The remaking of a Legacy
  • 1391
Re: The remaking of a Legacy
« Reply #520 on: October 01, 2019, 11:05:27 AM »
Ai respectul meu Wim pentru “making The forum great again”.
  • 704
« Reply #521 on: October 01, 2019, 11:15:04 AM »
Ma simt onorat. Sper sa onorez aprecierea cu o masina functionala.
  • 704
« Reply #522 on: October 02, 2019, 19:06:03 PM »
Winter is coming
Powdercoated, as usual. Si cred ca m-am elucidat si in legatura cu expunerea la temperaturi inalte in timpul procesului - dupa spusele autorului operatiunii, riscul de a decali janta nu are nimic in comun cu coacerea pudrei in cuptor la circa 200 de grade. Asta se intampla la curatarea jantelor, atunci cand, in loc de sablare se opteaza (din considerente de timp si bani) pentru combinatia temperaturi inalte plus decapant. Mie imi suna foarte plauzibil si experientele cu jantele de pana acum nu fac decat sa sustina aceasta ipoteza.
« Reply #523 on: October 02, 2019, 20:28:21 PM »
Sunt opiniile prestatorului care bineinteles nu are cunostinte legate de metalurgie si tratamente termice.
200°C sunt OK pentru oteluri sau fonte, nu pentru aliaje ale aluminiului.
« Reply #524 on: October 02, 2019, 21:30:52 PM »
Hai ca 200 de grade nu fac nimic grav aluminiului. Ti s a topit tigaia ? Ca si aia se incinge grav. Problema apare cand le curata prin metoda inductie. Le coace de le sar mucii.
  • 704
« Reply #525 on: October 19, 2019, 20:02:36 PM »
« Reply #526 on: October 19, 2019, 20:07:08 PM »
Aia e! Nu credeam ca ii pui si motor  :o.
  • 704
« Reply #527 on: October 19, 2019, 20:08:23 PM »
Credeai ca ramane doar un muzeu de piese  :D?
  • 204
« Reply #528 on: October 19, 2019, 20:41:56 PM »
Valoare !!!
 8) ;D ;D
  • 704
« Reply #529 on: October 19, 2019, 20:45:26 PM »
 ;D   ;D  ;D
  • 1391
« Reply #530 on: October 19, 2019, 21:21:25 PM »
Victorie !!! 🎉🎂 O0🥇🏆
« Last Edit: October 19, 2019, 21:23:03 PM by Xander »
  • 704
« Reply #531 on: October 19, 2019, 21:23:49 PM »
Am castigat o batalie, mai am de terminat razboiul  ;D
Dar entuziasmul vostru e foarte reconfortant si va multumesc!
« Reply #532 on: October 19, 2019, 22:34:19 PM »
Bravo !! Asadar, asta-i ce se cheama "o pornire pe genunchi"!!  8) ;)
  • 704
« Reply #533 on: October 19, 2019, 22:38:46 PM »
Multumesc! Cred ca da, era pornirea disperatului  :D
« Reply #534 on: October 20, 2019, 00:32:19 AM »
Ai de capul meu...nu ma pot opri din a admira lucrătura de care te ocupi...arată extraordinar, suna bine și eu după atât munca as ezita sa merg cu ea, asta merge pusă in vitrina cu toate ca ar fi păcat ca e Subie  O0 când ai mers sa o pornești ma întrebam din toate mațele alea dacă o sa găsești modul de a porni motorul ;D felicitări și succes ca începe sa prindă forma finala  8)
@mtfga in legătura cu aluminiu și temperatura, nu e sănătos sa se gătească in vase de aluminiu :o
  • 704
« Reply #536 on: October 20, 2019, 09:16:02 AM »
@Theo: Multumesc, e posibil sa aiba statut de bibelou daca doamna Firea isi duce planul la capat. Dar imi pun sperantele in atingerea magica a lui Vali, respectiv un soft care sa-mi permita sa circul pe strazile patriei. Oricum trebuie modificati parametrii de functionare pentru ca (1) este setat pe benzina cu cifra octanica 100 si (2) ECU-ul pe care l-am montat are raport de compresie de 9:1, iar motorul 9.5:1.
@Heli: E o metafora foarte frumoasa, care ma onoreaza, dar nu pot sa nu ma gandesc la sfarsitul autorului, pe care as dori sa-l evit  :D
« Reply #537 on: October 20, 2019, 10:25:42 AM »
Sa nu cumva sa faci vreo confuzie caci autorul butadei a avut parte atat de o viata nobila cat si de un sfarsit linistit, la domiciliu mai exact, insa ceea ce este cel mai important este faptul ca a ramas in istorie ca si promotor al stiintelor moderne.
Nu la fel de norocos a fost Jan Hus care a cam fost mistuit, la propriu, de flacara aprinsa de catre dogmaticii care se grabeau sa elimine si sa epureze lumea crestina si civilizata de noile concepte evolutioniste.
Dupa scurta opozitie dialectica sa nu crezi ca tolerez obscurantismul insa prin ceea ce ne demonstrezi ma determina sa te pozitionez in clasa elitei misticilor mecanicii moderniste  ;D
  • 704
« Reply #538 on: October 20, 2019, 11:20:20 AM »
Heli, m-ai pus serios pe ganduri, cochetez cu o schimbare de avatar - ma rog, mai corect spus o evolutie:
Sihastrul WIM  ;D
  • 14284
« Reply #539 on: October 20, 2019, 11:51:24 AM »
E un început bun ... Să sperăm că la primăvară vedem invitațiile la plimbare onorate. :D
