Forester XT '03 +motor STI
« on: September 07, 2018, 10:58:47 AM »
Salutare. M-am intors. Pai ce credeati ca mai las mult treburile asa? Gata cu amintiri din copilarie style lsi povesti interminabile despre cum sa te urci in masina ca s
Asadar , imi prezin aici masina. E un Forester din 2003 XT , care a primit un motor de STI cu care inca ma cert. Momentan merge bine , dar consuma cat o vaca gestanta. De asta o sa ne ocupam pe parcurs cu fratii Malakay , 2xGhe si Ady Burneru.
« Last Edit: January 24, 2020, 00:08:19 AM by Celalalt »
  • 1740
« Reply #1 on: September 07, 2018, 11:01:01 AM »
Heli, tu esti :o?
« Reply #2 on: September 07, 2018, 11:02:02 AM »
Serban, tu sa fii???  :D
Bine ai revenit si demacheaza-te ca sa te recunoastem!  8)
« Reply #3 on: September 07, 2018, 11:04:01 AM »
Return of the Jedi !
  • 14281
« Reply #4 on: September 07, 2018, 11:30:48 AM »
Bine ai revenit Zoro! Si spor la treaba!
  • 4763
« Reply #5 on: September 07, 2018, 11:42:03 AM »
Pff nici aici nu scap de tine 😂😂😂😂!  Bine ai revenit !
« Reply #6 on: September 07, 2018, 11:43:27 AM »
Uite asa se resusciteaza forumul, bine ai revenit baeatu’! Sa o stapaneati  sanatos, da ne detalii, parca s a intamplat prea repede totul😎 🤪😁😁
« Reply #7 on: September 07, 2018, 11:51:55 AM »
Pai ce sa zic? Stii si tu. Noi am muncit si tu ai stat degeaba. Si tot a pornit.
  • 4081
« Reply #8 on: September 07, 2018, 12:11:32 PM »
o fi avand ceva gaura in chiuloasa si fasaie benzina...
cristibna
  • 734
  • FUN
« Reply #9 on: September 07, 2018, 14:31:49 PM »
Man, ce patisi ? Bine ai revenit ;)
cutia de viteze o ai de rezerva sau deja ai schimbat-o? :)
Si cum zicea cineva, fara poze nu exista :)
Ti-e ciuda cu plimbarile ca nu ai timp :D
2018 Subaru XV 2.0
2016 Honda NC750x DCT
ex 2004 Subaru Forester 2.0X
« Reply #10 on: September 07, 2018, 14:34:08 PM »
Oh great......there goes the neighbourhood again..... ;D :laugh:
uelcom bac bub! ;)
« Reply #11 on: September 07, 2018, 21:56:08 PM »
Exista o posibilitate ca motivul consumului exagerat sa fie compresorul AC. Merg de 2 zile fara si acul de la benzina sta aparent nemiscat. Chiar si dupa 70 km de la plin. Cu AC la 50km eram deja la jumatatea primului cadran.
A reparat cineva compresorul? Stiti cam cat ar putea sa coste ?
  • 14281
« Reply #12 on: September 08, 2018, 09:04:26 AM »
Parca in jur de 300 euro cu piese de pe ebay.
« Reply #13 on: September 08, 2018, 16:13:27 PM »
E clar ca de acolo e. De la 19% a cazut in 13 dar fara Ac. O sa ma interesez. Parca nu as vrea sa o arunc in Dâmbovița.
Mai las aici o intrebare. Am urmatoarea problema : in special in treapta a3 a se intampla. Accelerez pana la 7000rpm si cand vreau sa dau a 4 a constat ca nu mai am pedala de ambreiaj. Zici ca o intrec si ramane in urma a dracu. Daca scad turatia isi revine si se incordeaza iar. Nu am gasit pana acum vreo explicatie logica...
  • 14281
« Reply #14 on: September 08, 2018, 18:57:39 PM »
Pompa si cilindru receptor. Se reconditioneaza cu piston, arc si burduf. A patit la fel si Alin de la TM (leone).
« Reply #15 on: September 08, 2018, 19:21:28 PM »
Randurile lui Mihai sunt citite de userii care au probleme dar cel mai mult de mecanicii fara scoala si experienta.
Multi devin "specialisti" in marca dupa ce lectureaza postarile de aici. :)
« Reply #16 on: September 08, 2018, 19:54:21 PM »
Eșplică să inteleagă si iapa...
« Reply #17 on: September 08, 2018, 23:13:51 PM »
Nu are legatura cu Foresterul tau, este doar o constatare. Sunt mecanici care urmaresc postarile lui Mihai pentru a invata sa lucreze.
Cand le iese bine nu spun nimic iar cand gresesc dau vina pe forum.
« Reply #18 on: September 08, 2018, 23:55:00 PM »
Mai da-i in calea gurii lu Dragnea pe aia care urmaresc fix ce zice Mihai ca sa invete ei meserie. Hai cu parerile. Ca suspansul asta m-a indepartat de platforma asta. Ori suntem ori nu mai suntem.
La treaba cu cilindru si/sau pompa imi e greu sa gasesc o logica. M-as duce catre placa de presiune. O sa caut sa studiez arhitectura functionarii ambreiajului in situatia de fata si probabil ca o sa pricep. Sau nu. Dar pana atunci , putin brain storming nu strica. Asa ca , hai sa lasam panica man. M-as mira sa fie spioni printre noi. Sau sunt pretutindeni. In curand scriem o manea. Se stieeeee....
« Reply #19 on: September 09, 2018, 11:20:02 AM »
Pun asta aici ca sa am de documentat luni cand ajung la munca. Din ce am inteles e vorba de un arc. O sa recitesc de pe desk la munca. Pe telefonu scrisul nu e intotdeauna suficient de mare.
https://forums.nasioc.com/forums/showthread.php?t=2088183
Tot in afara se gasesc raspunsuri. Acolo nu au spioni poate. Secrete de stat si amintiri din copilarie. "Căci" asa este la ei...
« Last Edit: September 09, 2018, 11:21:58 AM by make the forum greatagain »
