Subaru la dieta
Subaru la dieta
  • 14284
Subaru la dieta
« on: July 06, 2010, 14:35:57 PM »
Pentru cei care nu sunt interesati de confort si vor doar performante, mai jos este un tabel cu diferite elemente ce pot fi eliminate si greutatea lor. Nu va speriati de unitatea de masura. La finalul tabelului gasiti si modalitatea de conversie. Spor la dezmembrat!
Acesta nu este un subiect pentru Tom. El deja a scos tot ce se putea din masina  :D :D :D
http://www.subarufanclub.ro/forum/media/Weight.pdf
Răspuns: Subaru la dieta
« Reply #1 on: July 06, 2010, 19:05:10 PM »
pt ca ati fost cuminti
Engine bay
L radiator fan - 4.5 lbs
R radiator fan - 3.5 lbs
Windshield washer fluid reservoir - about 12 lbs full
L upper radiator bracket - 0.5 lbs
R upper radiator bracket - 0.5 lbs
L lower radiator bracket - 0.5 lbs
R lower radiator bracket - 0.5 lbs
Alternator tensioner bracket and bolt - 0.5 lbs
AC compressor, lines, condenser, belt, and dryer - 19.25 lbs
AC fluid - about 0.75 lbs
AC idler pulley - 1.0 lb (remove and use shorter belt if u want to keep AC)
AC compressor "outer half of pulley" - 1.0 lb (this can be removed with the belt in about 5 min. for track use only)
AC compressor lower bolts - 0.25 lbs (only 2 bolts needed to hold it in place)
AC refrigerant - 1.25 lbs (with the help of 02wrbrex1)
Deka ETX9 battery - 25.0 lbs (7.0 va. 32.0)
Battery terminal adapters + 0.25 lbs
Battery tie down bracket - 0.5 lbs
Battery plastic cover - 0.25 lbs
+ve battery terminal wiring - 0.75 lbs
-ve battery terminal wiring - 0.5 lbs
Custom 8ga battery cable (9ft long +ve, 1ft long -ve, both with ring terminals) + 0.75 lbs
Hood liner - 1.0 lb
TB hose and bracket (coolant bypass mod) - 0.5 lbs
PS line brackets - 0.25 lbs
Group N engine mounts w/ brackets - 0.5 lbs (3.5 vs. 3.75 x 2)
Perrin Equal Length Header - 13.75 lbs (12.0 vs. 25.75)
Perrin T-bolt clamps for slip joints +0.25 lbs
Wiring bracket on top of tranny bellhousing behind slave cylinder - 0.25 lbs
Clutch MC to SC piping, brackets, and hardware - 1.75 lbs (replaced with SS hose of negligible weight)
Carbing strut brace +3.5 lbs
Turbo heatshield -1.5 lbs
Turbo heatshield bracket -0.25 lbs
Boost Logic turbo blanket +1.0 lbs
Downpipe upper heatshield -0.5 lbs (between downpipe and uppipe and below the turbo)
Invidia uppipe - 2.5 lbs (3.5 vs 6.0)
RPS WRX custom aluminum flywheel, aluminum pressure plate, ceramic/carbon aluminum disc, release bearing, pilot bearing - 15.25 lbs
Q-rack +0.5 lbs (aluminum brackets added 0.5 lbs, deletion of driver side bracket with 2 bolts deleted 0.5 lbs, but extra length/thickness of part of the 06 RS tie rod adds 0.5 lbs)
Pelco fans for TMIC +3.0 lbs (1.5 x 2)
COBB crank pulley - 4.5 lbs (1.25 vs 5.75)
NRG dampers - 0.0 lbs (weighed exactly the same 1.25 lbs as parts they replaced)
DRL controller in engine bay - 0.5 lbs
COBB downpipe w/ O2 sensor - 11.5 lbs (11.75 vs. 23.25)
L Intercooler bracket w/ 3 bolts, rubber grommet, and metal insert - 0.75 lbs
R Intercooler bracket w/ 3 bolts, rubber grommet, and metal insert - 0.75 lbs
Process West TMIC w/ all hoses and clamps + 5.25 lbs
Driver side uppipe support bracket w/ 2 bolts and 1 less nut needed for uppipe - 1.0 lbs
Front of Car - Body
Front bumper cover unnecessary mounting brackets - about 2 lbs (only kept necessary ones)
Front bumper beam - about 24 lbs
KS-tech hood vent - 1.75 lbs (stock scoop is the same weight at 2.25 lbs, but the fins add 1.75 lbs so the net loss is 1.75 lbs)
Front of Car - Underneath
