2002 WRX SW
2002 WRX SW
Re: 2002 WRX SW
« Reply #1980 on: September 18, 2017, 21:48:04 PM »
supriza totala indeed :)
Re: 2002 WRX SW
« Reply #1981 on: September 18, 2017, 21:52:44 PM »
Vorbea cu cineva.... ;D
Re: 2002 WRX SW
« Reply #1982 on: September 18, 2017, 22:37:21 PM »
Surpriza de la Andea  >:D
  • 14157
Re: 2002 WRX SW
« Reply #1983 on: September 18, 2017, 22:46:50 PM »
Ai facut ai tu ca Pavel la intalnirea de 7 ani.
  • 5347
Re: 2002 WRX SW
« Reply #1984 on: September 18, 2017, 22:57:49 PM »
Ce, cum?
Musiu, nu-i de la Vali, culmea  :D
Il las pe el sa povesteasca mai multe.
Deci asta credeam eu ca e feature, cand de fapt e bug.
Un "bug" perfect de altfel, care-mi convine de minune.
Nu ca l-as folosi, cum nici acum, dupa 2 ani, n-am plecat niciodata blana cu ea de pe loc. Pe asfalt zic  ;)
Re: 2002 WRX SW
« Reply #1985 on: September 18, 2017, 23:06:14 PM »
da , este de fapt un bug-o-feature neintentionat :)
cand am pregatit rom-ul pt. Muttley am pornit de la un rom "OEM" luat de aici
http://www.romraider.com/forum/viewtopic.php?f=35&t=7591
care avea valori oem doar ca avea aplicat si patch-ul de la tinywrex
http://www.ecu-mods.com/online/index.php?act=viewProd&productId=4
chestie de care nu am stiut niciunul pana nu a descoperit Muttley ... :)
o fi bine si asa rau ce sa mai zic ...
« Last Edit: September 18, 2017, 23:09:06 PM by andea79 »
Re: 2002 WRX SW
« Reply #1986 on: September 19, 2017, 06:29:44 AM »
RSR? RCR? RTR?
  • 5347
Re: 2002 WRX SW
« Reply #1987 on: September 19, 2017, 08:03:43 AM »
Ultima.
  • 5347
Re: 2002 WRX SW
« Reply #1988 on: September 19, 2017, 21:07:14 PM »
Alaltaieri seara si ieri am stat mult sa studiez ce naiba s-a-ntamplat de a iesit atrocitatea aia pe dreapta. Si am adunat cateva idei.
Apoi am intrat pe olx, am tastat cu neincredere totala "carenaj golf 4" si am ramas masca... Vreo 20 de anunturi! 2 dintre ele in Brasov!!! Era de asteptat, vw in Romania e icoana, i se-nchina multi, iar eu imi iau aripa din UK... In sfarsit, am cumparat alt carenaj de dreapta! Pretul ca celelalte doua, bataie de joc, 25 de lei. Imi vine sa-mi iau Golf 4 de naveta!
Aseara eram calare pe el cu feohnul de aer cald, il modelam si-i dadeam forme dubioase...
Astazi, ca am multe zile de concediu neconsumate, il puneam pe masina.
Scurtat...
Zona aia la imbinarea cu bara, care inainte arata ca un pechinez calcat de camion s-a transformat in ceva... mai nebatator la ochi, mai digerabil.
Si din profil, inainte si dupa.
Am consumat "vreo 2" tuburi de ceara pe pasajele spate... Le-am inecat!
Si m-am apucat de dat telefoane, sa intreb de un drum neasfaltat da' amenajat cat de cat, in apropiere, neaparat plin de praf! Si am aflat de unul. Si au fost unele din cele mai distractive 10 minute pe care le-am trait cu masina asta vreodata. Adica e perfect drept drumul asta, fara gropi prea multe sau adanci, aderenta precara, adica perfecta... Directia e nebunie pentru redresarea derapajelor, ramane modificarea nr 1, fara discutie. Si am incercat pentru prima oara o plecare de pe loc mai vioaie pe macadam. N-am ce explica, cuvintele nu ajuta...  Poate un lucru ar merge mentionat - pentru asta e Subaru turbo AWD. Nu pentru liniute, nu pentru acceleratie, provocat invidie vecinilor, consum, confort... Pe macadam bun, impinsa putin, prin tot norul ala de praf... straluceste!
