Resoftare - oare ???
Răspuns: Resoftare - oare ???
« Reply #60 on: February 09, 2013, 12:03:20 PM »
Take it easy. Amandoi
« Reply #61 on: February 09, 2013, 12:11:08 PM »
:D
 :D
 :D sunt fff relax cand stiu cum e masina mea.
« Reply #62 on: February 09, 2013, 14:37:23 PM »
 ;)  2.0 STI 01-05
1. Keep the car std but just remap for more oomph and better fuel economy.
A full custom remap will bring boost in much earlier and hold higher boost levels for longer but the map will be geared to running much more efficiently ( which is also more economically) as it wont be possible to push too much boost with both cats in place. Typically a Green/K&N/Cosworth air filter and a backbox are fitted at this stage.
With a simple remap on the standard car typically this would get the car to about 290bhp (blob eyes may make slightly more)
2. Sports cat in downpipe - remove centre cat
A full custom remap will bring boost in much earlier due to the lower back pressure and hold much higher boost levels. The remap will also aim to get it running much more efficiently ( which is also more economically).
Typically a Green/K&N/Cosworth air filter is fitted at this stage (on top of the sports cat downpipe and exhaust system). A walbro 255 fuel pump is essential.
It is also advisable to change to NGK PFR7B spark plugs.
This would get the car to about 320-340bhp but a huge boost in torque figures in the mid range.
3. Fully Decat Exhaust
The low back pressure from removing all the cats reveals the true characteristics of the boxer engine. A remap is needed to bring it under control and stop overboosting. The remap will bring boost in as smooth as possible and most likely get full (and higher ) boost at around 3300 rpm (depending on turbo surge point) and hold higher boost right through the rev range. The remap will also aim to get it running much more efficiently ( which is also more economically).
Typically a Green/K&N/Cosworth air filter and possibly a 3 port solenoid are fitted at this stage (on top of the decat downpipe and exhaust system).
This would get the car to about 330-350bhp but I have seen them up to 365bhp on the std turbo but a huge boost in torque figures in the mid range and transform the way the car drives on the road.
with all my blessing - amin ;)
« Reply #63 on: February 09, 2013, 14:40:18 PM »
2.0 WRX 01-05
In std form they are 220bhp give or take and have boost at about 0.9 bar. The boost profile in the std map is pretty tame and doesnt come in til 3500rpm assuming the car is std.
so... choices
A full custom remap will bring boost in much earlier and hold higher boost levels for longer but the map will be geared to running much more efficiently ( which is also more economically) as it wont be possible to push too much boost with all 3 cats in place. Typically a Green/K&N/Cosworth air filter and a backbox are fitted at this stage.
This would get the car to about 250-260bhp
Typically a Green/K&N/Cosworth air filter and probably a 3 port solenoid are fitted at this stage (on top of the sports cat downpipe and exhaust system).
This would get the car to about 270bhp but a huge boost in torque figures in the mid range.
The low back pressure from removing all the cats is now the equivalent of the turbo running around the garden naked shouting "look at me I'm free". A remap is needed to bring it under control and stop overboosting. The remap will bring boost in as smooth as possible and most likely get full boost at around 2700 rpm and hold higher boost right through the rev range. The remap will also aim to get it running much more efficiently ( which is also more economically).
Typically a Green/K&N/Cosworth air filter and probably a 3 port solenoid are fitted at this stage (on top of the decat downpipe and exhaust system).
This would get the car to about 280-290bhp but a huge boost in torque figures in the mid range and transform the way the car drives on the road.
aici fiind vorba de masini normale nu racing etc......
Ca sa fiu mai clar nu am nimic cu nimeni doar cand te apuci si pui linkuri pe aici si ce parere au uni si alti - treaba e fff clara cand NU ARE CUM SA SCOATA UN STI 350 BHP DOAR CU O ALTA PLACA IN ECU LA ASTA MA REFER .... mai sus este explicat destul de clar ... da stiu si eu un impreza in grecia 900cp facut de extreme tuning.gr dar nu a mers prea mult cu el -FIABILITATE...
