Subaru participa la NBR Challenge 2010
  • 14189
« on: May 10, 2010, 17:22:16 PM »
Subaru a anuntat in urma cu ceva timp ca va participa la cursa de 24h ce va avea loc pe circuitul Nurburgring si detaliile despre masina si echipa nu au intarziat sa apara.
Subaru participa la aceasta cursa inca din 1992 (cu sprijinul direct al companiei sau prin pasionatii care au pregatit in particular masinile pentru aceasta cursa).\
Pilotii sunt: Kazuo Shimizu, Toshihiro Yoshida, Marcel Engles si Carlo van Dam.
Daca designul masinii a ramas neschimbat (cel putin la exterior), tehnicienii s-au axat mai mult pe performanta. Iata si cateva detalii...
Impreza WRX STI Race Machine
Dimensions                       Overall length : 4415mm / Overall width : 1795mm / Overall height : 1405mm / Wheelbase : 2625mm
Car weight                           1240kg
Engine                           EJ20@BOXER DOHC 16Valve AVCS Twin Scroll +ø38 Air Restrictor
Capacity                           1994(cc)
Maximum output / Torque   243kW(330ps)@5500rpm / 461Nm(47kgf-m)@3000rpm
Transmission                   MT
LSD   Front : Helical LSD / Center : Automatic DCCD / Rear : Mechanical + STI LSD
Steering                          Power assisted rack and pinion
Tyre / Wheel                  DUNLOP / BBS 18diameter,forget aluminum rim
Dumper                          BILSTEIN
Brakes                          BREMBO , Front : 4-pot calipers , Rear: 2-pot calipers