U-brace w/ plastic trim but no bolts - 25.0 lbs
Transmission rear cross member vibration dampener - 1.0 lb
Interior
L CG-lock + 0.25 lbs
R CG-lock + 0.25 lbs
R driver side floor mat holder - 0.25 lbs
Cruise control - 0.5 lbs
DRL controller under dash - 0.25 lbs
Middle rear seat belt - about 5 lbs (still have to weigh it)
Rear center pass through - 6.5 lbs
Blanket to cover rear pass through +0.75 lbs
Front grab handles - 1.0 lbs (0.5 x 2)
Rear grab handles - 1.0 lbs (0.5 x 2)
Front grab handle mounting brackets - 1.0 lbs (0.5 x 2)
Rear grab handle mounting brackets - 1.0 lbs (0.5 x 2)
L sunvisor - 0.5 lbs
R sunvisor - 0.5 lbs
Metal piece in center console - 1.0 lb
OMP Comfort L front seat (reclinable) - 12.0 lbs (29.0 + 6.0 (bracket) vs 47.0)
OMP Comfort R front seat (reclinable) - 7.0 lbs (29.0 + 6.0 (bracket) vs 42.0)
OMP Kubic steering wheel w/ NRG quick release - 1.75 lbs (2.25 + 1.0 + 1.5 vs 3.75 + 2.25 + 0.5)
Rear seat brace and support brackets - about 15 lbs
Metal shifter trim - 0.5 lbs
Foam sound deadener on firewall - about 25 lbs
Vents from HVAC to rear seats - 0.5 lbs
Child seat anchors (all 3) - 2.0 lbs
Door handle brackets replaced with velcro - 2.0 lbs (0.25 lbs ea)
Front door "saran wrap" sealant - 0.75 lbs (they were more than 0.25 lbs, but less than 0.5 lbs, so I weighed them together and got 0.75 lbs)
Rear door "saran wrap" sealant - 0.5 lbs (0.25 lbs each)
L rear speaker - 0.25 lbs
R rear speaker - 0.25 lbs
L front window aligner - 0.5 lbs (the window closes and seals fine, but NOT at highway speeds)
R front window aligner - 0.5 lbs (the window closes and seals fine, but NOT at highway speeds)
Rear door theft protection - 1.0 lb (0.5 lbs per side) - I have nothing in the car to steal, an immobilizer, hidden backup immobilizer, and an NRG quick release wheel - my car will have to be towed if somebody wants to steal it)
Autospeed dead pedal +0.25 lbs (0.25 vs negligible)
Homelink mirror +1.0 lb (1.5 vs 0.5)
Motomaster 6.5W solar panel +0.5 lbs
Cable for solar panel +0.25 lbs
COBB L front floor mat -0.5 lbs (1.5 vs 2.25)
COBB R front floor mat -0.75 lbs (1.75 vs 2.25)
L rear floor mat - 2.0 lbs
R rear floor mat - 2.0 lbs
Rear of Car -Underneath
Driveshaft protection plate - 4.0 lbs
Muffler heat shield - 1.0 lb
ACPT CF driveshaft - 10.0 lbs (14.5 vs 24.5)
COBB cat back - 2.0 lbs (19.0 vs 21.0)
COBB midpipe - 2.0 lbs (9.0 vs 11.0)
Rear tow hook - 2.0 lbs
L rear muffler hanger bracket - about 2 lbs
L rear muffler hanger - 0.5 lbs
Rear of Car - Body
Rear bumper cover unnecessary mounting brackets - 4 lbs (only kept necessary ones)
Rear bumper beam - 28.5 lbs
Rear bumper beam foam - 1.25 lbs
Rear bumper beam bolts - 1.0 lbs
Rear license plate screw holder - 0.25 lbs
Spec C trunk - 11.75 lbs (11.0 + 0.75 (paint) + 0.5 (hardware) vs 24.0)
APR wing - 8.75 lbs (8.25 vs 17.0)
APR rear diffuser w/ hardware +4.5 lbs
Trunk Area
Run low intercooler sprayer fluid - about 8 lbs (used to cool IC + spray the windshield)
Spare tire - 30.25 lbs
Spare tire bolt and cap - 0.25 lbs
Spare tire cover - 4.0 lbs
Jack extension handle located under spare tire cover - 0.75 lbs
Jack - 4.0 lbs
Tools w/ carry case - 1.5 lbs
All trunk trim - about 4 lbs
Spare tire rubber pads - 0.25 lbs
Trunk springs - 2.0 lbs
Neodynium magnets to replace trunk springs +0.25 lbs
Wheels, Suspension, and Brakes
Front brake dust sheilds - 2.0 lbs (1.0 lbs per side)
Rear brake dust shields - 1.5 lbs (0.75 lbs per side)
Rear caliper vibration dampener - 2.0 lbs (1.0 lbs per side)
