo Cambelt Front Upper Seal 13581AA051
Subaru Impreza Turbo Genuine PCV Inlet Manifold Valve 11810AA000
Subaru Impreza Turbo Throttle Body Gasket 16175AA201
Subaru Impreza Turbo Genuine Subaru Intercooler To Throttle Body Hose 21869AA000
Subaru Impreza Turbo 96-00 Version 3-6 Crankcase Breather Pipe Set
Subaru Impreza 92-14 Alternator Tensioner Bolt Set
Subaru Impreza Turbo Inlet Manifold Gaskets V5 & V6
Subaru Impreza Turbo 98-00 Inlet Manifold Gaskets & Bolts
Subaru Impreza, Legacy & Forester Main Heavy Duty Crankshaft Pulley Holder
Subaru Impreza, Legacy & Forester Quad Cam Front Timing Belt Cover Bolt Set
Exhaust
Gasket - exhaust turbo outlet (downpipe) Impreza GT/WRX/STI, Forester Turbo/XT, Legacy GT - 44022AA180   44022AA180
Gasket, exhaust manifold Impreza GT/WRX/STI, Forester, Legacy/Outback - 14038AA000   14038AA000
Subaru Impreza 96-00 Genuine Upper Turbo Heat Shield
Subaru Impreza 92-00 Genuine Lower Turbo Heat Shield
Subaru Impreza 92-00 Turbo Heat Shield Fixing Bracket
Transmission
5MT DCCD swap to 6MT DCCD
Transmission set    6MT DCCD
Subaru Impreza STi R180 Diff Gasket Set   ICP11015
Subaru Impreza 92-07 Turbo R160/R180 Rear Diff Lower Drain Plug   ICP13383
Subaru Impreza 92-07 Turbo R160/R180 Rear Diff Upper Fill Plug   ICP12240
Subaru Impreza STi 6 Speed Clutch Fork Return Spring    30546AA060
Sleeve, speedometer driven Impreza 1998-2007
Subaru Impreza Legacy Forester Block to Gearbox Stud
Subaru Impreza 92-00 Manual Gearbox Bell Housing bolt Kit
Subaru Impreza Forester Legacy 5 Speed Front Driveshaft Roll Pin x 1
Master cylinder, clutch Impreza GT, Forester Turbo S - 37230FC010   37230FC010
Brakes & Wheels
Sumitomo calipers swap to Brembo calipers
Brake discs F/R - Brembo
Brake pads F/R - Ferodo DS2500
OEM Subaru Impreza Brake Flexi Clamp Retainer Kit   627013001; 25546GA400
OEM Subaru Impreza Handbrake Cable Retaining Clip   26042AA030
OEM Subaru Impreza 92-00 Genuine LH Rear Brake Pipe
OEM Subaru Impreza 92-00 Genuine RH Rear Brake Pipe
Winter : masina va sta la caldura
Summer
OZ Alleggerita 17"
Yokohama Advan Neova 225/45/17
Handling & Suspension
Suspension BC Racing (imprumutata temporar de la Pluto, pana cand reusim sa luam o suspensie noua OEM)
OEM Subaru Impreza Turbo 92-05 Steering Rack Mount Brackets & Superpro Bushes
OEM Subaru Impreza Bottom Ball Joint Cone Adapter For Alloy Arms
OEM Subaru Impreza 92-00 Heavy Duty Uprated Rear Anti Roll Bar Chassis Mount Fixing Kit
OEM Subaru Impreza Turbo Trailing Arm Bolt & Nut Front   20540AA080 902350006
OEM Subaru Impreza Turbo Trailing Arm Bolt & Nut Rear   901000109 902350006
OEM Subaru Impreza Rear Diff Outrigger Bracket Bolts   010108200 010108206 901000303
OEM Subaru Impreza Rear Stut Mounting Bolts & Nuts                   20550AA010 20540AA100
OEM Subaru Impreza Turbo 92-00 Rear Subframe Mounting Bolt Set
OEM Subaru Impreza, Legacy & Forester Rear Diff Outrigger Washer    41324FA000
OEM Subaru Impreza Rear Anti Roll Bar Drop Links
OEM Subaru Impreza Turbo Rear Lateral Link Inner Bolt Kit   20560AA030 901000110 902350006
OEM Subaru Impreza Turbo Rear Lateral Link Inner Toe in Adjust Bolt Kit   20540AA111 20560AA011 20560AA000 902350006
OEM Subaru Impreza, Forester & Legacy Rear Anti Roll Bar Link, Nuts & Bolts Fitting Kit
OEM Subaru Impreza 92-00 Rear Diff Outrigger Mounting Bolts   41332FA000
OEM Subaru Impreza Turbo 92-00 JDM Rack End & Boot Kits   34140AA040 34140AA030 34141AA041 34141AA042 34161SA000 34161SA001 34135FC000
OEM Subaru Impreza 92-07 Outer Lateral Link Bolt Set
Powerflex Rear Tie Bar Front Bushes    PFR69-117BLK
Powerflex Rear Tie Bar Rear Bushes    PFR69-115BLK
Powerflex Rear Tie Bar Bushes                    PFR69-110BLK
Powerflex Rear Diff Mount Early models    PFR69-123BLK
Powerflex Rear Tie Bar Bushes                    PFR69-111BLK
Powerflex Rear Diff Mount                    PFR69-122BLK
Powerflex Front Wishbone Front Bush   PFF69-101
Powerflex Front Wishbone Rear Bushes   PFF69-102BLK
Powerflex Rear beam mount   PFR69-118BLK
Interior & Audio
STI v9 steering wheel
Lamco Gauges
Dash Centre and Vents
Dash board vents
Triple Dash Gauge Pod 52mm
Subaru Impreza Double Dash Cup Holder   66150FC010OE
Subaru Impreza Version 4 to 6 Gear Lever Gaiter   92072FC000
Exterior
Bonnet vents
Subaru Impreza GC Saloon Genuine Rear Boot Lid Seal
Subaru Impreza 92-00 Scuttle Panel Bonnet Seal
Hella horns
Front mud guard und, lh Impreza GT - 59110FA071   59110FA071
Front mud guard und, rh Impreza GT - 59110FA061   59110FA061
Subaru Impreza Turbo 92-00 LH Arch Liner
Subaru Impreza Turbo 92-00 RH Arch Liner
Clip-bumper, side Impreza GT/WRX/STI - 57728AC090   57728AC090
Clip front bumper Impreza GT/WRX - 59122FA010   59122FA010
Clip bumper Impreza, Legacy, Forester - 909140007   909140007
Subaru Impreza 92 Onwards Bonnet Insulation Retaining Clip   90814FC001
Subaru Impreza 92-00 Manual Radio Aerial
Subaru Impreza 96-00 Number Plate Light & Bracket   ICP7720
Subaru Impreza 92-00 Front Grille Clip Set   ICP11953
Subaru Impreza Genuine STi Front Wing Badge    ST9100055010
Subaru Impreza 01 on STi Subaru Tecnica Interantional Door Sticker LH   ICP9830
Subaru Impreza 01 on STi Subaru Tecnica Interantional Door Sticker RH   ICP9829
Subaru Impreza Genuine Type R Rear Hockey Stick Sticker
Depo smoked side marker lights repeaters
Crystal Black Front Indicators
Subaru Impreza Turbo 98-00 Version 5/6 Facelift Front Bumper
Subaru Impreza Turbo V5 & V6 Front Bumper Lower Vent Cover LH
Subaru Impreza Turbo V5 & V6 Front Bumper Lower Vent Cover RH
Subaru Impreza GC & GF Side Sill Fitting Kit Genuine Parts
Subaru Impreza 92-00 Washer Bottle & Pumps
Subaru Impreza 92-02 Front Window Stabilizer Guide 61256FE020
Subaru Impreza 2 Door RH Genuine Door Seal
Subaru Impreza 2 Door RH Genuine Window Seal
Subaru Impreza 2 Door LH Genuine Door Seal
Subaru Impreza 2 Door LH Genuine Window Seal
Subaru Impreza 2 Door LH Outer Weather Strip Window Scraper 62061FA030
Subaru Impreza 2 Door RH Outer Weather Strip Window Scraper 62061FA020
Subaru Impreza 92-00 Front Window Glass Stopper
Subaru Impreza 96-00 2 Door Quarter Window Trim Fitting Kit
Subaru Impreza 92-00 Rear Arch Protector Rubbers
Subaru Impreza 92-00 Side Sill Cover Black Protector Strip
Title: Re: Un alt cotet numit "Goofy" - GC8 Type R
Post by: Mihaistan on January 13, 2018, 08:11:02 AM
Sa o stapanesti sanatos ! Acum inteleg de ce vrei finala de sti :))
Post by: MihaiFlorescu on January 13, 2018, 08:45:54 AM
Wow! Ce nebuni!
