Un alt cotet numit "Pluto"
daniel.gugu
  • 1382
  • Forester & Impreza
    • http://www.gg-dc.ro/
« on: January 12, 2013, 00:43:15 AM »
Hello again...
Inca un Subaru in fata casei lui Malakay :))
De cateva ore a mai intrat un Subi in familie. Vorbim de un Subaru Impreza GC, 2.0 turbo, 4wd.
Masina a fost postata la "vanzari auto".
Poze mai tarziu, dupa o curatare completa.
Impresii la "a nu stiu cata vedere" si dupa prima plimbare :
Estetic :
- lasa mult de dorit - tabla ruginita
Tehnic - mecanic :
- un monstru brutal si foarte galagios
Ca planuri : inca nu sunt finalizate...
Multumesc Malakay... Inca o data...
UP-DATE 11.02.2016
Engine - power :
- Apexi Power FC Commander
- Apexi Boost Controller Kit
- radiator aluminiu
- ventilatoare Mishimoto
- fmic
- pompa benzina Walbro 255l
- surub magnetic baie ulei
- tampoane motor & pitch mount STI Grupa N
- radiator ulei
- turbo TD05H
- injectoare yellow 440cc
- distantiere phenolice admisie
- serpi ...
Transmisie & Suspensie :
- suspensie BC Racing
- pivoti si capete de bara de directie SuperPro
- bascule fata aluminiu
- bielete stabilizatoare CDF Racing
- sway bars front (22mm) rear (24mm) Whiteline
- bucsi spate Powerflex
Frane :
- 4pot WRC calipers
- discuri .... de schimbat
- placute frana DS2500
Up-Date 18.04.2019
Up-Date 28.04.2019
Engine
EJ20 closed deck
Shortblock
RCM/Omega Pistons 92.25 2.1 Stroker  kit
Crankshaft 79mm induction treated STI 2.5
Connecting rod Manley H-Tuff
Main bearing ACL Race
ARP Head Stud Kit Subaru EJ 2.0/2.5L DOHC CA625+, Kit #: 260-4704
ARP Case Bolt Kit Subaru EJ20/EJ25, Kit #: 260-5401
IAG Half Moon Valve Cover Cam Seals Black
13199AA010 Camshaft Sprocket Bolts x 2 Subaru EJ205 EJ255 EJ206 EJ208 EJ207 EJ257
Subaru Impreza, Legacy & Forester Quad Cam Front Timing Belt Cover Bolt Set
Subaru Impreza, Legacy & Forester Bell Housing Timing Hole Bung
Subaru Impreza Turbo 98 On Small Engine Block Gallery Plug & Washer
Oil system
Pan assy, oil Impreza GT/WRX/STI 1994-2005, Forester Turbo 1998-2005 - 11109AA053
RCM Magnetic Sump Bung - RCM2761
Oil strainer complete-engine Impreza GT/WRX/STI 2.0, Forester, Legacy/Outback, Baja - 15050AA050
Screw countersunk head to oil pump cover Impreza STI, 6x14x14
Impreza 2000 To 2007 Genuine Subaru Oil Pressure Sensor/Switch 25240KA040
Subaru Impreza Turbo 92-07 Dip Stick Tube
Subaru Impreza 92-14 ICP Oil Gallery 1/8BSPT Adapter For Defi Gauges
Cylinder heads
Manley Valve Spring and Retainer Kit for Impreza WRX/STI
Intake valves Impreza WRX/STI Manley Performance
Exhaust valves Impreza WRX/STI Manley Performance
Brian Crower 6mm Exhaust Valve Guides
Brian Crower 6mm Intake Valve Guides
??? Camshafts
Cooling system
Mishimoto Racing Thermostat Subaru STI 2001-2016   MMTS-WRX-01
Mishimoto radiator MMRAD-WRX-01
Mishimoto radiator vents MMFS-WRX-01P
Mishimoto kit furtunuri MMHOSE-WRX-01BK
Mishimoto MMHOSE-SUB-ANCRD
Subaru Impreza Turbo High Flow Cast Impeller Water Pump Kit
Subaru Impreza Turbo Oil Cooler to Water Pump cross over pipe
Subaru Impreza 96-17 Water Transfer O-Rings & Bolts
Fuel system
DW300 340lph Deatschwerks Compact In-Tank fuel pump Impreza 1997-2007    DW-9-301-0791
Subaru Impreza Turbo 92-00 Fuel Tank Straps