Front ABS sensor wire brackets w/ bolts - 0.5 lbs (0.25 lbs per side)
Rear ABS sensor wire brackets w/ bolts - 0.75 lbs (both sides)
Rear passenger brake line bracket w/ bolts -0.25 lbs
Brakeman L front rotors - 10 lbs (12.75 vs 22.75)
Brakeman R front rotor - 10 lbs (12.75 vs 22.75)
Brakeman L front caliper assembly - 3.0 lbs (9.25 - 12.25)
Brakeman R front caliper assembly - 3.0 lbs (9.25 - 12.25)
Brakeman L rear caliper assembly - 0.25 lbs (3.25 - 3.5)
Brakeman R rear caliper assembly - 0.25 lbs (3.25 - 3.5)
Brakeman L rear rotor - 10.75 lbs (7.0 vs 17.75)
Brakeman R rear rotor - 10.75 lbs (7.0 vs 17.75)
Car Labs X-brace +10.75 lbs
COBB front swaybar ASSEMBLY - 2.0bs (5.0 vs. 7.0)
COBB front endlinks - 0.0 lbs (same as stock)
COBB rear swaybar ASSEMBLY - 0.5 lbs (9.75 vs 10.25)
COBB rear endlinks +0.25 lbs (1.25 vs 1.0)
Kosei 17x9 ET 45mm w/ Bridgestone RE-01R 245/40/17 tires - 8.0 lbs (43.0 vs 45.0 x 4)
Kosei 17x9 ET 45mm w/ Michelin Pilot Sport Cup 245/40/17 tires - 28.0 lbs (38.0 vs 45.0 x 4)
Project KICS Neo Chro R26 lug nuts - 0.25 lbs (1.0 vs 1.25)
Rear backing plates - 11.5 lbs (5.75 lbs per side)
Rear drum brake components - 5.0 lbs (2.5 lbs per side)
Ebrake handle assembly - 3.5 lbs
Ebrake cables - 2.5 lbs (1.25 per side)
Ebrake cable bracket - 0.25 lbs
Misc
Gas tank filler trim - 0.25 lbs
Run a maximum of 35 L gas at a time (fill 30L when there is about 5L left) - about 40 lbs
Various brackets, bolts, nuts, etc. from all over the car replaced with nothing, zip ties, or double sided tape - about 50 lbs
  • 14284
Rspuns: Subaru la dieta
« Reply #2 on: July 06, 2010, 19:33:50 PM »
Multumim pentru lista completa! Daca ati scos tot ce scrie mai sus, ar trebui sa ramaneti cu o un volan si 4 roti :D Glumesc!
  • 4763
« Reply #3 on: July 06, 2010, 22:48:06 PM »
dump the bich off (pitziponcus)  :D scapi de 50 kg usor :D ;D  Invetii copii la prostii MR. STI .... ::)
George
  • 757
« Reply #4 on: July 07, 2010, 12:33:33 PM »
a incercat careva un total ?  ;D
George
  • 757
« Reply #5 on: July 07, 2010, 12:48:59 PM »
am facut eu ... baietul asta a dat jos de pe masina 264kg .
  • 14284
« Reply #6 on: July 07, 2010, 12:52:20 PM »
avion!
George
  • 757
« Reply #7 on: July 07, 2010, 13:02:34 PM »
eh ... un pic asa  :D
OFF: am gasit masina de oras , CC , hardtop adica, 800kg :, 87cp  ;D oare pot pune un turbo pe ea (cu conditia sa incap in ea si capotat  ;D)
« Reply #8 on: July 07, 2010, 13:13:00 PM »
Ai grija la flapsuri  ;D ;D
« Reply #9 on: July 07, 2010, 13:35:15 PM »
asta este mai mult un guideline pentru cine doreste sa faca astfel de operatiuni postat de un baiat pe numele lui AnorexicSTI pe un forum mai mare din afara
George
  • 757
« Reply #10 on: July 07, 2010, 13:37:00 PM »
asta e de top :
"Various brackets, bolts, nuts, etc. from all over the car replaced with nothing, zip ties, or double sided tape - about 50 lbs"
l-as invita cu masina pe drumurile din romania :D sa vada cum se desface bucati.
« Reply #11 on: July 07, 2010, 13:45:57 PM »
bah si eu am facut asta si daca desfaci o impreza o sa observi ca chiar poti face asta in unele locuri :) fara sa te saboteze drumurile noastre
George
  • 757
« Reply #12 on: July 07, 2010, 13:47:33 PM »
tu ai avut mai mult timp masina pe mana ... trebuie sa discutam in detaliu cand ne vedem ;)
« Reply #13 on: July 07, 2010, 13:50:56 PM »
vorbim vineri ;)
alecsm
« Reply #14 on: August 24, 2010, 13:20:53 PM »
bun topicul ...o sa am de lucru la urmatoare cursa :)))