Sa o stapanesti sanatos si sa iti mearga bine si cum mai vrei tu.
Post by: Pfaizzzer on January 13, 2018, 08:59:56 AM
Foarte frumoasa! Mare lucru ca e stoc!
Bine a venit in colectie!
Post by: andea79 on January 13, 2018, 09:31:32 AM
Felicitaaaari!!! si distractie maxima cu ea !!!
Ai mai cumparat si loc de parcare de la vecini ?  :)
Post by: Musiu on January 13, 2018, 10:01:50 AM
Bravo Daniel, felicitări pentru achiziție!!!
Post by: dan.pavel on January 13, 2018, 18:06:21 PM
BV man! Sa o stapanesti fara incidente! Abia astept sa vad cotetul
Post by: daniel.gugu on January 13, 2018, 18:59:38 PM
Multumesc mult tuturor!
@MihaiStan ... Deci, e a mea?
@andea79 ... Norocul meu ca vecinul a fost subarist in trecut ...
Post by: andea79 on January 13, 2018, 19:02:50 PM
in a 7-a poza , la o privire rapida pe telefon m-am speriat ca in spate se vede ceva STI negru 2011+ cu eleron :)
Post by: STI on January 14, 2018, 11:00:01 AM
sa te bucuri de acaret! arata foarte bine masina
Post by: Dragos Aron on January 14, 2018, 12:01:06 PM
Pfff, sa o stapanesti sanatos! Pare sa fie intr-o stare extraordinara :)
Post by: ady_viteza on January 14, 2018, 12:03:46 PM
Se inmultesc GC8 -urile in 2 usi  :D
S-o stapanesti sanatos si sa te bucuri de ea  ...in mainile tale sunt sigur ca va arata in curand extraordinar  :D
Post by: daniel.gugu on January 15, 2018, 06:00:19 AM
@Vali ... not yet  ;D
@STI ... thx man
@Dragos ... Chiar este intr-o stare extraordinara
@Ady ... La cat mai multe in Romania ...
Post by: Heliotropus on January 15, 2018, 07:36:08 AM
La Daniel cred ca a fost mai degraba o constrangere  ;) N-ai citit, omul a zburat cu linii aeriene private, jet-uri, fite, invitati celebrii din lumea auto, bauturi fine, mancaruri exclusiviste, cazari la Ritz asa ca nu i-a mai ramas buget de o berlina cu 4 usi; a cumparat de cati bani mai avea in buzunaru' de la piept  ;D
Ma-ntreb cum va face loc Daniel in noua-i masina de serie scurta pentru a-si duce covoarele la Nufarul si a cara sacii cu struguri pentru vin??? :P
Pana cand voi afla raspunsul ma aliniez colegilor care deja i-au urat ganduri bune, rabdare si tutun din belsug pentru a avea inspiratia necesara de a-si definitiva noua provocare tehnica! Succes si sa ne revedem cu bine!
Post by: Muttley on January 15, 2018, 08:08:49 AM
....tutun din belsug.....
Face cumva si aici rezolva  ???
Daniel, sa-ti fie de bine cupeu'.
Post by: raduprint01 on January 15, 2018, 10:22:04 AM
Bravo man, misto achizitia, si inteleg acum de ce nu mai ai bani de jante :))
incredibil de bine poate sa arate
Post by: andrei80 on January 16, 2018, 09:29:06 AM
Superba!
Post by: daniel.gugu on January 17, 2018, 00:33:10 AM
Multumesc mult ...
Weekend-ul asta avem program de up-grade - uri OEM, revizie completa, impachetare in ceara si o constatare cap-coada ...
@ Lorian ... O sa transporte doar produsul finit din struguri, maxim 2-3 sticle  ...  ;D
Post by: 2xGhe on February 20, 2018, 22:33:42 PM
Bravo Dani! Sa te bucuri si de asta, o sa ajungi sa ai cate una pentru fiecare zi din saptamana ;)
Post by: malakay on February 21, 2018, 10:04:51 AM
SA O STAPANESTI SANATOS  !!!!
Post by: daniel.gugu on February 23, 2018, 05:37:04 AM
Multumesc mult pentru ajutor!!!
Sa fim sanatosi cu totii!!!
Post by: daniel.gugu on March 12, 2018, 05:59:21 AM
11.03.2018
Intors de la zapada si serpentine am simtit nevoia sa iesim la o plimbare.
Soare, 20C, uscat pe jos si anvelope de iarna ...
(https://s14.postimg.org/5dv5f7rdt/image.jpg) (https://postimg.org/image/ctuf10f31/)
(https://s14.postimg.org/h2z539idd/image.jpg) (https://postimg.org/image/brk8ijwal/)
(https://s14.postimg.org/c4bmopjpd/image.jpg) (https://postimg.org/image/ch30uw1z1/)
(https://s14.postimg.org/h2z538v81/image.jpg) (https://postimg.org/image/3ytkqk365/)
(https://s14.postimg.org/5qmjlfjy9/image.jpg) (https://postimg.org/image/ujw3m32yl/)
(https://s14.postimg.org/gq7qx1psx/image.jpg) (https://postimg.org/image/x17utd2al/)
(https://s14.postimg.org/k9tomu5dd/image.jpg) (https://postimg.org/image/mr5fu3p9p/)
(https://s14.postimg.org/kzcgz8vn5/image.jpg) (https://postimg.org/image/513r941f1/)
(https://s14.postimg.org/g0oykpk4h/image.jpg) (https://postimg.org/image/yt0toagil/)
(https://s14.postimg.org/rd1k2h5o1/image.jpg) (https://postimg.org/image/3m26kd5gt/)
Post by: Pfaizzzer on March 12, 2018, 11:16:11 AM
Superba! Pastreaz-o cat mai originala!