Fotbalistu sau parintele  ;)
« Last Edit: February 09, 2013, 20:11:42 PM by impreza 01 »
« Reply #64 on: March 02, 2013, 19:24:48 PM »
Ma asteptam la o activitate mai dezvoltata cand e vorba de discutii de chiptuning.
Nu vreti sa-i ajutati cu informatii si pe cei mai noi in analele Subaru.
Daca intri pe un forum de afara la un astfel de subiect toata lumea fierbe spune ce si cum... nu cred ca sunt doar 2-3 care si-au resotatat Subaru in club.
« Reply #65 on: March 02, 2013, 21:50:03 PM »
Poate ca s mai multi...dar frecventa cu care crapa motoare e probabil la fel de mare.Parerea mea e ca mai binele e dusmanul binelui.Si daca nu esti pregatit sa bagi bani grei in masina ca sa ai un rezultat bun...doar un soft nu rezolva ceva.Hai sa rationam....de ce nu le ar face din fabrica mai sprintene...mai economice si/sau mai rezistente.....?
  • 4251
« Reply #66 on: March 02, 2013, 22:17:32 PM »
Domsnoopy poate sa confirme.... ;)
« Reply #67 on: March 02, 2013, 22:54:41 PM »
aici nu sunt de acord cu voi .... problema este la noi in tara nu la subaru in general ! nu sunt bine ingrijite motoarele si softuri ''smekere'' = boom sau dupa caz poc,poc,poc  ;D!
  • 1668
« Reply #68 on: March 02, 2013, 23:14:05 PM »
de acord  ;)
« Reply #69 on: March 03, 2013, 21:41:16 PM »
Salut Sebi, bine ai revenit :D se pare ca lumea s-a speriat si nu mai face resoftari.. asa ca rezumat!
« Reply #70 on: March 03, 2013, 22:49:59 PM »
De acum o sa fim toti sceptici cand mai apare cineva nou....
« Reply #71 on: March 04, 2013, 13:01:12 PM »
WOOOW VA AFECTEAZA RAU ! nu inteleg dece va stresati atat pt nimic ?
  • 1668
« Reply #72 on: March 04, 2013, 13:44:59 PM »
aha...era doar o banuiala... dar se pare ca am intuit bine... ;)
« Reply #73 on: March 04, 2013, 13:45:26 PM »
MAI E SI ZIUA LUI AZI !
  • 3912
« Reply #74 on: March 04, 2013, 22:26:19 PM »
Pai daca e ziua lui, trebuia sa-i dea Mihai un an, nu 6 luni...  :D :D
  • 1668
« Reply #75 on: March 04, 2013, 23:47:57 PM »
wow! cum suna... procuror trebuia sa te faci... ;D ;D ;D
  • 14261
Re: Resoftare - oare ???
« Reply #77 on: May 31, 2019, 15:24:16 PM »
Sunt in plin process de engine rebuild ( WRX EJ255). Intrebarea mea este: Merita s-o resoftez?  Scopul este ca masina sa devina mai reliable printr-un management mai eficient.   In motor voi bune doar piese OEM, practic ramane stock. Nu m-as supara sa am cativa caluti in plus, dar nu asta e obiectivul.
  • 4078
« Reply #78 on: May 31, 2019, 16:06:43 PM »
Eu iti recomand calduros sa NU pui doar piese OEM, minim prezoane de chiuloasa ARP - nu pune prostiile alea de bolturi OEM ca mai devreme sau mai tarziu vei avea probleme cu garniturile din nou (se subintelege ca in cel mai rau caz pui bolturi OEM noi - nu refolosi cele vechi - desi in reprez. vor vrea sa le puna pe alea vechi ... ) si as visa eu si pistoane ...
Faci rebuild pentru ca ? Stiu ca nu e la subiectul intrebarii dar sunt curios ce a patit motorul inainte ... garnituri de chiuloasa sau pistoane imprastiate sau cuzineti ?
« Reply #79 on: May 31, 2019, 16:32:01 PM »
garniturile de chiuloasa sunt duse si pistonul 4 spart. (cilindrii sunt perfecti, din fericire)  Si daca tot umblu pe acolo, pe langa pistoane mai schimb si cuzinetii si pompa de ulei.