Nu pot sa cred c-am facut chestia asta deliberat si intentionat si cu zambetul pe buze!
Cam asta a fost cu sezonul asta cald si chestiile urgente de facut la trancarici. Aer conditionat, arcuri joase, aripa indoita si schimbata, garnituri de culbutori, jante indoite cu final spectaculos as zice, carenaje spate... Vai, si nenorocirile alea de difuzoare. Alea n-au fost deloc treaba urgenta si nicidecum inspirata, da' ncsf. Si am avut momente in care ma dureau toate si-mi venea sa cedez nervos, dar acum sunt impacat si foarte multumit! Imi pare rau ca n-am rezolvat cu geometria si caderile, dar e si 2018 un an.
Mai am de pus aparatori de noroi, le astept de la nicu intrecaretul, ceara pe sub restul cojii (iau maine inca 10 tuburi) si e gata de o iarna de daily driving  :(
Mai spun o data, n-am mai zis-o de mult: iubesc masina asta!!!  ^-^
« Last Edit: September 19, 2017, 21:10:17 PM by Muttley »
  • 2966
Re: 2002 WRX SW
« Reply #1989 on: September 19, 2017, 21:32:54 PM »
Desi nu ti-am spus-o ti-o repet asa cum si G.K. Chesterton ne marturisea in "The Everlasting Man": "Iubirea inseamna sa iubesti ceea ce iti este antipatic, altminteri, nu este o virtute".
Eu prefer a sustine ca opusul iubirii este insasi indiferenta, mai precis acel sentiment intens care alterneaza intre cele doua relatii antagonice si il framanta chiar si pe insusi Gaius Valerius Catullus  ;) ;D :P, drept urmare imi duc masina la AutoKino...   :-*
  • 5347
Re: 2002 WRX SW
« Reply #1990 on: September 19, 2017, 21:35:04 PM »
Mdea, eu o iubesc mai rudimentar, asa, fara substrat si antagonisme ^-^
Re: 2002 WRX SW
« Reply #1991 on: September 19, 2017, 22:37:44 PM »
Muttley, jur ca ar trebui sa scri o carte!
Abia astept sa vina iarna sa inceapa distractia :)
  • 5347
Re: 2002 WRX SW
« Reply #1992 on: September 19, 2017, 22:39:49 PM »
Carte de adormit copii? E o idee...
Am uitat sa zic... Sa nu bata pietre-n tabla e fix nepretuit!
Re: 2002 WRX SW
« Reply #1993 on: September 19, 2017, 23:07:22 PM »
  • 5347
Re: 2002 WRX SW
« Reply #1994 on: September 19, 2017, 23:23:16 PM »
Mersi!
Cum limba germana imi repugna de-a binelea, d-acu-ncolo o dau pe "fion", ca sa fiu sigur ;)
  • 14157
Re: 2002 WRX SW
« Reply #1995 on: September 19, 2017, 23:32:40 PM »
Inchin un pahar de vin alb in cinstea reusitei si iti urez sa completezi inca 100 de pagini. Astept cu lacrimi de emotie si nerabdare finalul apoteotic scris in germana.
Fara Heliotropus si Wrangler jurnalul ar fi fost mai trist.
Revenind cu picioarele pe pedale, ma bucur ca ai trecut peste greutati si ai realizat ce ti-ai dorit in materie de Subaru. Si bine ca nu ai luat-o pe a mea, ca acum nu mai aveam atatea bug wrx break restaurate in tara.
  • 5347
Re: 2002 WRX SW
« Reply #1996 on: September 19, 2017, 23:35:15 PM »
Vesca ai gresit pagina =)))
  • 5347
Re: 2002 WRX SW
« Reply #1997 on: September 21, 2017, 20:55:02 PM »
Am sa fiu obositor, da' n-am ce va face, eu imi notez chestii aici.