Post by: MihaiFlorescu on March 12, 2018, 12:04:41 PM
Woaaaa! Acum am vazut ca e cu DCCDeu si limitare la 8k  :-X :-*
Post by: daniel.gugu on March 12, 2018, 19:29:10 PM
5MT DCCD ... foarte rara si scumpa. o punem la pastrat si ii facem swap la 6MT DCCD ... iar limitarea la 8k nu am atins-o inca ...
Post by: daniel.gugu on March 18, 2018, 21:11:45 PM
Si ceva teste ...
@Dragos ... farurile originale sunt in tipla si puse la pastrat ...
(https://s13.postimg.org/oqoke5kzr/20180317_130504.jpg) (https://postimg.org/image/82x2bnq83/)
(https://s13.postimg.org/gz7uf7bl3/20180317_130004.jpg) (https://postimg.org/image/4kl2evk2r/)
Post by: MihaiFlorescu on March 18, 2018, 21:14:38 PM
Cam USA style, dar arata bine. Daca iti place stilul e la fix.
Post by: Heliotropus on March 19, 2018, 00:15:04 AM
Cu totii stim ca exigenta este sinonima cu numele tau insa cand reusesti sa schilodesti traditia, unicitatea si totodata emblematica identitate a unui model consacrat la scara planetara imi vine sa ma spanzur cu cureaua de la ceas  >:(
Traditia tine de spiritualitate si de raportul cu fiinte ori lucruri emblematice, absolutul intruchipat in identitatea unui proiect, in cazul tau emblematicul Goofy.
Asadar, de ce eu as vrea sa admir un Subaru GC8 Type R autentic? Pentru a-mi aminti de filosofia japoneza, pentru a nu ma pierde intr-un no man`s land in care balteste stereotipul, superficialitatea si banalul cotidian, pentru ca nu mai exist in niciun fel prin stirbirea identitatii originare.
Observ in societate o tendinta procustiana a asimilarii tuturor modelelor de exprimare valorica asazis moderne si a ajustarii lor pe acelasi calapod  - oameni buni iesiti din tiparele care degradeaza traditia prin schingiuirea identitatii!
Spre deosebire de alte marci, Subaru nu-i ofera apartenenta, confort si siguranta doar trupului ci si sufletului.
Post by: Dragosh10 on March 19, 2018, 09:55:29 AM
Si ceva teste ...
Post by: Muttley on March 19, 2018, 12:00:56 PM
... cand reusesti sa schilodesti traditia, unicitatea si totodata emblematica identitate a unui model consacrat la scara planetara imi vine sa ma spanzur cu cureaua de la ceas  >:(
Dragilor, vreau sa va reamintesc de cateva detalii...
Cand un bun se afla in proprietatea cuiva, acel cineva are libertate deplina, ii poate face ce doreste. In cazul de fata, Daniel poa' sa-i puna si 4 usi daca asta-l face fericit.
Daca doriti sa aratati ca originalitatea e valoroasa, luati la puricat saiturile cu masini de afara, luati-va si voi cate un exemplar si dati ce exemplu vreti.
Pe mine (nu ca ar conta prea tare), ma doare de calitatea clasei politice, de faptul ca s-a dus naiba clima, ori ca am fire albe pe cap. Nu mai pot eu de farurile de pe masina din topicul asta. Dar daca mi-ar pasa de farurile de pe masina asta, n-as scrie nimic aici, pentru ca, vezi mai sus, a.k.a. nu-i treaba mea.
Asadar, spor la urmarit anunturile de vanzare cu GC-uri in 2 usi ;)
Post by: daniel.gugu on March 19, 2018, 16:08:06 PM
Guys ... am spus de la inceput ... "CEVA TESTE..."
@Lorian ... o mica comparatie : de la stanga la dreapta : OEM, AM v1, AM v2 "USA style" cu zicea Mihaita ...
(https://s13.postimg.org/by5yu8bxj/test.jpg) (https://postimg.org/image/7p18s28o3/)
Post by: MihaiFlorescu on March 19, 2018, 16:12:16 PM
Mijloc. Si tine originalele pentru cand o sa vinzi masina 100% original ;)
Post by: Dragosh10 on March 19, 2018, 16:17:49 PM
..........speram sa nu fiu nevoit sa elaborez dar here I go:
1.Tot ce a facut la masina asta imi place la nebunie, cam astea as fi facut si eu daca eram in locul lui, inclusiv farurile!
2. Suntem pe un forum(imagine that) si fiecare avem dreptul la o parere si sa o expunem indiferent ca este sau nu pe placul cuiva
3.emoticoanele mele de mai sus (Dani Gugu stie) se refera la faptul ca am sugerat ca aceasta masina sa ramana cat mai aproape de stock dat fiind raritatea ei - drept urmare >
Quote
4.
Quote
Total de acord!
5.
Quote
- dar te doare de emoticoanele mele in schimb?
6.
Quote
Multumim!  ;)
Post by: Heliotropus on March 19, 2018, 18:45:43 PM
@Daniel Gugu: in opinia mea frumusetea este relativa, subiectiva si interpretativa, ca atare te rog sa imi ignori libera-mi cugetare din postul trecut.
@Dragii mei prieteni: judecand dupa sintagma conform careia fiecare isi poate aduce aportul artistic la bunul pe care l-a achizitionat sunt intrutotul de acord. Fiecare are dreptul legitim pentru a se manifesta in trend cu moda iar saltul de la autenticitate la barbarie, implinind un capriciu de etapa, va cunoaste declinul prin deprecierea obiectului ceea ce ne releva ciclul de viata al unui produs efemer  :'(
In aceeasi ordine de idei liber exprimata de bunii mei prieteni, astept sa vad si cateva sculputuri antice ori renascentiste aflate in colectii private carora li se vor adauga vesminte de firma, genti de mana sau de umar ultimul racnet, cusute manual la Paris, si neaparat machiaj + parfum in ton cu toanele proprietarului ori cu tendintele modei  ;D :P
L.E.: promit sa nu mai fac aprecieri pe marginea lui Goofy si ma astept sa vad chiar si o salba de LED-uri dispusa chic  >:D
Post by: Muttley on March 19, 2018, 19:11:01 PM
Eram siiiiiiiiiigur!!!
Leduri! =))))))
Post by: daniel.gugu on March 19, 2018, 20:01:06 PM
@Lorian ... Ca intre prieteni, imi doresc sa nu te tii de promisiune.
@All ... Cum am spus la inceput "CEVA TESTE" ... rezultatele "testului" sper sa fie gata in cateva saptamani !!!
Fiecare parere conteaza!!!
CONCLUZIA ZILEI : MASINA VA RAMANE OEM / STOCK!!!
Post by: daniel.gugu on April 01, 2018, 01:03:16 AM
(https://s31.postimg.org/egnthu3ej/20180331_193133.jpg) (https://postimg.org/image/82yqekyif/)
Post by: MihaiFlorescu on April 01, 2018, 08:06:15 AM
Sa te bucuri de ele (numere si roti)!