Subaru Impreza 93-00 Fuel Neck Filler Pipe Kit
Subaru Impreza Fuel Filler Neck Cap
Subaru Impreza 92-00 Fuel Filler Neck Lower Hose & Clips
Subaru Impreza 92-00 Fuel Filler Neck One Way Valve
Subaru Impreza 92-00 Fuel Filler Neck Body Gasket
Subaru Impreza 00-07 Fuel Pipe Retaining Clips 42037AE150
Subaru Impreza 92-07 Genuine Fuel Pump Tank Gasket
Accessories
STI Performance Group N engine mount, right Impreza    ST4100055110
STI Performance Group N engine mount, left Impreza    ST4100055120
Subaru Impreza, Legacy & Forester Genuine STi Group N Engine Pitch Stopper
Engine gasket and seal kit Subaru Impreza STI 2.0 2001-2005    10105AA360
Subaru Impreza, Legacy & Forester Alternator Live Wire Red Rubber Cap
Subaru Positive Battery Terminal Rubber Boot Cover
Subaru Turbo 5 x Exhaust studs & Flanged Nuts
Drivetrain & Transmission
STI Performance Group N gearbox mount, 6 speed   ST410224S040
STI Performance Group N cushion lever support Impreza    ST35036ST000
Subaru Impreza Turbo 2.0 STi 6 Speed Gearbox Gasket Seal Kit 00-02
Subaru Impreza Turbo LHD 00-07 GD/GG ICP Stainless Steel Black Braided Clutch Slave Cylinder Feed Line
Subaru Impreza Legacy Forester Block to Gearbox Stud
Subaru Impreza Turbo Front Gearbox Crossmember Bolt
Powerflex Rear differential mount Impreza GT/WRX/STI   PFR69-122
Subaru Impreza 92-07 Turbo R160/R180 Rear Diff Upper Fill Plug
Subaru Impreza STi R180 Diff Gasket Set
Subaru Impreza 92-07 Turbo R160/R180 Rear Diff Lower Drain Plug
Subaru Impreza, Legacy & Forester Rear Diff End Cover Bolt 800210310
Bolt and washer assembly, pressure plate clutch    800508310
Brakes & Wheels
Front
Brembo STI 2002 Calipers
Godspeedbrakes front discs
Carbone Lorraine RC6 front brake pads for Impreza CL4066RC6
Carbone Lorraine RC5+ front brake pads for Impreza STI 4066T16RC5+
Rear
Godspeedbrakes rear discs
Carbone Lorraine RC6 rear brake pads for Impreza STI 4060RC6
Refurbishment
Subaru Impreza & Forester STi Brembo Front Brake Pad Fitting Kit
Subaru Impreza 2.0 & 2.5 STi Front & Rear Brembo Caliper Mounting Bolts
Subaru Impreza WRX STi 00-07 Brembo Rear Caliper Seal Kit
Subaru Impreza & Forester STi Brembo Rear Brake Pad Fitting Kit
Subaru Impreza STi Front Or Rear Brembo Caliper Bleed Nipple Cover
Subaru Impreza WRX STi 00-07 Brembo Front Caliper Seal Kit
Subaru Impreza, Legacy, Outback & Forester Stainless Steel Caliper Banjo Bolts & Washers
Handbrake
Subaru Impreza, Legacy & Forester Handbrake Shoe Fitting Spring Kit
Impreza 1992 to 2007 Rear Handbrake Shoe Adjuster
Subaru Impreza Handbrake Cable Retaining Clip
Impreza WRX STi Rear Handbrake Shoe Right Hand Lever Kit
Impreza WRX STi Rear Handbrake Shoe Left Hand Lever Kit
Lichid Frana    Motul RBF660
Subaru Impreza Turbo 00-07 GD/GG ICP Stainless Steel Black Braided Brake Line Kit
Wheels & Tyres
Winter - not needed
Summer - Prodrive GC010 17" x 8J, 5x100, 6.5kg/pc
                - Federal 595 RS-R, 235/45/17
Handling & Suspension
Steering rack 2.2 turns lock to lock GpA
Mishimoto Universal Transmission Cooler and Power Steering Cooler, MMTC-U
Bushing column assy Impreza - 34361FC000
Subaru Impreza Turbo 92-05 Steering Rack Mount Brackets & Superpro Bushes