Tocmai s-a consumat ziua a 4-a din adaptarea carenajelor. Si ULTIMA!!! Adica cel mai probabil n-o sa mai existe vreo continuare, cu fibra de sticla and sheet. Sunt, in sfarsit, multumit de rezultat!
Asa... ies in seara asta de la serviciu si, la tigara de incalzire motor inainte de plecare, ma uit la carenajul drept, ala care inca-mi statea-n gat, ca avea o zona inspre fata unde distanta fata de muchia aripii era deranjant de mare. Si am o revelatie, ca sa mai tai 1-2mm dintr-un colt, asta facandu-l sa se aseze. Bun, ajung acasa, ridic troaca, scot roata, tai, finisez, probez, nimic. Venea la fel de prost.
Trec la ultima solutie, "fion" cu aer cald. Si ma apuc de modelat carenajul la propriu. Incalzeam, il tineam in forma dorita, asteptam cat ma lasau nervii, stropeam cu apa pentru racire fortata, repetam. M-am legat si de imbinarea cu bara, unde era iar o distanta, dar aia din forma Golfului, sa-i zic "constructiva". Noah, am incalzit, am modelat, am probat. Tot nu statea bine! Ofticat si plictisit am mutat fixarea cu surub de pe gatul de umplere (aici doar eu inteleg, nu va obositi). Si... miracol! S-a asezat! Perfect!!!  :o :o :o
Incercuite-n poza sunt portiunile unde plasticul statea distantat de tabla.
Un efect secundar - plasticul depaseste tabla cu o distanta uniforma pe toata circumferinta. Inainte venea aiurea.
Cu zoom si imaginatie se vede si faptul ca plasticul "se muleaza" pe ansamblul arc-amortizor. Am decupat usor si aici, ca aveam un usor contact.
Ironia-i ca-ntr-un final apoteotic, asta drept a iesit mai bine decat stangul, de care eram foarte incantat de altfel. Echitabil in cele din urma, cum criblura aia multa si diabolica e pe marginea din dreapta a drumului.
Experiment carenaje spate pe Impreza new-age: reusit! ;)
Sfarsit!  ^-^
___________________________
Astazi a mai fost o chestie de mentionat, o premiera.
De cand e la mine a vazut doar Petrom 99 si Oemve 100. Am trecut pe lang-un Mol proaspat deschis, aveam becul aprins de periculos de mult timp, asa ca i-am facut un plin cu zeama din poza, incurajat si de faptul ca Andea a scris candva, p-undeva pe forumul asta, ca merge si Mol in lipsa de celelalte doua.
Sambata o plimb pana la Piatra Neamt, am sa raportez daca-s probleme.
Si in incheierea unei zile cu final fericit pentru troaca, fiind si sarbatoare,  i-am dat Fionei acces la castronul cu bunataturi al maimutei. E aia cu botu' pana-n gat in hrana de sterilizate.
« Last Edit: September 21, 2017, 21:00:43 PM by Muttley »
  • 5347
Re: 2002 WRX SW
« Reply #1998 on: September 22, 2017, 17:35:17 PM »
Discutie pe ARB va rog, andea, tu ai experimentat deja, rog pareri.
De fabrica: 20mm fata, 17mm spate.
Acum: 20mm fata, 20mm spate.
Varianta 1: 22mm fata, 20mm spate;
Varianta 2: 25mm fata, 25mm spate.
Variabile:
- prea subtila schimbarea si risc sa nu se simta mare lucru;
- prea mare schimbarea si risc sa rupa aderenta brusc si violent, iar eu sunt soferake amator.
Deci varianta 1 sau varianta 2?
Re: 2002 WRX SW
« Reply #1999 on: September 22, 2017, 17:42:43 PM »
dar nu exista ceva reglabile sa le poti ajusta in caz ca da cu virgula ?
la fel ar mai fi discutia daca sunt bari pline sau goale ...anyway... daca sunt doar cele 2 variante eu as alege a doua