Post by: Heliotropus on April 01, 2018, 22:13:26 PM
Dupa ce am inteles semnificatia cifrelor "571" ("STI" - n.n.) remarc si o culoare potrivita a jantelor, ca sa nu spun fascinanta, ce contureaza sau mai bine zis accentueaza discret dar fundamental identitatea masinii tale.
Nu in ultimul rand, observ si totdata salut reintregirea formei pe fondul pastrarii identitatii masinii - au reaparut blocurile optice originale.
Acum pot afirma, fara a fi linsat de catre unii sau altii, ca asist la o ierarhizare a valorilor prin recastigarea libertatii de exprimare si creatie fara a se "redefini" originalitatea acestui monument al liniei sportive create de Subaru.
Ce aspect nobil poate avea o masina ale carei elemente definitorii raman la locul lor. Succes!
Post by: daniel.gugu on April 06, 2018, 07:16:50 AM
O scurta plimbare in miez de noapte ...
(https://s18.postimg.org/6p6hn9x5l/20180405_234451.jpg) (https://postimg.org/image/ir1vhf6dx/)
(https://s18.postimg.org/ehx5f8np5/20180405_234519.jpg) (https://postimg.org/image/d2vkqimlx/)
Post by: Heliotropus on April 06, 2018, 07:44:01 AM
Mașinile din parcul tău, cu excepția XT-ului, suferă de fotofobie căci le văd circulβnd decβt la lumina lunii?  ;D :P 8)
Post by: Muttley on April 06, 2018, 08:53:37 AM
Păi dăcβt βn mez de nuapte duarme ăea cu radarurili ;)
Post by: daniel.gugu on April 24, 2018, 18:13:58 PM
Dar ne plimbam cu ea si ziua ... chiar si la munca ...
(https://s14.postimg.cc/x8562ssjl/20180423_065107.jpg) (https://postimg.cc/image/yzy4xpbwd/)
(https://s14.postimg.cc/l69s8nyqp/20180423_100046.jpg) (https://postimg.cc/image/8rn08c78d/)
(https://s14.postimg.cc/p2n44nc0h/20180424_044831.jpg) (https://postimg.cc/image/9tx6qvibx/)
Post by: daniel.gugu on April 24, 2018, 18:17:08 PM
Si cum e la moda swap-ul la 6MT ... ne pregatim si noi sa urcam pe Goofy un 6MT DCCD
(https://s14.postimg.cc/det29qchd/20180422_130336.jpg) (https://postimg.cc/image/idgko9ga5/)
(https://s14.postimg.cc/qvq0sluip/20180423_200140.jpg) (https://postimg.cc/image/v4uqurxrx/)
(https://s14.postimg.cc/jfqr6tej5/20180423_200143.jpg) (https://postimg.cc/image/g8w7n6u31/)
Post by: MihaiFlorescu on April 25, 2018, 02:48:31 AM
Lucrezi la OMV? :D
Bafta la swap!
Post by: Mihaistan on April 27, 2018, 23:06:27 PM
Pe viitor mai mult curaj din prima   >:D
Post by: daniel.gugu on April 27, 2018, 23:34:35 PM
asa ar trebui ...
Post by: daniel.gugu on May 30, 2018, 12:03:33 PM
Si cum prea mult stres dauneaza grav sanatatii … am zis sa ma relaxez un pic.
Asa ca … am urcat masina pe capre si am inceput sa desfac.
(https://s33.postimg.cc/r9ui9lb9b/image.jpg) (https://postimg.cc/image/mnye18pq3/)
Roata de rezerva si altele :
(https://s33.postimg.cc/ttuqgzdrz/Roata_rezerva.jpg) (https://postimg.cc/image/6fmr51vuj/)screenshot (https://postimages.org/app)
(https://s33.postimg.cc/hrzcn2wwf/Rep_1.jpg) (https://postimg.cc/image/50l6gkn4b/)
(https://s33.postimg.cc/4b2e48p5r/Rep_2.jpg) (https://postimg.cc/image/g06ds7g4b/)
(https://s33.postimg.cc/4b2e49rqn/Rep_3.jpg) (https://postimg.cc/image/hf7ygyjsb/)
(https://s33.postimg.cc/ujditn44f/Rep_4.jpg) (https://postimg.cc/image/pxhelail7/)
(https://s33.postimg.cc/yfqupm9of/Rep_5.jpg) (https://postimg.cc/image/bea9jva0r/)
(https://s33.postimg.cc/k9b3uetof/Rep_6.jpg) (https://postimg.cc/image/5q3yt00jf/)
(https://s33.postimg.cc/km2i0kosv/Vop_2.jpg) (https://postimg.cc/image/7hwxnvwqz/)
Am dus la sablat si vopsit electrostatic (@Lorian : vor fi negre oem  ;) )
(https://s33.postimg.cc/i60omcom7/Vop_1.jpg) (https://postimg.cc/image/6to34kfx7/)windows 7 print screen (https://postimages.org/app)
Si apoi, dupa 2 zile in care am urmat toate procedurile : spalare  / degresare / curatare rugina / tratare / matuire / iar degresare / vopsire / lacuire / ceara cavitati) :
(https://s33.postimg.cc/s3bpfxyy7/After_1.jpg) (https://postimg.cc/image/ada0uwld7/)
(https://s33.postimg.cc/kal1nz0ov/After_2.jpg) (https://postimg.cc/image/gqz3y5xyz/)
(https://s33.postimg.cc/aq1f13qsf/After_3.jpg) (https://postimg.cc/image/vmxn5rot7/)
(https://s33.postimg.cc/bsbljn1vz/After_4.jpg) (https://postimg.cc/image/wcgfi4hmz/)
free photo upload (https://postimages.org/)
Pe prima pagina a topicului am reusit sa actualizez si lista de cumparaturi / modificari.
@ Lorian : Masina va ramane 99% OEM si voi incerca sa o fac sa arate aproape 100% ca atunci cand a iesit pe poarta fabricii nipone. (cu exceptia pozitiei volanului)  ;D
Post by: MihaiFlorescu on May 30, 2018, 12:49:36 PM
Wow! Imi place set-up de canal ca ai acces sa tii/ridici cu cricul si totusi iti permite sa intri sub masina lejer.
Foarte tare ce ai facut la masina. Ceva de genul asta mi-ar placea si mie sa fac.
Post by: Heliotropus on May 30, 2018, 15:56:37 PM
Nu numai ca iti apreciez atitudinea indreptata spre procesul de restaurare insa exemplul tau plin de insemnatate istorica este urmat, din nefericire, doar de cativa colegi ai forumului. Nicidecum nu folosesc cuvinte mari ci vorbesc despre o marca japoneza ce se confrunta cu propriile sale limite existentiale intr-un tumult al noii piete de consum bazata pe reguli avatice.
Cred ca, in calitate de formatori ai atentiei pentru un producator de serii scurte, impreuna cu cativa colegi tipicari (unii de pe la Brasov, altii de prin Bucuresti, Sibiu si mai era un constantean da' cam scump la vedere in ultima vreme  :D) ar trebui sa va organizati astfel incat masinile voastre sa ajunga, la un moment dat, intr-o galerie nationala a marcii Subaru.
