wrx sti '08
wrx sti '08
Răspuns: wrx sti '08
« Reply #480 on: January 08, 2015, 16:41:56 PM »
Din ciclul "ce-i mai bun pentru masina mea" combinat cu "cea mai proasta baterie e la mine pe masina", are cineva baterie cu gel?
LE. Am dat comandat de  VARTA Start Stop Plus 60Ah AGM model D52 . Daca si asta crapa...
« Last Edit: January 10, 2015, 15:50:07 PM by kinderjoy »
« Reply #481 on: January 15, 2015, 11:42:47 AM »
O intrebare de neubie ... 75W140 merge pus acolo unde scrie "power steering oil" ?
« Reply #482 on: January 15, 2015, 11:51:14 AM »
Motul zice doar de astea:
Capacity    :    Capacity 0,7 litre
Use    :    Alternative (acceptable)
Products    :    MULTI ATF (year-round)
             :    DEXRON III (year-round)
             :    ATF 1A (year-round)
  • 3912
« Reply #483 on: January 15, 2015, 14:24:55 PM »
In niciun caz!
« Reply #484 on: January 15, 2015, 14:25:59 PM »
De fapt, merge, da doar cativa km, probabil ;D
  • 3912
« Reply #485 on: January 16, 2015, 14:12:19 PM »
Faptul ca ti-a distrus bateria intr-un timp atat de scurt, nu e normal. Eu zic sa o iei la verificat pe parte electrica...
« Reply #486 on: January 16, 2015, 18:22:19 PM »
Daca se duce naibi si D52 (ergo incepe sa aiba aceleasi simptome ca cealalta) atunci da. Pana atunci consider doar ca am ales o baterie nepotrivita pentru masina.
« Reply #487 on: January 25, 2015, 09:13:42 AM »
Poti sa pui si untdelemn de la bunica acolo unde scrie power steering. ;)
« Reply #488 on: January 26, 2015, 10:05:52 AM »
Am completat cu DEXRON III.
Vreo 100ml era sub minim.
Probabil ca trebuie s-o duc curand la schimbul de lichide de 2 ani.
« Reply #489 on: January 26, 2015, 10:25:38 AM »
Sa si verifice instalatia, 100ml nu e chiar putin cand totalul instalatiei e 0.7 si de obicei nu se completeaza
  • 14234
« Reply #490 on: January 26, 2015, 10:48:11 AM »
Mda. Inceputul unui sfarsit de caseta.
Eu cand am fost la constatare de caseta stricata si au intrebat daca am mai umblat la instalatie (in 3 ani eu nu, dar nu stiu inainte)... au deschis capacul si au testat lichidul cu degetul si face meseriasul "E ulei d-ala bun boss". Semn ca e de fabrica si ca nu s-a atins nimeni de el din 2001 pana astazi. Si nivelul e unde trebuie. Mi-au recomandat sa verific franele mai bine decat sa dea ei jos caseta.
Deci sa pierzi 100 ml nu e normal. Nu e ca la motor.
« Reply #491 on: January 28, 2015, 18:48:56 PM »
Am facut curat :)
Din saga amurg, bestia albastra, ieri vad martorul de ulei ca clipeste o data. Verific dimineata uleiul, pauza. Nici macar nu aveam ulei pe joja.
Am pus repede ulei de completare de la primul petrom ... Dupa 1L, tot nu aveam ulei pe joja. Am luat rezerva strategica (ergo, bidonul de 5L) si tup la service la colt.
Cablurile de la radiatorul suplimentar pline de ulei... care picura in voie.
Oh well...
It will be fun. Bine ca nu am facut mai mult de 10 km de cand cu martorul...
  • 3912
« Reply #492 on: January 28, 2015, 18:52:03 PM »
Eu zic sa te pregatesti psihic de ceva de genul facut de mine la masina.  ;) Sper sa nu ai nevoie de asa ceva, dar martorul ala se aprinde cand deja motorul e cam gol... Sa speram ca treaba nu e nasoala.
« Reply #493 on: January 28, 2015, 19:16:49 PM »
La 15k+ eur... iau alta :)) O tin pe asta de piese...
  • 4077
« Reply #494 on: January 28, 2015, 20:15:55 PM »
eu zic ca este o performanta :) daca ai vazut becul de ulei aprins si motorul inca merge ... e ceva :)
« Reply #495 on: January 28, 2015, 20:52:45 PM »
+1
oricum daca nu a cedat inca... la prima gusa bruta sigur vomita cuzinetii :D
« Reply #496 on: January 28, 2015, 21:06:12 PM »
Ce oameni ma.Parca ati fii aia de ii propun soft pentru un sound mai bun la radio Zu...
  • 4077
« Reply #497 on: January 28, 2015, 21:09:38 PM »
nu :) , doar sustinem un coleg , ii aratam ca ii suntem alaturi :)
  • 4077
« Reply #498 on: January 31, 2015, 21:03:21 PM »
ai mai "facut" ceva ? :) totul ok ?
« Reply #499 on: February 01, 2015, 01:04:35 AM »
Am dat o tura la munte :)
Totul ok. Nu sunt zgomote ciudate sau alte manifestari.
O asteapta o verificare de rutina in curand si o schimbare de lichide.
Am polita retractabila din spate un pic rupta pe cusatura intr-o margine (vreo cativa cm). Am cerut oferta de una noua. 1200 ron.
Cred ca cumpar superglue de banii astia...