Subaru Impreza Power Steering Pump High Pressure Pipe Banjo Bolt Washer
Subaru Impreza WRX & STi 00-02 Genuine Power Steering Pump Seal Kit
Front
Whiteline Front Control arm - lower inner rear bushing (anti-lift/caster correction)    KCA359
Whiteline front roll centre/bump steer - correction kit    KCA313
Rear
Whiteline rear sway bar links    KLC26
Bracket, trailing arm left Impreza 20540FE110
Bracket, trailing arm, right Impreza 20540FE100
Subaru Impreza Rear Diff Outrigger Washer 41324FA000
Subaru Impreza Turbo Front Chassis Rail Reinforcement Plates
Subaru Impreza 92-07 Lateral Link & Trailing Arm Bolt Set
Subaru Impreza 92-00 Rear Diff Outrigger Mounting Bolts
Subaru Impreza Rear Diff Outrigger Bracket Bolts
Subaru Impreza 92-04 Front Shocker Upper Camber Adjusting & Lower Bolts
Subaru Impreza Turbo 00-07 Rear Subframe Mounting Bolt Set
Cusco power brace, front member Subaru Impreza GT (GC8), 660 492 FM
Interior & Exterior & Body
Body Sandblasting / welding / rust protection
Rollcage OMP FIA
Subaru Impreza 01 on STi Subaru Tecnica Interantional Door Sticker LH
Subaru Impreza 01 on STi Subaru Tecnica Interantional Door Sticker RH
Subaru Impreza Turbo 92-98 Front Bumper Support Beam (New Bolts (4))
Subaru Impreza 92-00 Brand New Rear Bumper Support Beam (New Bolts (4))
Subaru Impreza 92-00 Side Sill Fitting Kit
Subaru Impreza GC Saloon Fuel Filler Neck Plastic Cover
Subaru Impreza Weather Strip White Screw Grommet
Subaru Impreza, Forester & Legacy Metal Weather Strip Tapping Screw
Subaru Impreza 92-00 Bulkhead Grommet For A/C Cars
Subaru Impreza 92-00 Genuine Bulkhead Grommet For Non A/C Cars
Subaru Impreza 92 Onwards Bonnet Insulation Retaining Clip 90814FC001
Impreza 92-02 Front Window Stabilizer Guide 61256FE020
Subaru Impreza Full Roof Trim Clip Set Saloon & 2 Door Only
Subaru Impreza 92-00 Genuine Upper Front Panel
Subaru Impreza 92-00 Saloon Screen Upper & Lower Trim Set
Subaru Impreza 92-00 Genuine RH Headlight Front Panel
Subaru Impreza 92-00 Genuine LH Headlight Front Panel
Subaru Impreza 92-00 Genuine Front Panel Bonnet Catch Support
Subaru Impreza 92-00 Genuine Lower Front Panel Kit
Bracket spoiler, right Impreza GT/WRX, 96055FA150
Base, license plate Impreza 1992-2007, Forester 1997-2002 - 757745500
Clip - pin Impreza GT - 91167AA000
Bolt, grill front
Bolt, fender Impreza    801506040
Clip - pin Impreza GT    91167AA000
Grommet, hood support stay    57253AA010
Clip Impreza 92-00 - 91167FA010
Clip-bumper, side Impreza GT/WRX/STI - 57728AC090
Clip front bumper Impreza GT/WRX - 59122FA010
Screw, grille front hood Impreza GT - 904575013
Tapping screw, moulding roof Impreza 1993-2001, Legacy 1995-1998 - 91173FA000
Subaru Impreza 00-07 JDM Red Hazard Switch
« Last Edit: June 01, 2019, 07:14:11 AM by daniel.gugu »
Subaru Impreza Type R - GOOFY
Răspuns: Un alt cotet numit "Pluto"
« Reply #1 on: January 12, 2013, 01:04:23 AM »
Felicitari! Rupe-i gura! ;D
  • 4251
« Reply #2 on: January 12, 2013, 01:05:02 AM »
Lu` Malakay??  ::) :D
daniel.gugu
  • 1382
« Reply #3 on: January 12, 2013, 01:16:49 AM »
In cazul de fata : vecinul de langa casa niciodata nu te lasa...  :D ;D
« Reply #4 on: January 12, 2013, 01:25:16 AM »
Malakay e mai ceva decat un virus pt windows...