Este evident faptul ca arta retinala este menita doar sa incante privirea, in timp ce satira si umorul au darul de a prezerva lucrarile de capcanele prestigiului insa unii dintre posesorii marcii care concentreaza purul spirit nipon isi elibereaza, uneori, fraiele creativitatii fara a avea cunostinte despre estetica iar rezultatul este mai aproape de grotesc ori de kitsch.
Autoturismele noastre nu trebuie sa devina expresia complexa a unui dramatism existential, trait ca experienta individuala si istorica ci mai degraba o forma de a conserva, cel putin la exterior, inventivitatea, creatia artistica si spiritul echipelor de designeri care au elaborat o forma pe un fond al stiintei in corelatie cu istoria.
Ma intreb ce s-ar intampla daca un colectionar de arta care a achizitionat celebra statuie David, a lui Michelangelo Buonarroti, i-ar acoperi trupul cu vesminte brodate pe goblen iar in mana dreapta i-ar infige un fanion al F.C. Scornicesti?
Felicitari pentru amplul si costisitorul proces de conservare al masinii si astept cu emotii sa vad rezultatul final!
P.S: In caz ca scoti masina la plimbare si accepti un novice sa iti stea in dreapta te rog sa tii cont de rugamintea de a-ti fi alaturi pret de cate minute binevoiesti  ;D
Post by: daniel.gugu on May 30, 2018, 17:16:41 PM
@MIhai … dupa ce o scot din curte … te astept cu a ta sa facem aceleasi operatiuni …
@ Lorian … iti promit ca primul drum al masinii dupa restaurare va fi prin "paradis" cu tine la volan.
Post by: daniel.gugu on June 06, 2018, 22:49:44 PM
Primele piese vopsite :
(https://s22.postimg.cc/3zfcmssvl/20180602_081136.jpg) (https://postimg.cc/image/s364b3bcd/)
Si am profitat de weekendul prelungit :
(https://s22.postimg.cc/abuhwwbg1/20180601_183615.jpg) (https://postimg.cc/image/9mbpkjawd/)
(https://s22.postimg.cc/7vsoiqvup/20180601_183623.jpg) (https://postimg.cc/image/6gr3u0urh/)
Chirurg principal Malakay :
(https://s22.postimg.cc/9mbpkjy1t/20180602_145234.jpg) (https://postimg.cc/image/50flc7cil/)
(https://s22.postimg.cc/8lbgv4yz5/20180603_162359.jpg) (https://postimg.cc/image/7vsoiryfh/)
(https://s22.postimg.cc/51pj5bgtt/20180603_162404.jpg) (https://postimg.cc/image/4c6qsyga5/)
(https://s22.postimg.cc/j85a0jc9d/20180603_162411.jpg) (https://postimg.cc/image/fbry4jr9p/)
In asteptare de timp liber :
(https://s22.postimg.cc/ad4fq1q1t/20180603_181716.jpg) (https://postimg.cc/image/cug6xb9y5/)
(https://s22.postimg.cc/y43t85atd/20180603_181719.jpg) (https://postimg.cc/image/kn6upa0hp/)
(https://s22.postimg.cc/iimho6jfl/20180603_181721.jpg) (https://postimg.cc/image/5r8bho9nh/)
Post by: daniel.gugu on June 07, 2018, 21:41:21 PM
O zi superba ... plina de curieri ...
Asteptam timpul liber sa incepem sa urcam pe masina ...
(https://s33.postimg.cc/plbp0rdz3/20180607_125043.jpg) (https://postimg.cc/image/i5cfeyq9n/)
(https://s33.postimg.cc/hftn2lxfz/20180607_125052.jpg) (https://postimg.cc/image/vz0s40qkr/)
(https://s33.postimg.cc/thp0wpwdr/20180607_125143.jpg) (https://postimg.cc/image/516v28vmz/)
(https://s33.postimg.cc/fb9a1j3j3/20180607_210352.jpg) (https://postimg.cc/image/m1prayqor/)
(https://s33.postimg.cc/y3l5547n3/20180607_211502.jpg) (https://postimg.cc/image/ss68kelkb/)
Post by: Heliotropus on June 07, 2018, 22:35:09 PM
Dacă asamblezi, "cum trebuie", piesele livrate prin curier poate te căpătuiești și cu o motocicletă  ;D
L.E.: ...si dam si o tura prin cartier fara sa trezim mai mult de 100 de familii  ;)
Post by: Muttley on June 07, 2018, 23:37:06 PM
Ce e diferit la filtrul de ulei?
Post by: daniel.gugu on June 08, 2018, 04:09:28 AM
@ Muttley : Scrie pe el "Engine only"  ;D ;D ;D
@ Heliotropus : Eu sper sa nu se intample asta  ;D ;D ;D
Post by: MihaiFlorescu on June 08, 2018, 10:46:19 AM
Citisem pe undeva pe internet ca sunt diferente la supapa de bypass si unii zic ca ar fi un element de filtrare ceva mai rezistent pentru ca teoretic sunt presiuni mai mari si temperaturi mai mari pe motoarele pe care se pune (pompe de ulei marite etc.). Daaar.. sunt doar vorbe pe internet. Cred ca Tom stie cel mai bine care e treaba.
Post by: daniel.gugu on July 12, 2018, 09:23:04 AM
Distractia continua … Toata podeaua curata / vopsita / ceruita :
(https://s33.postimg.cc/b8g06rnqn/20180624_205755.jpg) (https://postimg.cc/image/8r48zi3u3/)
(https://s33.postimg.cc/9gn1bvjtb/20180624_205806.jpg) (https://postimg.cc/image/d08z1omiz/)
(https://s33.postimg.cc/93vn5p99b/20180624_205808.jpg) (https://postimg.cc/image/69shs972z/)
Si a venit vremea sa punem la loc diverse piese :
(https://s33.postimg.cc/nzu6defjz/20180617_132005.jpg) (https://postimg.cc/image/qh5xknzgb/)
(https://s33.postimg.cc/s8ywfky8v/20180624_181702.jpg) (https://postimg.cc/image/q4ejehwm3/)
(https://s33.postimg.cc/7ou2h3xxb/20180624_205959.jpg) (https://postimg.cc/image/to0h4berf/)
(https://s33.postimg.cc/7ou2h3q7j/20180624_210046.jpg) (https://postimg.cc/image/bxysj9tgr/)
(https://s33.postimg.cc/a65tompm7/20180703_193157.jpg) (https://postimg.cc/image/qtxbr4kdn/)
(https://s33.postimg.cc/es1xwziv3/20180703_193208.jpg) (https://postimg.cc/image/fhkq9cjej/)
Multe piese OEM venite, inclusiv toate chederele :
(https://s33.postimg.cc/5x13mic33/20180710_214726.jpg) (https://postimg.cc/image/5x13mic2z/)
(https://s33.postimg.cc/nabe1dujj/20180710_214820.jpg) (https://postimg.cc/image/p24cwadwb/)
(https://s33.postimg.cc/6mjvywf7j/20180710_214934.jpg) (https://postimg.cc/image/9gn1cchdn/)
(https://s33.postimg.cc/opcyq43cf/20180710_214943.jpg) (https://postimg.cc/image/bxysjltkb/)
(https://s33.postimg.cc/sn08expzj/20180710_214944.jpg) (https://postimg.cc/image/u21t3nr2j/)
(https://s33.postimg.cc/70l7xwz4v/20180710_214949.jpg) (https://postimg.cc/image/7q40a9zob/)
Aseara ... dupa 4h de chin, singur dar cu ajutorul a 3 cricuri ... am reusit sa urc pe masina 6MT DCCD ...
