Outback 2011 2.5i CVT - Subi
VeNoM836
  • 274
    • Hranitor Animale
Re: Outback 2011 2.5i CVT - Subi
« Reply #120 on: March 07, 2021, 19:03:21 PM »
La CVT folosesc Amsoil, la motor m-am intors la Motul, la diferentiale tot Motul.
Vineri am luat de la pol 7 cutii cvt amsoil. Saptamana asta il schimb.
2011 Subaru Outback 2.5i CVT
VeNoM836
  • 274
    • Hranitor Animale
« Reply #121 on: March 19, 2021, 09:17:50 AM »
Asta este toba de esapament de la pilot pitesti.
VeNoM836
  • 274
    • Hranitor Animale
« Reply #122 on: March 19, 2021, 09:19:34 AM »
Drain & Fill CVT // 11/03/2021 // 253650 KM
Amsoil CVT x 7 cutii (intra 6 si jumatate)
VeNoM836
  • 274
    • Hranitor Animale
« Reply #123 on: June 08, 2021, 17:57:02 PM »
Revizie 260.800 KM // 01/06/2021
- Motul 8100 X-Clean EFE 5w30
- Filtru ulei OEM, Filtru aer MANN, Filtru polen MANN FP
Saptamana viitoare placute frana fata/spate.
« Last Edit: June 08, 2021, 17:58:06 PM by VeNoM836 »
VeNoM836
  • 274
    • Hranitor Animale
« Reply #124 on: October 19, 2021, 11:08:41 AM »
Schimb ulei diffs ~265.000 // 12/08/2021
- Motul Gear 300 75W-90
VeNoM836
  • 274
    • Hranitor Animale
« Reply #125 on: November 11, 2021, 11:19:34 AM »
Revizie 271.800 KM // 10/11/2021
- Motul 8100 X-Clean+ 5w30
Am schimbat si radiatorul (Denso), termostat/garnitura originale, antigel G11 HEPU.
« Last Edit: November 11, 2021, 11:21:23 AM by VeNoM836 »
  • 1389
« Reply #126 on: November 11, 2021, 13:53:30 PM »
La mai mulți !
VeNoM836
  • 274
    • Hranitor Animale
« Reply #127 on: June 20, 2022, 10:34:52 AM »
revizie 282.000 KM - 05/10/2022
- drain fill CVT Amsoil
- inlocuire head gaskets comandate in Polonia
 se pare ca prin iarna 2021 mi-a crapat radiatorul. pana in primavara s-a golit, nu am avut nici un simtom, ca era frig. cum s-a incalzit, fiind in trafic in Bucuresti s-a supraincalzit. a fost suficient.
« Last Edit: June 20, 2022, 10:36:06 AM by VeNoM836 »
« Reply #128 on: June 20, 2022, 10:44:38 AM »
Cat a fost distractia de inlocuit garnituri? Ce garnituri ai montat, OEM MLS sau altceva?
VeNoM836
  • 274
    • Hranitor Animale
« Reply #129 on: June 20, 2022, 11:31:35 AM »
OEM, undeva la 4500 lei cu totul
  • 4081
« Reply #130 on: June 20, 2022, 11:41:27 AM »
OEM MLS sau chiar si aftermarket MLS sunt super ok cat timp se verifica/rezolva planeitatea chiuloaselor si a blocului ...
« Reply #131 on: June 20, 2022, 12:00:38 PM »
Deci daca nu aveai duda cu radiatorul, probabil te mai tinea. Vad ca aveai aproape 300.000, nu-i rau pentru "vestitul" 2.5 aspirat. Bine, e adevarat ca nu stiu daca tu ai EJ sau FA/FB sau alte instagrame   ;D
La cat mai multi km fara probleme!
VeNoM836
  • 274
    • Hranitor Animale
« Reply #132 on: June 20, 2022, 12:27:27 PM »
Sa citez mecanicul, se strica doar daca ai o problema si se supraincalzeste.
Garantat daca nu aveam o problema ajungeam la cel putin 400.000.
  • 4081
« Reply #133 on: June 20, 2022, 12:31:55 PM »
nu ca sa contrazic mecanicul tau dar din experienta de obicei se imprastie garniturile prima data, creste presiunea in sistem si cedeaza furtune/radiatoare & shit  nu invers dar ... important e ca este ok acum :)
VeNoM836
  • 274
    • Hranitor Animale
« Reply #134 on: January 17, 2023, 11:57:02 AM »
Distributie / Revizie
- revizie 297.200 KM - 09/01/2023
-- Motul 8100 X-Clean EFE 5w30
-- Filtru ulei OEM, Filtru aer MANN, Filtru polen MANN FP
- distributie 297.200 KM - 09/01/2023
-- Pompa apa HEPU P7576
-- Curea transmisie cu caneluri GATES 4PK806SF
-- Set curea de distributie INA 530 0426 10
-- Curea transmisie cu caneluri GATES 5PK683
-- Bujie DENSO IK20TT
-- Termostat Mahle
- inlocuire discuri fata si placute fata/spate 297.200 KM - 09/01/2023
-- Disc frana HERTH BUSS JAKOPARTS J3307015
-- Set placute frana, frana disc FERODO FDB1947
-- Set placute frana, frana disc FERODO FDB1639
« Last Edit: January 17, 2023, 15:43:48 PM by VeNoM836 »
VeNoM836
  • 274
    • Hranitor Animale
« Reply #135 on: January 17, 2023, 11:58:52 AM »
Cred ca o sa rezolv si cu farurile. I-am gasit pe baietii astia care inlocuiesc toata partea de oglinda/lupa cu oglinda metalica / lupa si LED.
Mai jos un exemplu facut de ei tot pe un Outback.
&feature=youtu.be
  • 14275
« Reply #136 on: January 17, 2023, 13:53:29 PM »
Sa stai cu ochii pe temperatura apei. Este recomandat DOAR termostat Subaru original. Sunt nenumarate articole si filmulete plus postari aici pe forum pe tema asta unde se arata ca termostatele aftermarket sunt net inferioare si la o comparatie ochiometrica se vede clar ca cel original este mult mai robust.
Multi km fara probleme in continuare!
  • 5457
« Reply #137 on: January 17, 2023, 14:46:16 PM »
N-as pune termostat altfel decat OEM la nicio marca, pe motiv de CTC + riscuri asociate daca se blocheaza.
VeNoM836
  • 274
    • Hranitor Animale
« Reply #138 on: January 17, 2023, 15:43:35 PM »
Termostat Mahle nu MANN :)
O sa caut original si il schimb.
Multumesc de info.
« Last Edit: January 17, 2023, 16:02:43 PM by VeNoM836 »
VeNoM836
  • 274
    • Hranitor Animale
« Reply #139 on: January 17, 2023, 16:03:26 PM »
Am luat masina de la baietii cu farurile. Ce sa zic, arata foarte bine. Voi vedea in seara asta si rezultatul.
