Subaru Impreza GC *STi Swap*
  • 4076
Răspuns: Subaru Impreza GC *STi Swap*
« Reply #1480 on: September 08, 2014, 20:24:57 PM »
Ba mai bine voteaza ... cu cine vrei da voteaza ... ca cu anulatul/nevotatul chiar nu se intampla nimic .... :)
(am ajuns si la politica :) )
« Reply #1481 on: September 08, 2014, 20:29:10 PM »
am pus launch controlu la -3200 cum era in tabelu ala si ma asteptam sa fie la 4000 limitarea .. si este la 4500 ... oricum e fun am dat azi 2 plecari de test...
aici il dadeam o tura pe un prieten de la itp  ;D
https://www.facebook.com/video.php?v=736659273069466
https://www.facebook.com/video.php?v=736685283066865
« Last Edit: September 08, 2014, 20:34:39 PM by malakay »
  • 4076
« Reply #1482 on: September 08, 2014, 20:42:50 PM »
pai redline-ul e pus la tine la 7600 (asa era si in rom-ul tau initial) deci 7600-3200 = 4400 pt. launch control
din pacate din ceva motive linkurile de feisbuc nu merg :)
« Reply #1483 on: September 08, 2014, 20:44:18 PM »
da nus cum sa le fac sa mearga a posta la el pe megabuci ... :/
Fab
  • 791
« Reply #1484 on: September 08, 2014, 21:21:02 PM »
Trebuie sa le faci publice pe FB, nu private.
daniel.gugu
  • 1382
  • Forester & Impreza
    • http://www.gg-dc.ro/
« Reply #1485 on: September 08, 2014, 22:19:44 PM »
Frumoasa bestia...
Subaru Impreza Type R - GOOFY
  • 4076
« Reply #1486 on: September 08, 2014, 22:41:34 PM »
Frumoasa bestia...
ai vazut filmuletele undeva ? :)
« Reply #1487 on: September 08, 2014, 23:09:54 PM »
gata man am luat eu filmuletele si le-am urcat
https://www.youtube.com/watch?v=mRCbBv5g8VU&list=UUApqUYjRCdRKGzBf7WG8dxg
G8dxg
nu au calitate din imagine ca se pierde la transfer pe whatsapp  :D
« Last Edit: September 08, 2014, 23:12:26 PM by malakay »
  • 14210
« Reply #1488 on: September 08, 2014, 23:24:47 PM »
Sex!
  • 4076
« Reply #1489 on: September 08, 2014, 23:27:20 PM »
"s-a speriat asta" :) :)
sa nu uiti sa verifici learning view din cand in cand ..... sa vezi cum se simte :)
« Reply #1490 on: September 08, 2014, 23:31:14 PM »
dupa prima 100 km sa ajunga iam ala cat mai sus...
  • 4076
« Reply #1491 on: September 08, 2014, 23:38:14 PM »
IAM-ul trebuie sa ajunga/sa fie 16 daca totul este ok si ar trebui sa ajunga la 16 relativ repede ...
(exista si posibilitatea sa il pui tu direct pe 16 din rom si daca sunt probleme/ai knock mult va scadea ....)
oricum, daca te uiti la learning view si IAM-ul nu este inca 16 si ai valori negative in tabela ... oabla treaba ca nici nu va mai ajunge la 16 ....
sau altfel zis daca IAM-ul nu este inca 16 dar in tabela ai doar valori pozitive/zero ... mai sunt sanse sa mai creasca ...
te-am ametit ? :)
LE: pe scurt eu m-as uita la learning view oricum :)
« Last Edit: September 08, 2014, 23:41:06 PM by andea79 »
« Reply #1492 on: September 08, 2014, 23:59:29 PM »
Fa o acum.Nu mai avem noi rabdare. ;D
« Reply #1493 on: September 09, 2014, 02:18:51 AM »
Ok o sa verific sapt asta ! Sa vad cum stau cu timpu ...
« Reply #1494 on: September 09, 2014, 07:32:20 AM »
ACUM.....
  • 4076
« Reply #1495 on: September 09, 2014, 15:41:29 PM »
DO IT, DO IT NOW !!!! :)
pe de alta parte, asa dupa sunetul din film, ai BOV atmosferic ? stii ca nu este tocmai indicat daca soft-ul foloseste MAF-ul, singura solutie 100% ok pentru BOV atmosferic este soft de tip speed density/cum este si carberry-ul adica care foloseste MAP-ul ....
« Reply #1496 on: September 09, 2014, 18:13:14 PM »
Da stiu si treaba asta... O sa vedem cum facem sa iau widebandu ala sa punem carberry... Mie frica de softu ala de grupa N !
  • 4076
« Reply #1497 on: September 10, 2014, 08:03:39 AM »
pai si mie imi este frica cateodata de propriile modificari pe propria masina :) dar merg incetutz / fac loguri / verific learning view ... si ma calmez :)
in rest ce sa zic, principala modificare este modul in care ECU calculeaza cantitatea de benzina necesara in amestec, folosind presiunea inregistrata de senzorul MAP in loc de "cantitatea" inregistrata de senzorul MAF si daca totul este setat cum trebuie sistemul rezultat poate fi mai robust decat cel initial (sa functioneze corect cu BOV -  sa nu conteze practic daca exista "scurgeri" de aer intentionate sau nu pe tot traseul pana la MAP ... )
dar de la teorie la practica e in general problema si dupa cum ti-am mai spus cand/daca va fi cazul eu pot sa iti arat pasii care trebuie facuti: la ce faci log-uri, ce/unde modifici in functie de log-uri...dar efectiv iteratiile logat/modificat/logat/modificat... tot tu va trebui sa le faci :)
  • 4076
« Reply #1498 on: September 11, 2014, 19:15:01 PM »
deci, un learning view ceva ?  ;D
« Reply #1499 on: September 11, 2014, 20:01:11 PM »
NU, e cablu plecat la brasov :D