(https://s33.postimg.cc/6nttry6n3/20180711_232818.jpg) (https://postimg.cc/image/m9b5bwil7/)
(https://s33.postimg.cc/rxhg2ta33/20180711_232853.jpg) (https://postimg.cc/image/j2glsalaj/)
Sambata va pleca la vopsitorie totala ... deci tragem tare sa o pregatim ...
Post by: Muttley on July 12, 2018, 09:51:45 AM
(jawdrop)
Impresionant, felicitari! Si in special pentru performanta (zic eu) de a agata de masina cutia aia de unul singur.
Post by: MihaiFlorescu on July 12, 2018, 09:57:21 AM
No comment! Ba da, unul: Credeam ca o faci sa mergi cu ea, nu de dus la muzeul Subaru :D
Post by: Heliotropus on July 12, 2018, 10:51:33 AM
Vazand exponatul m-a dus gandul, ca si pe Mihai, ca masina va fi pregatita pentru muzeu sau vreo expozitie temporara ori pentru vreun memorial... ;D
De curiozitate, dupa ce vei incheia proiectul acesta va fi tezaurizat in patrimoniul national sau il depui alaturi de comorile umanitatii? Si o ultima intrebare, cand va avea loc vernisajul si la ce galerie de arta contemporana?  :P
P.S.: de emotii am uitat sa iti adresez felicitarile cuvenite pentru perseverenta, viziune si nu in ultimul rand pentru eforturi!
Post by: daniel.gugu on July 14, 2018, 19:28:11 PM
Multumesc baieti!!!
Azi am reusit sa trimitem masina la vopsit ... Noua culoare : surpriza !!!
Avem 2 saptamani la dispozitie sa terminam motorul.
(https://s22.postimg.cc/sqlixhb01/20180714_095329.jpg) (https://postimg.cc/image/sdu4rasq5/)
(https://s22.postimg.cc/b0jucgcup/20180714_095348.jpg) (https://postimg.cc/image/6rf4aa9l9/)
(https://s22.postimg.cc/lam9bm2pd/20180714_095358.jpg) (https://postimg.cc/image/fz7cqwgml/)
Post by: Dragosh10 on July 15, 2018, 22:48:05 PM
WR-Blue???
Post by: andrei0241 on July 16, 2018, 01:07:40 AM
Personal n'as merge pe WR blue cand da asa bine cu griul asta. Plus ca pe dedesubt a facut'o deja gri ... tonul a fost dat :P
Post by: daniel.gugu on July 16, 2018, 08:55:24 AM
Culoarea de baza va fi tot gri …
Post by: Heliotropus on July 16, 2018, 09:21:44 AM
Iar cea de acid, in functie de pH, se poate selecta dintre urmatoarele  >:D:
- verde malachit
- albastru de bromtimol
- indigo carmine
- violet de bromcrezol
- rosu Congo
 ;D
Post by: MihaiFlorescu on July 16, 2018, 09:32:19 AM
Culoarea nu o schimba ca la cat a fost pe la RAR cu masina asta, sigur nu ii arde de inca un drum acolo.
Asa ca o sa fie un RB5 probabil, sper. Altfel se va dovedi a fi un fan VAG pana la capat si ii da un nardo grey.
Post by: Forester on July 16, 2018, 11:45:45 AM
Ceea ce pe vremea "mea" se numea Urban Grey, adica un gri metalizat dar mai inchis:  8)
(http://zombdrive.com/images/2007-subaru-forester-11.jpg)
Post by: daniel.gugu on August 06, 2018, 09:12:43 AM
Avand putin timp liber, profit sa fac un mic up-date.
La vopsitorie s-a tot lucrat … dezechipare …
(https://s33.postimg.cc/8qzh5zkdb/IMG-20180717-_WA0012.jpg) (https://postimg.cc/image/b8b8d949n/)
(https://s33.postimg.cc/81gotmrjj/IMG-20180717-_WA0013.jpg) (https://postimg.cc/image/81gotmrjf/)
(https://s33.postimg.cc/whyuo3zzz/IMG-20180717-_WA0014.jpg) (https://postimg.cc/image/aisg0wj5n/)
(https://s33.postimg.cc/m7wfovpjz/IMG-20180717-_WA0015.jpg) (https://postimg.cc/image/57djg7cij/)
(https://s33.postimg.cc/uq5vt7ocv/IMG-20180717-_WA0016.jpg) (https://postimg.cc/image/453cxnlzf/)
(https://s33.postimg.cc/zc201kpbj/IMG-20180717-_WA0017.jpg) (https://postimg.cc/image/whyuo4n57/)
… retusari ...
(https://s33.postimg.cc/ljnl5iqpr/IMG-20180718-_WA0043.jpg) (https://postimg.cc/image/j2bty96t7/)
(https://s33.postimg.cc/haiv3cv67/IMG-20180718-_WA0044.jpg) (https://postimg.cc/image/szmurbm4r/)
(https://s33.postimg.cc/hna99jl5r/IMG-20180718-_WA0045.jpg) (https://postimg.cc/image/et73w3izf/)
(https://s33.postimg.cc/rxco8sir3/IMG-20180718-_WA0046.jpg) (https://postimg.cc/image/58nh981d7/)
(https://s33.postimg.cc/z0kjoevwf/IMG-20180718-_WA0047.jpg) (https://postimg.cc/image/6axnrrrwb/)
... fuller ...
(https://s33.postimg.cc/gxrgxjnan/IMG-20180723-_WA0029.jpg) (https://postimg.cc/image/yb1rceiln/)
(https://s33.postimg.cc/wj8shi6yn/IMG-20180723-_WA0030.jpg) (https://postimg.cc/image/urftmlnln/)
(https://s33.postimg.cc/9ujlhy50f/IMG-20180723-_WA0031.jpg) (https://postimg.cc/image/70gg4i2u3/)
(https://s33.postimg.cc/46dar1sy7/IMG-20180723-_WA0032.jpg) (https://postimg.cc/image/qib3kfs23/)
(https://s33.postimg.cc/comqvemm7/IMG-20180723-_WA0033.jpg) (https://postimg.cc/image/ak2dubkzf/)
(https://s33.postimg.cc/950t5lc6n/IMG-20180723-_WA0034.jpg) (https://postimg.cc/image/qib3kg7hn/)
Mostra vopsea ... cod vopsea secret ...
