Salutare tuturor,
Stiu ca trebuia sa imi fac resume-ul de la inceput, sorry about that. Better late than never... here we go:
STI 2008 hatchback, platit avans la el in mai 2008 si primit masina in septembrie 2008. Cele mai lungi 6 luni din viata mea !
In ordinea aproximativa a aparitiei:
Brakes:
HOSE TECHNIK - Brake Lines
Motul - RBF600 Brake Fluid
DBA - Brake disks 4000 T3 front & back
Ferodo - Brake pads DS 2500 front & back
Handling:
Whiteline - Front Sway bar - 24mm X heavy duty blade adjustable (BSF39XZ)
Whiteline - Control arm - lower inner rear bushing (anti-lift/caster correction) (KCA334)
Whiteline - Trailing arm - lower front bushing (W0568)
Whiteline - Steering - rack & pinion mount bushing (KSR207)
Whiteline - Gearbox - positive shift kit bushing (KDT901)
Whiteline - Crossmember - mount bushing (KDT907)
Whiteline - Diff - support outrigger bushing (KDT905)
Whiteline - Diff - mount in cradle bushing (KDT906)
Whiteline - Rear Sway bar - 22mm X heavy duty blade adjustable (BSR49XZ)
Whiteline - Control arm - upper inner bushing (camber correction) (KCA326)
STi - Group N Engine/Gearbox Mount Kit
Kartboy - 6-Speed Shifter Bushing Combo
COBB - Double Adjustable Short Shifter
Look:
LLumar - Folii rosii stopuri
Heko - Paravanturi geamuri
Perrin - Wing Riser Kit
OZ Racing - Alleggerita Black 18x8.5 ET 55
GrillCraft - Hood Scoop Grill Black
GrillCraft - Front Lower Grill Black
PlastiDip all over (still a work in progress)
Power upgrade:
Invidia - Down-Pipe 76mm catless
Samco - Silicone Turbo Hose Kit
DEI - Titanium Exhaust / Header Wrap
PTP - Turbo Blankets Turbo Blanket Lava
Cosworth - High Flow Synthetic Air Filter
Crawford - TMIC Air Oil Separator
Custom tuning RacingCode: 280whp, 423wNm
Audio:
Focal - Multumesc mult Relu
Other:
Defi - Red Racer Boost 52mm
Defi - Red Racer Oil Pressure  52mm
Defi - Red Racer Oil Temperature 52mm
Defi - Red Racer EGT 52mm
ATI - Single Gauge Pod
SMY - ClusterMaker Dual Gauge Pod
Fun:
Tinywrex patch LC + FFS (my favorite mod)
On hold:
Whiteline - Control arm - lower inner front bushing (W0508)
AEM - UEGO Digital Wideband Air / Fuel Gauge
That's my girl:
Acum asteapta dupa mine sa termin procesul de documentare si va urma un engine related upgrade: camasi, pistoane, biele, prezoane, radiator ulei............
