Onboard cameras
Onboard cameras
Răspuns: Onboard cameras
« Reply #40 on: March 01, 2013, 20:52:33 PM »
aha mersi ! eu credeam ca e wrx ceva dupa ceasuri si mergeam cam tare pt un wrx :D
p.s masina mea nu cred ca rezista la 15 min de asa ceva (si fara sa fiu rau 80 % din subaru din romania nu cred ca rezista )
off topic : ma bag la s19e05 top gear !
De ce n-ar rezista??...WRX-ul meu a vazut numai forja si pe circuit si urcari si tot tacamul si merge ceas ;D....sunt facute pentru asa ceva, nu pentru plimbari prin centru ca sa moara fetili  ;D ;D
Retrag afirmatia de mai sus......
Ex. 03 WRX
99 STI Coupe Race Car
08 Impreza STI
« Reply #41 on: March 01, 2013, 21:02:00 PM »
A crapat si la tine?
  • 4763
« Reply #42 on: March 01, 2013, 21:06:49 PM »
 ;D malakay stie ce vb  ;D
« Reply #43 on: March 01, 2013, 23:45:32 PM »
gata man a vomitat transmisia?
ce cotet astronomic...
« Last Edit: March 02, 2013, 00:41:55 AM by STI »
  • 4763
« Reply #44 on: March 02, 2013, 14:13:07 PM »
suspecta motorul ca a bubuit ! dar a avut noroc si se pare ca a bubuit doar intercoolerul de wrx !
e timpul de upgrade!
« Reply #45 on: March 02, 2013, 21:51:16 PM »
Adica noroc chior....
  • 1668
« Reply #46 on: March 03, 2013, 01:00:06 AM »
ce tot suspina asa cand schimba vitezele? ca nu prea suna a BOV...
« Reply #47 on: March 03, 2013, 01:09:29 AM »
Turbina ;D
Ex. 03 WRX
08 Impreza STI
  • 1668
« Reply #48 on: March 03, 2013, 01:27:16 AM »
wow! serios?! cum ? de ce face asa? e supapa de overboost? la mine de ce nu face asa?
thanx Adi  :)
  • 14284
« Reply #49 on: March 03, 2013, 01:40:06 AM »
Secunda 27. E de la wastegate. Imi place mai mult decat sunetul de BOV
  • 1668
« Reply #50 on: March 03, 2013, 02:08:20 AM »
exact de sunetu' ala ziceam... imi place mult... putem face si la ale noastre?
« Reply #51 on: March 03, 2013, 03:17:09 AM »
O explicatie ceva mai tehnica:
The noise is in fact the air compressed by the turbo passing back through the compressor wheel of the turbo after the airflow is abruptly halted by the throttle plate closing, called compressor surge. However, in some cases, i.e. where the throttle plate doesn't open fast enough or is set up to only react to high boost, some chatter will remain. Surge can occur on diesels when the turbo is attempting to pressurize the air at a higher pressure ratio than the compressor wheel can flow at a given speed. Most Diesel engines have no use for a blow off valve as they do not have a throttle plate.
The chatter noise is very noticeable on World Rally Cars, where anti-lag is used.
It is commonly heard more clearly and may be more prominent on cars with modified intake silencers, up-pipes, downpipes, or an oversized wastegate incorrectly matched to that specific engine. Also, vehicles using on/off solenoids to control boost can do this under certain conditions. It is not harmful to the engine.
« Reply #52 on: March 29, 2013, 00:44:08 AM »
  • 4763
« Reply #53 on: March 29, 2013, 12:02:45 PM »
concrion
« Reply #54 on: March 29, 2013, 16:23:23 PM »
si
P.S. Baieti ziceti-ne si noua care e treaba cu wastegate-ul extern si cum ar ajuta pe strada (eu am citit aici http://forums.nasioc.com/forums/showthread.php?t=59271 si vad ca sunt pareri impartite despre beneficiile lui).
« Last Edit: March 29, 2013, 20:06:05 PM by concrion »
« Reply #55 on: March 29, 2013, 17:14:21 PM »
Ideea topicului este fiecare user care contribuie are voie la un post / zi, cerinte : numai motorsport onboard circuit/rally/wrc/rally sprint/macadam/hill climb, fara ot, keep it interesting, si ca sa incepem cu dreptul pentru azi:
mihai fa si tu un topic separat sau muta discutia ca sa nu sterg tot sa se poata continua discutia o/t
« Last Edit: March 29, 2013, 17:18:18 PM by STI »
RACING CODE
  • 67
  • SUBARU EXPERT - chiptuning & dyno
    • www.racingcode.ro
« Reply #56 on: March 29, 2013, 18:29:48 PM »
Cu mai bine de 10 ani in urma, o masina cu ceva mai multa putere decat s-a declarat  si destul de solicitanta la condus.
Reliable + Cheap = Not Fast
Cheap + Fast  = Not Reliable
Fast + Reliable = Not Cheap
RACING CODE
  • 67
    • www.racingcode.ro
« Reply #57 on: March 29, 2013, 18:42:24 PM »
« Last Edit: March 29, 2013, 18:44:59 PM by RACING CODE »
« Reply #58 on: April 04, 2013, 00:51:42 AM »
[ Invalid YouTube link ]
« Reply #59 on: April 04, 2013, 18:53:21 PM »