(https://s33.postimg.cc/usprfz7f3/20180804_093559.jpg) (https://postimg.cc/image/wkiqavqrv/)
Post by: daniel.gugu on August 06, 2018, 09:32:23 AM
Iar acasa … motorul este aproape gata …
(https://s33.postimg.cc/nj8sau2r3/image.jpg) (https://postimg.cc/image/8na938rcb/)
(https://s33.postimg.cc/oyaczkbjz/image.jpg) (https://postimg.cc/image/yitzmg0vv/)
(https://s33.postimg.cc/3omqoqaov/image.jpg) (https://postimg.cc/image/t7f31qu8r/)
(https://s33.postimg.cc/uz81wn5vz/image.jpg) (https://postimg.cc/image/qdbxoakcr/)
(https://s33.postimg.cc/4qwx7a17z/image.jpg) (https://postimg.cc/image/7xrgqwlnv/)
(https://s33.postimg.cc/lrftfylz3/image.jpg) (https://postimg.cc/image/pnt5by6yj/)
Post by: andea79 on August 06, 2018, 09:37:21 AM
ioi ma... toate masinile le faci asa shiny si frumoase.. ma faci sa ma simt rusinat cu motorul meu negru si uleios :)
Post by: Heliotropus on August 06, 2018, 09:55:39 AM
Nu numai ca Daniel a atins culmile in detailing insa produsul final cred ca mai degraba va fi muzeificat. Ca atare, unde planuiesti sa-ti expui capodopera, in sufragerie (si o ocoliti cu grija cand va plimbati cu aspiratorul ;D) sau faci o constructie auxiliara pentru glorificarea modelelor SUBARU pe care le detii?
Post by: andea79 on August 06, 2018, 10:00:05 AM
aloo adminii... permiteti limbaj suburban pe forum?!?!
scrie mai sus "subaru muzeificat" :)
Post by: BOXER on August 06, 2018, 10:22:01 AM
@daniel.gugu, cand ajungi spre sfarsit ar fi util sa spui si suma la care s-a ridicat intregul proiect (cu aproximatie).
Ar intelege multi ce inseamna Subaru si mai ales STI.
Post by: MihaiFlorescu on August 06, 2018, 10:25:32 AM
Se cere cafeluta pentru a analiza morfologia lu' "muzeificat" asta.
Post by: daniel.gugu on August 06, 2018, 12:46:14 PM
@Vali … Tinand cont de faptul ca nu voi merge cu masina asta (adica va fi "muzeificata") ar fi si pacat sa nu o fac "shiny si frumoasa" … si aproape 100% OEM
@Lorian ... Pana va fi gata constructia auxiliara, Goofy poate fi zgariat in parcarea subterana de la Inter ...  ;D ;D ;D
@Boxer ... Nu pot face asta pe forum ... Cateodata se mai uita si nevasta pe aici ...  :-X  ;D ;D ;D
@Mihai ... Eu dau cafelutele ... Lorian vine cu analiza ...
Post by: Dragosh10 on August 06, 2018, 12:57:01 PM
@Mihai ... Eu dau cafelutele LA BRASOV ... Lorian vine cu analiza ...
;D :angel:
Post by: BOXER on August 06, 2018, 13:00:50 PM
Toate nevestele citesc forumul. Ele sunt principalele piedici in calea unei masini bine intretinute. :)
Post by: daniel.gugu on August 06, 2018, 14:14:33 PM
@Dragosh … O idee excelenta …  ;D ;D ;D
@Boxer … Hai sa nu fim chiar atat de rai …
Live from cabina de vopsitorie :
(https://s33.postimg.cc/l6ea028sv/IMG-20180806-_WA0007.jpg) (https://postimg.cc/image/ip2issowb/)
(https://s33.postimg.cc/45vdre3hb/IMG-20180806-_WA0008.jpg) (https://postimg.cc/image/rwur9i3ob/)
(https://s33.postimg.cc/nayn15pv3/IMG-20180806-_WA0009.jpg) (https://postimg.cc/image/smdjlvbxn/)
(https://s33.postimg.cc/rk3d3c0u7/IMG-20180806-_WA0010.jpg) (https://postimg.cc/image/5kwyg4jzv/)
(https://s33.postimg.cc/efxsqngi7/IMG-20180806-_WA0011.jpg) (https://postimg.cc/image/ktmvtwle3/)
Post by: Forester on August 06, 2018, 14:34:16 PM
Intrucat nu am verva si complexitatea lingvisto-analitica a lui Lorian, eu voi spune ceva extrem de expresiv si cuprinzator: WOW!
Curiozitatea mea - nu-mi dau seama din sample-ul de culoare, e un fel de gri mai inchis? picatelele albe vor fi sau nu in peisaj? Ca sa stiu cat de aproape am fost cu ghiceala mea.  ;D ;D
Post by: malakay on August 06, 2018, 22:26:30 PM
uuuuhuuu sexy !
Post by: daniel.gugu on August 08, 2018, 08:40:28 AM
Cotet colorat …
(https://s33.postimg.cc/cqqjnmm4v/IMG-20180807-_WA0003.jpg) (https://postimg.cc/image/vj2er7iiz/)
(https://s33.postimg.cc/84uffa8bj/IMG-20180807-_WA0004.jpg) (https://postimg.cc/image/3vppd4523/)
(https://s33.postimg.cc/48h3jav1r/IMG-20180807-_WA0005.jpg) (https://postimg.cc/image/yd5k4o04r/)
(https://s33.postimg.cc/48h3jb2rj/IMG-20180807-_WA0006.jpg) (https://postimg.cc/image/d3hxttrjv/)
(https://s33.postimg.cc/w8l73ldxr/IMG-20180807-_WA0007.jpg) (https://postimg.cc/image/ndkct2p57/)
(https://s33.postimg.cc/72k8wrkdb/IMG-20180807-_WA0008.jpg) (https://postimg.cc/image/z2och1ntn/)
Post by: Pfaizzzer on August 08, 2018, 08:50:03 AM
Speciala si in acelasi timp apropiata de culoarea originala.
Post by: Heliotropus on August 08, 2018, 08:59:06 AM
Desi eu apreciez nuantele de albastru ca definind o masina sport nu pot spune ca acea culoare de grey guzgan (Icreicetus frumentarius) ar reprezenta o alegere nepotrivita pentru un exponat demn de a-si gasi locul in salile Muzeului de Arta Contemporana  >:D
PS: Chiar imi place culoarea si iti urez sa ai multa rabdare pentru a-ti definitiva proiectul! Daca la inaugurarea lui Goofy vei alege acelasi ritual ca la ceremonia de botez/lansare a unei noi nave la apa te rog sa imi spui ca sa pregatesc sticla de sampanie si o nasă   ;D
Post by: Muttley on August 08, 2018, 09:05:18 AM
grey guzgan
Daca vei alege acelasi ritual ca la ceremonia de botez/lansare a unei noi nave la apa te rog sa imi spui ca sa pregatesc sticla de sampanie
Daniel, ai grija, chiar e-n stare sa-i phoota o sticla de sampanie-n capota.
Post by: MihaiFlorescu on August 08, 2018, 10:15:52 AM
Interesanta nuanta de bronz a capatat din perla. Frumos!
Post by: daniel.gugu on August 20, 2018, 07:46:48 AM
Almost ready !!!
