Racing Budy Condenser
« on: January 11, 2011, 10:54:25 AM »
Servus,
Ma bate gandul la asa ceva:
Buddy Club BC04-RSCON Racing Spec Ground System Condenser
http://www.procivic.com/pages-product_car_part_info/category-70_91/product-469/engine-electronics-buddy-club-racing-spec-condenser-grounding-system.html?utm_source=googleproductsearch&utm_medium=organic&utm_campaign=product
Ceva pareri pro/contra?
Masina pe care ar urma sa ajunga este un Impreza 2.0 Diesel, 2010.
Ar fi eventual probleme cu garantia?
Merci fain.
What I am doing?
  • 14294
Rspuns: Racing Budy Condenser
« Reply #1 on: January 11, 2011, 11:02:22 AM »
Eu cred ca o sa imi pun asa ceva pe masina: http://www.hksusa.com/products/?id=1506
Asa ca sunt si eu interesat de pareri despre grounding kits.
Răspuns: Rspuns: Racing Budy Condenser
« Reply #2 on: January 25, 2011, 10:59:41 AM »
@Mihai, am citit specificatiile si sincer nu prea inteleg unde-i castigul de a-ti monta asa ceva. Poate cei care il au destainuie mai multe aspecte necunoscute sau simtite dupa instalare.
Macar sa stim pe ce eventual dam banii.
What I am doing?
« Reply #3 on: January 26, 2011, 21:23:10 PM »
Grounding kitul ofera mai multe puncte de masa luate direct de pe baterie catre galeria de admisie
, bloc motor, alternator, caroserie si inca cateva puncte
Răspuns: Racing Budy Condenser
« Reply #4 on: January 26, 2011, 21:32:19 PM »
ceata...deci?inca odata?la ce foloseste?
« Reply #5 on: January 27, 2011, 00:28:11 AM »
Circular Grounding System - By utilizing a 24 karat gold plated distribution block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points.
De la HKS direct poate ajuta
« Reply #6 on: January 27, 2011, 08:11:36 AM »
aha.ok.m-am lamurit.
« Reply #7 on: March 01, 2011, 11:17:49 AM »
Am pus eu kitul de impamantare de la HKS.
Ce am observat:
*motorul e mai stabil la relanti
*muzica se aude mai bine
*parca se ridica geamurile mai repede  :)
*parca porneste mai repede masina chit ca am bujii mai reci
Nu e o diferenta asa mare, dar imbunatateste sistemul de impamantare al masinii care dupa 3 ani cred ca e obosit si oricum continea niste fire de 3 4 ori mai subtiri.
Am legat la:
*alternator
*caroserie 2 fire
*electromotor
*cutie de viteze
« Reply #8 on: January 29, 2013, 09:38:57 AM »
Ce am observat:
Am legat la:
*alternator
*caroserie 2 fire
*electromotor
*cutie de viteze
Stiu ca e cam vechi topicul dar ai putea sa imi arati o schema(sau si mai bine niste poze)?As vrea sa imi montez si eu asa ceva si habar n-am cum!
« Reply #9 on: January 30, 2013, 06:54:22 AM »
Servus,
Merci fain.
Piesa ta este un condesator de fapt un montaj care are rolul de a mentine cat mai constanta tensiunea de alimentare, existand in fnctionare varfuri de consum pe care bateria le duce cu greu. Inmomentul in care tensiunea scade mai mult pentru o perioada scurta de timp condesatorul se descarca si suplineste sarcina.
In mod normal nu are de ce sa fie o problema la garantie.
Grounding kits - este altceva si de fapt este un sistem de calbluri de masa electrice cae urmareste crearea unui punct Kelvin electric.
Se folosesc in special la modelel pe benzina unde masa este extrem de importanta la aprindere. Se stie ca la bujii masa este chiulasa si celalalt electrod se alimenteaza de la bobina.
Astfel pentru a creea o masa perfecta se aduc cabluri de masa care se leaga la diverse piese metalice, sasi apoi se unesc si se leaga la minusul de la baterie.
Acest sistem poate fi confectionat insa trebuie mare atentie la contacte, acestea trebuiesc facute perfect pe suprafete mari si cu materiale care nu oxideaza. HKS foloseste aur acesta diind si un f bun conductor electric. Recomandarea este ca acolo unde legati fiecare cablu sa curatati bine ininte pt a face contact excelent.