  • 4763
« Reply #5 on: January 12, 2013, 02:04:35 AM »
Sa o stapanesti sanatos !! si sa aveti grija unul de celalalt !!!
  • 14282
« Reply #6 on: January 12, 2013, 12:02:14 PM »
Eu nu mai vorbesc cu Victor. Daca ma apuca si pe mine virusul sa mai adun si alte Subaru in fata casei?
Sa o stapanesti sanatos si sper ca vei reusi sa o aduci intr-o stare buna si d.p.d.v estetic.
daniel.gugu
  • 1382
« Reply #7 on: January 13, 2013, 15:12:49 PM »
Multumesc mult tuturor...
Nu ma pot da jos din ea... 1 plin = 380km ouch!!! din care si un drum Bucuresti Pitesti.
Acum lucram la lista "cu si despre"  :'( :'( ... E atat de lunga ... Mai lunga decat strada Lunga din Brasov.
Astept sfaturi si sugestii!
  • 3912
« Reply #8 on: January 13, 2013, 16:38:52 PM »
 :D :D Pai ai facut cam mult cu un plin. Dupa ce o vei cunoaste, si te vei da la ea "de-adevaratelea", vei ajunge sa faci mai putin cu un plin.
Felicitari pentru achizitie, sa te bucuri de ea si bafta la intocmirea listei, dar mai ales la "infaptuirea" ei!
daniel.gugu
  • 1382
« Reply #9 on: January 14, 2013, 10:47:45 AM »
Cateva poze de sambata ...
« Reply #10 on: January 14, 2013, 14:09:39 PM »
Ce seamana cu cateaua mea.... ;D
Putina tinichigerie si ai rezolvat o.Sunt sigur ca e doar de suprafata
Spor
« Reply #11 on: January 15, 2013, 00:00:20 AM »
Felicitari. O mare problema la babe este rugina, dar se rezolva. Bafta.
daniel.gugu
  • 1382
« Reply #12 on: January 18, 2013, 14:29:47 PM »
Asa este... si din pacate nu e de suprafata...
Dar cu pasiune si rabdare... se va gasi o solutie...
daniel.gugu
  • 1382
« Reply #13 on: January 21, 2013, 11:48:56 AM »
Ma poate ajuta careva cu o informatie?
Erau niste baieti care vopseau intr-un mod mai "special"... ceva cu o folie si un bazin de apa...
Ceva un link?
« Reply #14 on: January 21, 2013, 13:01:47 PM »
Te referi la hidrotransfer?
  • 4763
« Reply #15 on: January 21, 2013, 13:01:57 PM »
daniel.gugu
  • 1382
« Reply #16 on: January 21, 2013, 13:44:32 PM »
Asta era... Thx again!!!
daniel.gugu
  • 1382
« Reply #17 on: January 22, 2013, 09:01:45 AM »
Pluto si troaca...
  • 4251
« Reply #18 on: January 22, 2013, 11:52:06 AM »
Unde-i Pluto?  :D
  • 4763
« Reply #19 on: January 22, 2013, 12:20:02 PM »
GC-ul e Pluto !!