(https://s33.postimg.cc/ea84lhzvz/20180817_172003.jpg) (https://postimg.cc/image/fcib41ip7/)
(https://s33.postimg.cc/var0u6kn3/20180817_172017.jpg) (https://postimg.cc/image/aqm6vp4vv/)
(https://s33.postimg.cc/ox1xqxngv/20180817_172213.jpg) (https://postimg.cc/image/jln1681e3/)
(https://s33.postimg.cc/3nebg3evz/20180817_172223.jpg) (https://postimg.cc/image/a13ejcjrv/)
(https://s33.postimg.cc/4pohyn5f3/20180817_172237.jpg) (https://postimg.cc/image/p9tbx4l63/)
Post by: daniel.gugu on August 31, 2018, 09:08:34 AM
In drum spre casa …
(https://s33.postimg.cc/w89j70pov/20180824_160730.jpg) (https://postimg.cc/image/hp2e5lwjv/)
(https://s33.postimg.cc/xajppkvnj/20180824_185052.jpg) (https://postimg.cc/image/rmdeyoraz/)
Alte piese ...
(https://s33.postimg.cc/9jkc7kimn/20180825_091649.jpg) (https://postimg.cc/image/6ph6u4ggb/)
(https://s33.postimg.cc/w89j75ffz/20180830_201250.jpg) (https://postimg.cc/image/bbdb2hhez/)
O noapte interesanta ... admiram si ne pregatim (studiem si citim despre "cum sa montezi un motor pe masina")
(https://s33.postimg.cc/728l0gbmn/20180828_064402.jpg) (https://postimg.cc/image/gms7nc0yj/)
Invatam si punem in practica lucruri noi :
Before 10.00PM
(https://s33.postimg.cc/q7bua8l5r/20180830_201914.jpg) (https://postimg.cc/image/ei7um9u6z/)
After 02.00AM
(https://s33.postimg.cc/te6dtuxvz/20180831_013101.jpg) (https://postimg.cc/image/zf42qxki3/)
Post by: MihaiFlorescu on August 31, 2018, 09:41:10 AM
Ce e vasul din stanga? Cel cu capac mov. IC Water spray?
Post by: daniel.gugu on August 31, 2018, 09:59:01 AM
Ce e vasul din stanga? Cel cu capac mov. IC Water pray?
yeap
Post by: andea79 on August 31, 2018, 10:43:13 AM
si iconitza de la water pray unde este ? :)
Post by: MihaiFlorescu on August 31, 2018, 11:07:05 AM
:D corectat
Post by: daniel.gugu on September 10, 2018, 08:33:42 AM
Un alt weekend plin :
(https://s33.postimg.cc/avgjadgi7/01._New_IC_water_reservoire.jpg) (https://postimg.cc/image/k38rr2nkb/)
(https://s33.postimg.cc/tb107s2cf/image.jpg) (https://postimg.cc/image/57a8jhjvf/)
(https://s33.postimg.cc/b87xgklxb/image.jpg) (https://postimg.cc/image/qgxuucfln/)
(https://s33.postimg.cc/dpjonty3z/04._Under_the_hood.jpg) (https://postimg.cc/image/s8qtp8r8r/)
Prima pornire dupa restaurare :
https://youtu.be/e-sak0NoAjA
HKS Silent Hi-Power exhaust :
https://youtu.be/P8oD8e6zXjY
Goofy a ajuns din nou la vopsitorie pentru ultimele retusuri : polish, ceara ceramica
(https://s33.postimg.cc/b9hv9gsqn/20180908_161025.jpg) (https://postimg.cc/image/469ztunaz/)
(https://s33.postimg.cc/5lbkil3tr/20180908_161057.jpg) (https://postimg.cc/image/9ugakr72z/)
(https://s33.postimg.cc/469ztvagf/20180908_162131.jpg) (https://postimg.cc/image/z0h8rlg2z/)
Post by: Heliotropus on September 10, 2018, 09:33:07 AM
Au uitat sa iti monteze antena de radio sau bugetul nu ti-a mai ajuns pentru infotainment? ;D
Ma intreb cum se va desfasura dialogul holistic dintre tine si masina...cum se va asigura schimbul simplu de informatii dintre pilot, bolid si mediul exterior...??? ::)
Post by: MihaiFlorescu on September 10, 2018, 09:35:23 AM
Ce sa mai comentezi la pozele astea...?
Post by: daniel.gugu on September 10, 2018, 09:55:38 AM
Ma intreb cum se va desfasura dialogul holistic dintre tine si masina...cum se va asigra schimbul simplu de informatii dintre pilot, bolid si mediul exterior...??? ::)
Antena e noua si e la locul ei … pe dreapta masinii …  ;D am mai pastrat ceva din JDM Style …
Pe parte de audio Goofy a primit doar un player Pioneer  DEH-4600BT (dat jos de pe Pluto) si un up-grade de difuzoare :
Fata : Focal Auditor RSE-165
Spate : Focal Auditor RCX-130
Post by: daniel.gugu on June 30, 2019, 23:29:58 PM
Un weekend cu Goofy …
(https://i.ibb.co/D1dT1yk/01.jpg) (https://ibb.co/YNgwNM8)
(https://i.ibb.co/7pLTd0z/02.jpg) (https://ibb.co/HP3Mf92)
(https://i.ibb.co/Mspqt77/03.jpg) (https://ibb.co/rmMnzHH)
(https://i.ibb.co/nRT2KCt/04.jpg) (https://ibb.co/qxzG25V)
(https://i.ibb.co/8sYx0z1/05.jpg) (https://ibb.co/QQDHf8y)
(https://i.ibb.co/9qCrJt1/06.jpg) (https://ibb.co/30LCwzj)
(https://i.ibb.co/D1N965K/07.jpg) (https://ibb.co/zm1XLGf)
(https://i.ibb.co/3kpbT8s/08.jpg) (https://ibb.co/qxN8D4n)
(https://i.ibb.co/qkhZ6v0/09.jpg) (https://ibb.co/18BScks)
(https://i.ibb.co/Rhyn989/10.jpg) (https://ibb.co/GsTw0m0)
(https://i.ibb.co/hH44Zxw/11.jpg) (https://ibb.co/MpttGyQ)
(https://i.ibb.co/Jq9VdB3/12.jpg) (https://ibb.co/C6fgt1P)
(https://i.ibb.co/dJX8pmL/13.jpg) (https://ibb.co/JF8Dp3y)
(https://i.ibb.co/jDQSJVk/14.jpg) (https://ibb.co/FzyFHs4)
(https://i.ibb.co/q7tcKbc/15.jpg) (https://ibb.co/fqhyfmy)
(https://i.ibb.co/pyQdBPn/16.jpg) (https://ibb.co/X8Dtr4V)
Post by: andea79 on June 30, 2019, 23:41:12 PM
mda...nu arata rau gufi asta :)
Post by: Forester on July 01, 2019, 09:49:44 AM
Absolut superb! Felicitari!!!
Post by: MihaiFlorescu on July 01, 2019, 10:36:54 AM
Perfecta! Pana si cenusa din evacuare arata ca motorul merge cu amestecul corect :D
